Build 5.20.01
Official release, update 2.1
Date - Nov 4, 2021
Download V-Ray 5, update 2.1, for 3ds Max
New features
V-Ray, VRaySun/VRaySky/VRayAerialPerspective
- Add atmospheric contribution options to the VRaySun light;
Bug fixes
V-Ray
- Crash when using VRayDecal and Cryptomatte RE;
- Graphical glitches after adding color correction to a VFB composite layer with Cryptomatte mask;
- Normal Bump maps crash 3ds Max when rendered in Material Editor swatches;
- Previous render clear mode does not work with most render masks;
- Crash when baking VRayAO with gpu;
- Crash with Anima 4D characters when Production render has been started after a Viewport IPR session;
- Cosmos material drag and drop doesn't work in 3ds Max 2018;
V-Ray GPU
- Crashes with VRayDecal in GPU IPR;
- Cryptomatte with progressive sampling - issues when there is denoiser channel added;
VRayDirt
- Slowdown when blending materials with displacement using VRayDirt as blend amount;
VRayMDL, VRayGLSL, VRayOSL
- Misplaced configuration files;
Build 5.20.00
Date - Oct 26, 2021
New features
VRayDecal
- An easy way of projecting one material on top of another;
VRayLight
- Add contribution per light for atmospherics;
Cosmos
- Cosmos Materials support;
VRay
- Override material preserve functionality option for material displacement;
- Override material preserve functionality option for Reflection/Coat/Sheen;
- Curvature texture support for isolating Convex or Concave values;
- VRayBlendMtl material to blend the displacement maps of the sub-materials;
- Add support for animation exporting for the OSL plugin in Max;
VRayMtl
- Implement the thin-walled mode of the VRayMtl on the GPU;
- Implement the new volumetric translucency modes of the VRayMtl on the GPU;
V-Ray, VRayInstancer
- Lights as source objects for the VRayInstancer;
.vrscene exporter / Chaos Cloud
SiNi Software scattering plugins export;
Anima 4D characters support for V-Ray GPU and Chaos Cloud;
Dot-delimited frame number option in VRayStandalone;
V-Ray, VRayScene
- Initial USD support in VRayScene node;
VFB
Add a Sharpen/Blur post effect layer;
Integrate rendering log in the new frame buffer;
Option to create an "effectsResult" channel when only Lens Effects layer is enabled (no Denoiser);
Option to bake Lens Effects intensity into the Glare channel;
Add an option for adding VFB color corrections to all render channels when saving to separate files;
Add option to set shortcuts for all VFB2 menu items;
Batch image processing in VFB2 for vrimg files;
Ability to add color corrections to the VFB Background layer
VRayDisplacementMod
- Support for Creases modifier with VRayDisplacementMod subdivision;
V-Ray, VRayMultiSubTex, VRayTriplanarTex, V-Ray GPU
- Extend the randomization options in VRayMultiSubTex;
V-Ray GPU
- Implement support for the total lighting render element;
- Support for Sparse Volumes on GPU using Nvidia's NanoVDB library;
VRayIES
- Expose IES light shape and size to MAXScript;
VRayMultiSubTex
- Element recognition in VRayProxy;
VRayOSL, V-Ray, VRayGLSL, V-Ray GPU, VRayMDL
- Support for camera shaders;
VRayVolumeGrid
- Add Absorption color for the Volumetric Shader for CPU rendering;
V-Ray, V-Ray GPU
- Cryptomatte with progressive sampling;
Modified features
.vrscene exporter/Chaos Cloud
- Add a warning that default lights are unsupported when exporting scenes with no other lights;
- Warning that 3ds Max output is not being saved with Standalone when there is a Separate render channels output;
- Auto rename and add a warning if there are render elements with the same name;
Cosmos
Set the default Cosmos browser width to 480 pixels;
Switch Cosmos proxies to preview from file, when previews are available;
Cosmos HDRI "Import" button should replace/set the map if a Dome Light is currently selected;
Use whole mesh (and not the embedded) preview for certain assets (vehicles) on import;
Cosmos Import Options remembered after 3ds Max is closed;
Bring Cosmos browser to front if it is behind other windows and the user clicks the Cosmos Browser toolbar button
V-Ray
Improved LPE material label system;
Update Embree to 3.13.0;
Apply color corrections to the RGB channel when saving;
Remove the Subdivs parameter from V-Ray Light Lister;
Remove Quick V-Ray render settings from the Customize UI;
Add VRaySpecularMap and VRayReflectionMap bake render elements;
Ability to specify a camera to determine reflections for texture baking;
Missing parameters in the MAXScript vrscene export function;
Preserve the cosmos dialog size (and position) after 3ds Max restart;
Preview for UDIM textures in the realistic (Nitrous) viewport;
Auto rename duplicate channel names when auto creating LightMix render elements;
Display an error and abort the render if there are Progressive Caustics and DR set;
Install thumbnail handler for the VRScans files with V-Ray;
Consistent IPR scene update with IPR camera selected when View to Render has been locked;
Improve the data window values when using Auto mode for the VrayOptionRE;
VFB Lens effects were exported even when V-Ray VFB is disabled;
