This page gives information on the VRayAO render element.
VRayAO render element creates an ambient occlusion effect in the scene. The render element consists of a VRayExtraTex render element with a VRayDirt texture loaded in it.
The background is calculated with unoccluded color by design. You can use compositing with the New V-Ray Frame Buffer (VFB).
VRayVFB – When enabled, the render element appears in the New VFB.
Denoise – Specifies whether to denoise this render element.
Consider for antialiasing – When enabled, antialiasing will be considered where possible.
Affect matte objects – Sets whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material or VRayObjectProperties with the Matte surface option enabled.
Radius map – Determines the amount of area (in scene units) where the VRayAO effect is produced. You can also use a texture to control the radius. The texture intensity is multiplied by the radius to calculate the final radius at a given surface point. If the texture is white at a given surface point, the full radius value is used. If the texture is black, a radius of 0.0 is used.
Distribution – Forces the rays to gather closer to the surface normal. The effect is that the dirt area is being narrowed closer to the contact edges. For ambient occlusion, set this parameter to 1.0 to get distribution similar to the ambient lighting on a diffuse surface.
Falloff – Controls the speed of the transition between occluded and unoccluded areas.
Subdivs – Controls the number of samples that V-Ray takes to calculate the VRayAO effect. Lower values render faster but produce a more noisy result.
