This page provides information on the Translucent Two-Sided Material.
The VRayMtl2Sided material is a utility material provided with the V-Ray renderer. The material allows seeing the light on the backside of objects.
Use this material to simulate thin translucent surfaces like paper, cloth curtains, tree leaves etc.
© Stephen Andrianakos
Front – The material used for front-side faces as defined by the object normals.
Back material –The material used for back side faces as defined by their normals.
Use back material checkbox – When disabled, V-Ray considers both sides assigned with the front material. When enabled, you can assign a different material from the front one.
Translucency – Determines which side (front or back) relative to the camera is more visible in the rendering process. By default this value is 0.5, which means that both the side facing the camera, and the one facing away from it, will be visible to the same degree. When this parameter is closer to 0.0, more of the material facing the camera is going be seen. When it is closer to 1.0, more of the back material is seen.
Multiply by front diffuse – When enabled, the translucency is multiplied by the diffuse of the front material. This option is not available when the renderer is set to GPU.
Force single-sided sub-materials – When enabled (the default), the sub-materials render as one-sided materials. Disabling this option is not recommended.
Example: Translucency Value (Front vs. Back Material)
In every pyramid, there is a VRayLight (Sphere type), which is the only light source in the scene. The setup of the VRay2SidedMtl includes a VRayMtl in the Front Material slot, and Check-Box Off. That means V-Ray uses the same material for the Back one as well. The VRayMtl (Front material) has a diffuse Bitmap and for the opacity - a procedural Output map.
Opacity = Off
Translucency = 0.2
more of FrontMtl
Opacity = Off
Translucency = 0.8
more of BackMtl
Opacity = 0.5
Translucency = 0.2
more of FrontMtl
Opacity = 0.5
Translucency = 0.8
more of BackMtl
Example: Usage examples
These are some examples of common usage for the V-Ray 2-sided Material
Slim Curtain Look
Paper Lamp
Textile Lamps
Leaves
- This material gives best results when assigned to single-sided objects (non-shelled) like planes, extruded splines, etc. Otherwise, it can lead to much longer render times.