Per frame export for animated parameters of Composite map;
Better performance of dynamic geometry and tiled textures on many-core machines;
Add a custom color option for background in VRayExtraTex render element;
Implement Qt-based user interface for VRayMtl, VRay2SidedMtl, VRayALSurfaceMtl, VRayClipper, VRayColor, VRayFastSSS2, VRayProxy;
Particles rendering with Embree;
Rename the VRay Asset Browser's 'Add to Scene' option to 'Add to Material Editor' or relevant;
Improved anisotropy for the V-Ray material;
- Rename the VRay Asset Browser's 'Add all to scene' to 'Add all to material editor'
V-Ray GPU
Use small buckets when rendering with CUDA CPU Only;
VRayDirt with "Ignore Invisible Objects" enabled should not be affected by lights that are invisible;
Spot Lights with narrow cones have wrong penumbra with V-Ray GPU compared to CPU;
Improve VRayTexOCIO on GPU;
- Expose VRayTotalLighting RE in V-Ray GPU UI;
- Oversaturated rendering of Mix map when mapped with values above 1
V-Ray Toolbar
Integrate Vantage Live Link with V-Ray for 3ds Max;
Replace the Create VRayMetaballs button in V-Ray Toolbar with Create VRayDecal button;
V-Ray, V-Ray GPU
- Improve the machine info printed in the log in V-Ray Standalone or by the -version flag;
Calculate LC only on the GPU when V-Ray GPU is used;
Add support for tiled textures with large amount of tiles on V-Ray GPU;
V-Ray GPU fails to load and render tiles texture with Mudbox filename format with lowercase $u and $v;
VFB
- Elapsed time is not showing in the VFB Stats tab when rendering in Bucket mode;
Add a new function vfbcontrol #historysize that exposes current history size to MAXScript users;
Add MAXScript command to transfer LightMix to scene;
Add an icon for the "off" state of the VFB layers;
The curve color correction in VFB2 shows visible banding for very low intensity images;
Change the Source back to RGB in VFB if the VRayBackToBeauty element is disabled;
Implement VRAY_VFB_GLOBAL_PRESET_FILE environment variable for the new VFB;
Allow masks for Render element layers;
Improve the Lookup table VFB2 correction;
Cameras in Render Pull-Down button in VFB to be listed in a sorted order;
Possible to load/save VFB2 shortcut configuration from/to file;
VFB2 should remember collapsed state of history and layer widgets;
Reset VFB position button in the Render Setup window;
Disable Layer controls if the layer is disabled;
VRayCurvatureMap
- Option to ignore bump in VRayCurvature;
VRayDirt
Streaks breakthrough for VRayDirt;
Blur effect for streaks in VRayDirt;
Ignore bump option for VRayDirt;
Thin mesh mode for VRayDirt;
Add output section to V-Ray Dirt texture;
- Support for reading custom data channels from Phoenix's PRT Reader in V-Ray Instancer;
V-Ray, VRayInstancer, VRayTriplanarTex
- Thinking particles instancing to support Data Channels from TP (tPDCbitmap);
- Change the name of the "Improved" model in VRaySky to "PRG Clear Sky";
V-Ray, VRayTriplanarTex, V-Ray GPU
Add "by node handle" randomization mode in VRayTriplanarTex;
TriPlanar texture make textureable the "frame_offset" and "texture_rotation" parameters;
VRay2SidedMtl, VRayColor
- Implement the UI of VRay2SidedMtl and VRayColor in Qt;
VRayAO
- Ability to exclude objects / lights from VRayAO render element;
- Add the "Ignore invisible objects" option to the VRayAO pass;
VRayBitmap
Add "auto" mode for the color transfer function in VRayBitmap;
Open browse window with VRayBitmap creation in 3ds Max 2022;
VRayDenoiser
Fall back to Intel Denoiser when there is no suitable hardware for the NVIDIA Denoiser;
Add an option to the Denoiser to take under consideration that you are rendering 360 panorama;
VRayDistanceTex
- Add the possibility to remove multiple objects from VRayDistanceTex list;
VRayEnvironmentFog
- Gray out the mapping options in VRayEnvironmentFog when the current renderer is V-Ray GPU;
VRayFastSSS2
- Implement Qt UI for VRayFastSSS2 Material;
VRayLight
Make the button for texture in VRayLight larger;
V-Ray lights' settings to be set to default value with right click on the spinners;
Remove some old stale options from the UI to reduce complexity;
Hide the No Decay option of V-Ray lights for new scenes;
VRayLights to only accept multiplier values above zero;
Don't disable adaptive dome lights if all excluded for shadows objects are already invisible for shadows;
VRayLight, VRayMtl
- Extend the Drag and drop Cosmos HDRI textures;
VRayMDL
- Ability to suppress the MDL search path prompt;
VRayMtl
- Implement new physically correct GTR anisotropy based on linear stretching of the microsurface;
VRayOSL
- Add support for animation exporting for the OSLMap plugin in Max;
VRayPhysicalCamera
- Link the values for EV and ISO to update together in VRayPhysicalCamera;
VRayScene
Make the Auto mode of "Flip Axis" in VRayScene node to work for USD files;
Scale setting for VRayScene node;
VRayStochasticFlakesMtl
- Remove Subdivs parameter from VRayStochasticFlakesMtl's UI;
VRayToonMtl
- Remove Subdivs parameters from VRayToonMtl's UI;
VRayUVWRandomizer
- Minor UI improvements for VRayUVWRandomizer;
VRayVolumeGrid
