© Taichi Kobayashi
« Previous Version 8 Next »
This page contains information about the V-Ray TexOSL node.
The V-Ray TexOSL map can be used to load Open Shading Language OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray. It can be used with shaders that have simple color and float output parameters. These parameters are considered respectively as texture RGB and alpha outputs.
For more on OSL in general, see the Github reference.
UI Paths:
||mat Network|| V-Ray> Texture: File > V-Ray OSL
OSL Code
OSL Source  Determines how the OSL code is drawn.
Inline OSL
File path (.oso/.osl)
OSL Code  A space for manual insertion of an OSL code.
Path to .oso/.osl file – Specifies the .osl or .oso file which contains the shader (object) code.
Color & Alpha Tweaks
These rollouts are the standard V-Ray for Houdini texture rollouts.
  • The V-Ray TexOSL texture automatically compiles OSL shaders to object code (OSO format) upon shader selection. No following compilations occur (even at render events). If the loaded OSL shader is modified click the Recreate attributes button for your changes to take effect.
  • An OSL compiler that translates *.osl files to *.oso files can be found in the tools subdirectory of V-Ray's root installation folder.
References