Speed up frame blending with Time Bend controls;
Enable Probabilistic Volumetrics by default for new scenes;
Sparsify VDBs exported by the Phoenix simulation or the cache converter;
Probabilistic shading should have an effect only with V-Ray in 3ds Max;
Enable GPU preview and velocity streamline preview in 3ds Max 2022;
Allow animating of the Solid, Wetting and Voxel Mode Override node properties in 3ds Max;
Move the Preferences and About dialog from the Simulator to the Phoenix FD menu;
Make Huffman compression of particles multi-threaded and break up the channels into pieces like the grid channels;
Make Zip compression of particles multi-threaded;
Sequential Tab ordering of the dialog controls in 3ds Max;
Bug fixes
VRayBitmap's Mono output set to Alpha doesn't work with Mix and Composite maps when exported;
Anima Subscription models are not rendered properly with Standalone and V-Ray GPU;
Wrong export of ColorCurveGrad.osl and SetFloat.osl;
The cache size for tiled textures is not exported;
Cache normals option in VRayDisplacementMod has no effect in vrscene;
Discrepancy with VRayUVWRandomizer's Random by Instance ID and Random by Particle ID modes in V-Ray Standalone;
Incorrect export to .vrscene of the mirror option in the Coordinates rollout;
MultiTexture results in V-Ray Standalone don't match V-Ray for 3ds Max when randomizing by object;
Forest Color results in V-Ray Standalone don't match V-Ray for 3ds Max when "random strength min" is greater than "random strength max";
Scene with empty name is exported incorrectly as .vrsceneuntitled;
Add a warning that VRayBitmap's Noise options do not render in Standalone;
VRayUVWRandomizer random by name / by element distribution on geometry mismatch with V-Ray Standalone;
No error code when exporting vrscenes to wrong paths;
Access violation on "Export and Render" in case of issues with finding V-Ray Standalone installation;
VRayMultiSubTex Random by Name distribution on VRayLight mismatch with V-Ray Standalone;
Exporting .vrscene zip or folder to existing one merges the assets instead of overriding them;
Archive as ZIP is greyed out if we open another scene to export;
OpenSubdiv Preserve Geom Bnd/Preserve Map Bnd options are not exported to .vrscene;
Wrong vrscene export - skipped switch material in blend;
Displacement texture of VRaySwitchMtl sub-material is not exported;
Some of the MultiSubTex modes are not properly exported to Standalone;
Motion blur shutter efficiency is not exported;
Disabling the 'generate render elements' option in the VRayDenoiser has no effect when exporting .vrscenes;
vrscene export doesn't register VRayDisplacementMod amount animation;
VRayDistanceTex with hidden reference object is not exported properly to vrscene;
Animated Gradient ramp is not exported with .vrscene file;
Show a warning for unsupported image filters when exporting to vrscene and Chaos Cloud;
Discrepancy with VRayTriplanar's Random by Instance ID and Random by Particle ID modes in V-Ray Standalone;
Negative anisotropy values are clamped to 0 in vrscene export;
VrayEnvironmentFog with loaded animated atmospheric gizmo is not exported to .vrscene;
Warnings during scene export fail backburner jobs;
Incorrect scene export with Forest Pro with camera motion blur and forest camera density/scale checkboxes enabled;
VRayMtl's animated map multipliers / color swatches are exported incorrectly;
Animated self illumination multiplier of VRayMtl is not exported to Standalone/Chaos Cloud when a map is used;
Mapped Fog color of VRayMtl is not exported properly;
Per frame export for animated Phase parameter of VRayNoiseTex map;
Per frame export for animated parameters of VRayNoiseTex map;
- Forest Pack 7 "Limit to visibility" feature doesn't work with animation export
Cosmos
Cosmos import options window for 3ds Max 2018 is not properly scaled and moved;
Cosmos importer settings should be persistent across 3ds Max sessions;
Bump amount of imported Cosmos assets doesn't scale properly depending on the 3ds Max Units Setup;
Wrong Cosmos gallery size in maximized browser window after reopen;
Cosmos browser exceeds desktop height on higher desktop scale (250%);
Installer
Installer displays wrong destination paths for 3ds Max 2022;
Some of the shortcuts that V-Ray installs are not visible in the Windows Start Menu;
Phoenix
Rendering animation to vrscene or on the Cloud during simulation will render only the first cache from the sequence;
Transforms of Render Cutter, Glass geometry or Fade volume do not contain animation when exported to vrscene from 3ds Max;
- Rendering in Mesh Mode with Smoothing and Motion Blur enabled loses the smoothed normals in 3ds Max;
V-Ray
Crash with camera shaders on process exit;
Fish eye auto-fit option is ignored on vrscene export;
Normals render element is wrong with texture baking when a bake camera is specified;
Crash when successively deleting cameras in V-Ray Camera Lister;
MaxScript error (and no export) with the VRMat converter when a VRayMultiSubTex is present in the shader;
3ds Max freezes on scene reset if there is a corrupted vrimg file in VFB2 image history;
V-Ray Spawner is restarted on second V-Ray DR render;
Typos in the usage text of Material Library Downloader;
Crash with Slate material editor when the material renderer is V-Ray but the production renderer is another;
Crash with printing warning on scene export having MultiScatter in the scene;
vfbcontrol #historyload returns control back to the caller before the image is loaded;
V-Ray Scene Exporter Analyze UI is messed if Cloud submitter is opened over it;
Difference between material displacement with and without a modifier with the same settings;
Register V-Ray menus writes in Program Files when no user settings are present;
Crash when rendering specific scene with Physical materials in Standalone;
Rendering with VFB2 in V-Ray Standalone prints QObject::installEventFilter message;
Pixel aspect is not applied on render begin but only if toggling the pixel aspect option;
VFB2 menu shortcuts are listed multiple times in 3ds Max 2018 and 2019;
.vrscene exporter / Chaos Cloud's V-Ray path browse button doesn't work in 3ds Max 2022;
Thinking Particles normal meshes (non instanced) are no longer rendering along with Instances or when Instancing is turned on in tP.;
JSON validation when trying to load layer presets wtih MAXScript;
Wrong render with V-Ray GPU when the frame being rendered is outside the active time segment;
Error with Max Batch resulting from Cosmos importer connection on 3ds Max startup;
Incorrect shadows on alembic file when including it to a light;
Problem with reflections when baking VrayCompleteMap;
Material IDs are not rendered properly on Thinking particles using instancing;
ThinkingParticles are not rendered at all with Render Instance enabled if they don't have explicit Shape instancing;
Standalone generates artifacts when switching the material slot (of a multi material) in animation;
Create V-Ray Physical Camera command is missing in main menu;
Exception when rendering with V-Ray GPU from viewport that is set to align with some light;
VRayDRBucket render element could be denosied;
Image file paths are not listed in the asset tracker for VRayBitmap texmap with <UDIM> tiles;
Difference in displacement between 3ds Max and Standalone;
VRayInstancer doesn't render VolumeGrid with motion blur enabled;
Laggy Cosmos Browser when the create light operation in Max is still active;
VRayInstancer, VRayMetaball, VRayPlane, VRayScene, VRaySphere are incorrectly named in the Modifier list in Max 2022;
V-Ray GPU
V-Ray GPU crashes on render end in scenes with VraySun and disabled atmospheric effects;
Remove Prepass samples option from GPU render settings;
Gray out "Multiply color by opacity" option of the V-RayLightMtl when V-Ray GPU is selected as engine;
Crash in V-Ray GPU IPR when switching GPU Light cache on/off and restarting IPR;
Specific UDIMs are not supported on GPU;
Crash with GPU Light cache from file on second render;
GPU Light cache from file is not working;
Simple scene renders much slower with adaptive dome light and specific dome texture;
Crash with CUDA-CPU and k2 on the 3990x threadripper;
Incorrect results with VRayMtl SSS translucency if the 'Scatter Radius' has zero components;
VRayOCIO does not convert VRayColor;
Missing highlight with thin-walled glossy refraction;
Environment changes are not reflected in IPR with GPU LC unless another change is made after them;
Artifacts with VRayClipper using C++/CPU rendering;
Crash in hybrid mode with specific setup with refractive material, bucket sampler and kernel 2;
Incorrect results with invisible lights behind objects with refraction glossiness;
GPU crash with a specific setup including V-Ray UVWGenExplicit and BerconNoise;
GPU Light Cache has 0 num samples in several test scenes;
Error 700 with GPU LC and self illumination test scene;
Endless GPU LC calculation with OptiX on RTX hardware;
Animated VRayLight is not rendered on proper position;
UVs break when using demand Mip-mapping with .tx files;
Freezes during K3 on scenes containing ALSurface;
Copying objects during Optix IPR is not considered;
Artifacts in shadow when rendering scene with VRayFur;
Light cache error when render is stopped during Light cache;
Wrong alpha in specific scene when k3/ooc geometry is used;
Wrong dirt in extra tex with k3/ooc geometry in specific scene;
Wrong extra_tex render in specific scene when kernel3/ooc is enabled;
Missing particles from nightly scene when k3/ooc geometry is used with V-Ray GPU;
Wrong SSS render in nightly scene when k3/ooc geometry is used with V-Ray GPU;
Multicamera VR does not render correctly with GPU in Standalone/Cloud;
Artifacts when AL grid is loaded from light cache;
GPU Light cache Error when aborting render during Loading bitmaps phase;
The MultiMatte render element renders different result in V-Ray GPU compared to V-Ray;
VRayLightMtl Compensate camera exposure not working properly on other than Standard camera modes in GPU;
Crash with VRayExtraTex RE, visible lights and GPU Light cache;
IPR crashes with GPU Light Cache when changing the Background color quickly;
Incorrect VRayLightSelect RE with GPU light cache and multiple light selects containing the same light;
Fireflies with refractive materials;
Crashed various test scenes with Out of core on Linux with GPU;
Darker GI with matte objects when matte for refl/refr is off;
Artifacts in VRayLightSelect RE when rendered with LC GPU on multiple GPU machine;
Exception with GPU Light cache and RTX with specific scene;
Artifacts in IPR with GPU Light Cache when adding/cloning/moving point lights (like IES, Omni, Spot);
Difference in rendering VRayMtl with sheen color inside VRay2SidedMtl in CUDA;
Shutter efficiency has no effect on motion blur with CUDA;
Adaptive Lights with Distributed Rendering and Point light artifacts;
Render artifacts with shelled glass geometry intersecting the bounding box of the Volumetric grid on V-Ray GPU;
Grid artifacts when rendering Particle Shader in Fog mode under the liquid surface with V-Ray GPU;
V-Ray GPU crashes with enabled motion blur and "Default geometry type" set to "Auto";
Crash when rendering VRayCarPaintMtl2 in animation;
Objects render black on using Metalness with no reflection color;
Crash on second render with GPU Light cache and Resumable rendering;
V-Ray GPU IPR
Off in viewport for modifiers also disables them in V-Ray GPU IPR;
Max switches to ticks for the whole duration of V-Ray GPU IPR;
Freeze in V-Ray GPU IPR with GPU Light cache when moving camera or geometry;
Incorrect IPR update with GPU LC when drawing render region in VFB;
V-Ray GPU, V-Ray
- Crash when sliding timeline during IPR session with hybrid mode, OOC and GPU Light cache;
V-Ray IPR
V-Ray IPR restart loop with Anima 4D characters;
POV viewport menu selection doesn't аffect IPR render view after selecting camera in VFB;
Crash when stopping IPR after using debug shading with isolate selected material;
Exposure control from VRay camera is not immediately applied in IPR when switching views;
Environment (Physical camera) exposure control not updated during IPR;
V-Ray Material Library
Material Library No preview for materials/libraries with non-standard names;
Material browser preview data table is highlit on mouse hover without being interactable;
Minimum width for the Asset preview window (Material Library);
V-Ray Asset Browser (Material Library) to preserve the material name when added to the scene;
V-Ray Toolbar
When loading application package from arbitrary location the toolbar icons are not loaded;
Cosmos browser button(s) missing in 3ds Max 2016 & 2017;
V-Ray, VRayPhysicalCamera
VRayPhysicalCamera with Exposure Value Mode is affected with 0 and negative shutter speed;
Particles created by the simulation sometimes have invalid or repeating IDs;
V-Ray Bitmap to VRayBitmap converter
- Output selections of Bitmap are not transfered when converting to VRayBitmap;
VFB
Non-latin characters not displaying properly in VFB Source:LightMix;
V-Ray crashes when reading VFB2 Layer presets with unexpected format;
Color correction layers are not disabled when Render element is selected in VFB;
Crash when zooming a lot in image files with Exposure correction in VFB2;
It is possible to drag color corrections above the display correction;
VFB2 curve "Save As Type" file filter is incorrect;
Curve or White balance pipette tool stays active after layer is disabled;
Coat and Sheen specular render elements are visible into LightMix menu;
Black VFB when aborting a subsequent render if Denoiser is enabled;
VFB2 Layers tree is reset in V-Ray Standalone if quotation symbol is used in a layer's name;
Reset all to default doesn't reset removed hotkey after Resolve conflict;
Lens effects do not work correctly when using VRayStereoscopic helper;
Overbright Lens Effects in an image with NaN pixels;
Black buckets when loading a denoiser layer via an image in the History while rendering;
VFB2 fails to load vrimg file in specific case when there is a rendered image and History is disabled;
Incorrect values for render region in VFB2 with MaxScript control function;
Crash when applying Curves correction in VFB2 when the loaded image has no RGB channel;
Color picker window is not contained in the desktop boundaries;
Possible incorrect output with disabled Post Effect layer;
VRay
- Opacity mapped objects are incorrect in VRayZDepth with Don't filter environment option enabled;
VRayBitmap
UDIM files are not resolved when using User defined attributes in VRayBitmap;
Different filtering of VRayBitmap if mapping source is a VRayTriplanarTex texture;
UDIM textures with ${VAR_NAME} are not working;
Regression in resolving paths from User defined attributes in VRayBitmap;
Textures with <UDIM> and <UVTILE> tags and relative paths are not loaded in VRayBitmap;
VRayClipper, VRayPlane
- V-Ray Clipper with "Use object material" turned on crashes with Forest;
VRayCurvatureMap
VRayCurvature map's name gets reset on scene reload;
Difference with VRayCurvature in V-Ray Standalone;
VRayDenoiser
- VRayDenoiser's denoising engine dropdown is grayed out for machines without any dedicated GPUs;
VRayDirt
VRayDirt set to Inner occlusion appears in Reflection RE with V-Ray Standalone;
Debug shading Ambient occlusion mode is wrong for displaced geometry in V-Ray GPU IPR;
Crash when VRayDirt with Streaks enabled is used for OverrideMtl and Preserve options;
VRayDisplacementMod
- Graphic UI elements mismatch and out of borders in VRayDisplacementMod;
VRayDistanceTex
- Discrepancy with Particle Systems and VRayDistanceTex between Max and Standalone/Chaos Cloud. Max rendering improved;
VRayEdgesTex
- Crash when rendering specific scene with VRayEdgesTex as bump and increased number of light cache bounces;
VRayEnvironmentFog
- Crash with incorrectly merged Environment's fog objects;
VRayEnvironmentFog, VRaySun/VRaySky/VRayAerialPerspective
- Wrong consistent render elements of scenes with VRayAerialPerspective;
VRayExposureControl, V-Ray
- V-Ray Exposure Control is not working with EV value from VRayPhysicalCamera;
VRayFastSSS2
Crash when rendering rectangular 3ds Max light with VRayFastSSS2;
Wrong effect of VRayScatterVolume with very high values of SSS color;
VRayGLSL, VRayOSL
- Crash when loading scenes with changed shader paths and null fingerprints;
VRayGLSL, VRayOSL, V-Ray GPU
- In OSL shaders some built-in global derivatives are wrong on GPU;
VRayIES
- Known system exception when loading ies files via MAXScript;
VRayInstancer
Crash when rendering VRayInstancer with animated instanced object and motion blur;
Crash with old scenes with VRayInstancer using Thinking particles;
VRayLightingAnalysis
- Incorrect (larger) lighting analysis illuminance values with area light sources;
VRayLightSelect
- Crash on render with V-Ray Light select RE and refractive matte object intersecting another geometry;
VRayMtl
Crash with clear coat material and subdivided geometry and very high material reflection depth;
NAN pixels with refractive material with negative Fog bias;
Wrong Preserve refraction with Thin-Walled option;
VRayMultiSubTex
- It is not possible to set a number lower than 1 for ID of VRayMultiSubTex;
VRayMultiSubTex, V-Ray GPU
- Output of the randomized maps is clamped with VRayMultiSubTex;
VRayNormalMap
- Animation of VRayNormalMap map rotation parameter is not exported to vrscene;
VRayOSL
Help text indented with spaces is not displayed correctly in VRayOSLTex;
VRayOSLTex Clear doesn't remove the applied texture maps;
VRayPhysicalCamera
- VRayPhysicalCamera's Tilt corrections don't match the viewport;
VRayPluginNode
VRayPluginNode unlinked textures are still rendered;
VRayPluginNode UVW generators are not animated as expected;
VRayPluginNodeMtl
- Crash when setting Gradient Ramp map for VRayPluginNodeMtl BRDFStochasticFlakes Random color map;
VRayProxy
Preview levels list becomes disabled and empty when switching display modes;
Creating a new VRayProxy with "preview from file" uses the default cube for viewport selection;
VRayProxy fails to show viewport preview when opening a scene;
VRayScannedMtl
- Difference in the clear coat layer of VRScans car paint materials between NEXT and 5;
VRaySoftBox
- VRaySoftbox should use the Base color swatch if a base map is not specified;
VRaySphere
- VRaySphere does not work with VRayInstanser;
- Crash with VRayStochastic flakes and random hue in specific scene;
- No effect of Sun invisible and Sun size multiplier options in VRaySky with specified VRaySun node;
VRayToonMtl
- The VRayToon effect does not work with some camera types and FOVs around 180;
VRayVolumeGrid
Increase/Decrease Grid Resolution buttons scale the simulator size after merging a scene in 3ds Max 2022;
Changing the frame during 3ds Max V-Ray IPR CPU distorts the Phoenix mesh when it has modifiers;
Phoenix mesh renders incorrectly in animation with V-Ray Standalone when it has 3ds Max modifiers applied to it;
Retiming particles without IDs causes them to disappear in blended frames;
Particles rendered as Bubbles inside of a liquid mesh render darker when exported from 3ds Max to vrscene;
All types of Phoenix previews are drawn on top of and occlude V-Ray's Viewport IPR in 3ds Max;
Surface Channel of the Liquid Simulator resets to Liquid when rendering starts in 3ds Max;
Re-timed particles using Time Bend Controls lose their ID channel;
Out of memory Error during building mesh with Phoenix liquid when rendering a scene with V-Ray Standalone on Linux;
The voxel preview in 3ds Max 2022.1 is multiplied by the object color;
Active Body simulation with many bodies is very slow in 3ds Max with Macro Recorder enabled;
Crash when rendering Phoenix Simulator with Export as Particle plugged into V-Ray Instancer's Particles list during simulation;
Hiding all Phoenix nodes translates the instances when the Phoenix Simulator is used as Particles in V-Ray Instancer;
The Beer and Ocean presets are rendering differently in V-Ray Standalone for 3ds Max and Maya;
Phoenix GUI license is taken with 3dsmaxbatch.exe simulations;
Crash when meshing grids nearing or over 2 billion voxels;
Crash if A_StopSim() is called on changing the timeline frame during simulation in 3ds Max;
Crash when constructing the scalar Speed channel of VDBs whose bounding box does not start at 0,0,0;
Starting or restoring the simulation sometimes randomly fails on Threadripper 3990X;
Crash when resimulating liquids to VDB, since Phoenix 4.10;
Crash during IPR of a Particle Shader in Bubbles mode with Render as Geometry ON;
Crash when exporting the ID channel of a particle system with more than 536'870'911 particles;
The cache is appearing skewed in the Extended GPU Preview when the selected viewport is turned into the extended GPU Preview Window;
Repeating Undo in the Phoenix MAXScript window will ultimately erase all the script;
Splashes Foam on Hit Amount is named Size Distribution in Track View;
Probabilistic volumetrics render particles in Point mode incorrectly when combined with Smoke;
Fire and fire lights illumination are not visible in Reflection render element with V-Ray CPU;
No motion blur from translation with more than 10 Simulators/V-Ray Volume Grids in Volumetric mode in 3ds Max;
Maya viewport gets stuck when using a Particle Texture as a Surface Channel for meshing;
Build 5.10.03
Official Release, Update 1.3
Date 24 June, 2021
New features
New VFB
- Implement a functionality for adding VFB color corrections to all render channels with "Separate render channels" output;
Modified features
New VFB
- Sort the channels in the LightMix UI alphabetically;
- LightMix should not reset values whenever possible;
V-Ray Cloud
- Print warning for Blur value of Bitmap maps during the Submit to Chaos Cloud rendering analisys;
- Print a warning for modified texture blurriness value during the Submit to Chaos Cloud rendering analisys;
V-Ray
- Include V-Ray App SDK Python 3 binding in the installation;
VRayVolumeGrid
- Replace the 'Particle Mode' of the Volumetric Shader with single sample probabilistic shade;
Bug fixes
V-Ray
- Crash in the compact material editor with Shell materials;
- Crash on closing 3ds Max 2022;
- DR option Restart servers on render end is not loaded properly (since V-Ray 5, update 1.2);
- Loading a scene from the VFB history fails to load the units from the file;
V-Ray IPR
- Crash after render to texture while viewport IPR is running;
- Crash when adjusting TextMap during rendering;
- Crash when calculating VRayLightMeter/texture baking during rendering;
- Crash when rendering with specific Forest Pack scene having Corona material;
- Viewport IPR Safe Frame differences with 3ds Max 2022 hotfix 1;
V-Ray GPU IPR
- The entire render is restarted when Region render is stopped;
New VFB
- "vfbcontrol #loadimage" returns control back to the caller before the image is loaded;
- VFB window moves when loading different sized images on 4K monitors
VFB
- Test resolution cuts rendered image in the 3ds Max native frame buffer;
Chaos Cosmos
- Significant slowdown when saving a scene, when the Cosmos communication is blocked by firewall;
- The Cosmos browser slows down 3ds Max startup when Internet connection is absent;
VRayBitmap
- Options for disabling texture filtering are ignored;
- User tags do not work in file names;
VRayBlendMtl
- Duplicated slots in Slate Material Editor;
VRayCryptoMatte
- Crash when trying to use Cryptomatte mask in .vrimgs with duplicated Cryptomatte elements;
- Wrong cryptomatte manifest if geometries have unsupported symbols in their name;
VRayLight
- Adaptive dome light artifacts in scene with V-Ray Dome and multiple IES lights;
VRayProxy
- Crash when enabling Tessellate Hair with Alembic hairs and VRayVRMat material;
VRayVolumeGrid
- The results with colored transparency/absorption are incorrect in Volumetric Geometry mode;
VRayZDepth
- Colored lines and artifacts are produced over the z-depth image;
.vrscene exporter
- Negative texture values are clamped when plugged in a Composite map and in a V-Ray Displacement node;
VRayDenoiser/vdenoise.exe
- Blurry results with the NVIDIA AI denoiser;
Installer
- Chaos Cosmos service check if running is incorrect;
Build 5.10.02
Official Release, Update 1.2
Date 15 April, 2021
New features
V-Ray
- Add support for 3ds Max 2022. The installation is now using the Autodesk plugin package;
V-Ray GPU
- Add absorption color for the Volume Grid;
Modified features
V-Ray GPU
- Support for motion blur for the Chaos Phoenix's Particle Shader;
V-Ray GPU IPR
- Slow GPU LC preview when moving the scene during rendering;
New VFB
- Implement vfbcontrol history options;
- Shift "Render" button for "Render last" function;
VRayMtl
- The fog color should be enabled in Thin-walled mode;
VRayUVWRandomizer
- Incorrect textures previews (produces black solid color) in slate material editor;
.vrscene exporter
- Export scene offset = ON;
Bug fixes
V-Ray
- Crash when rendering with wrong version DR server;
V-Ray IPR
- Crash when consecutively hiding multiple imported identical Cosmos assets during rendering;
V-Ray GPU
- 3ds Max freezes when there isn't enough VRAM and GPU Light Cache is enabled;
- Adaptive lights grid renders visible artifacts;
- Crash with GPU Light Cache in hybrid mode after adding/removing light;
- Crash with VRayCarPaintMtl with flake size = 0;
- ETA is missing while rendering using GPU Light Cache;
- Objects are missing with GPU Light Cache enabled;
- Specific opacity texture is rendered incorrectly with On-demand mipmapping;
V-Ray GPU IPR
- Crash with GPU Light Cache;
- Crash with RTX when deleting VRayDisplacementMod's texmap during rendering;
- Light cache is not shown during calculation phase with viewport IPR;
- Undoing/redoing hide operations of multiple proxies during rendering causes crashes or endless kernel compilation;
- Unhandled exception in "Preparing direct light manager" when starting DR session;
V-Ray Cloud
- Forest Boundary Checking Edge mode doesn't render as expected; "
VRayLight
- Disc lights produce noisy shadows with Brute Force GI engine;
VRayMtl
- Material with thin translucency renders transparent inside VRay2SidedMtl;
- Missing highlight with thin-walled glossy refraction;
- Outlines appear at the edges of opacity maps;
- Wrong result with refraction glossiness values below 0.78;
.vrscene exporter
- Missing bump in OSL shaders;
Cosmos browser
- High CPU usage when the Chaos Cosmos Browser Service is not running;
Build 5.10.01
Official Release, Update 1.1
Date 17 March, 2021
Modified features
V-Ray
- Support for Autodesk 3ds Max 2022;
V-Ray GPU
- Out-of-core improved IPR update;
- Print device info for GPU Light cache;
V-Ray Cloud/V-Ray Standalone
- Faster initialization of meshes with static 3D displacement;
VRayCryptoMatte
- Add ability to work with VRaySwitchMtl;
- Add ability for Cryptomatte to read Multi/Sub-object materials;
VRayMtl
- Expose the VRayMtl thin-walled refraction option in the UI;
.vrscene exporter
- Multiple standard cameras export;
V-Ray Material library browser
- Fix issue with recursive search in the refresher script;
Bug fixes
V-Ray
- Crash rendering scene with ForestPro 7;
- Crash when a VRayBumpMtl is applied on an object and another VRayBumpMtl is used as an Override Mtl;
- Error building Embree voxel tree when "Conserve memory" is enabled in certain scenes;
- Increased memory consumption with displacement in specific cases;
- No illumination on surrounding geometry from PhoenixFD/VRayVolumeGrid's Fire Lights;
- Underwater lighting is missing when the camera is under the water;
V-Ray IPR
- Incorrect rendering during IPR when switching from None to Volumetric/SSS translucency in VRayMtl;
- VRayPhysicalCamera Tilt & Shift is incorrect since 5.1.00;
V-Ray GPU
- Crash with big light cache subdivs;
- Texture on objects with normal displacement appear smudged with on-demand mip-mapping;
VRayCryptoMatte
- Regression with node custom attributes;
VRayDisplacementMod
- Crash with on specific geometry with Editable poly modifier;
VRayICC
- .icc files are not loaded through the DR assets transferring;
VRayLight
- Random modes for textures applied to VRayLight copies produce non-randomized lighting;
VRayMtl
- Crash when setting reflection/refraction depth too high;
VRayProxy
- Animated Alembic files do not show animation in viewport;
- Newly created proxies with "preview from file" use the default cube for viewport selection instead of the preview geometry;
VRayUVWRandomizer
- Crash when switching between different texture instances;
.vrscene exporter
- Archive as ZIP is greyed out if we open another scene to export;
- Archiving to zip or directory merges the assets instead of overriding them;
- Missing geometry in exported scenes when there is a VRayDistanceTex and VRayDisplacementMod on EditablePoly;
- Tile UV mapping of Bercon Tiles is not working properly;
- "Open ME on apply" doesn't work with drag&drop;
- "Use Real World Scale" doesn't work with user added libraries;
Build 5.10.00
Date 23 Feb, 2021
New features
V-Ray
- Progressive caustics mode;
V-Ray GPU
- Light cache calculated on GPU;
- Add support for blending the sun with the horizon with the Improved sky model;
New VFB
- Layers masking based on Cryptomatte, integer and color render elements data;
- Add stamp layer support;
- Custom White Balance support for color picker and tint;
- Support for animated sequences for Background layer using <frameNum> tag;
- Add an option to bake the RGB primaries conversion;
- Add horizontal/vertical offset for Background layer;
- History render settings loading and comparing;
- Image Info for the history images;
- Save color corrections to a LUT file;
Chaos Cosmos
- Add support for Chaos Cosmos assets within 3ds Max;
VRayMtl
- New translucency modes for based on VRayScatterVolume;
VRayAO
- Add a render element for ambient occlusion;
VRayBackToBeauty
- A render element that expands to the render elements needed for back to beauty compositing;
VRayCoat/VRaySheen
- Render elements for compositing with VRayMtl's Coat and Sheen layers;
- Integrate the Intel Open Image Denoiser;
VRayInstancer
- Support for Thinking Particles as source;
VRayLight
- Add support for additive dome lights;
- Add "Occlude other lights" option;
.vrscene exporter
- Export all camera objects to vrscene;
- Add options to archive and compress scenes with their assets;
V-Ray Camera Lister
- Add a lister tool to manage scene cameras;
V-Ray Material Library browser
- Add a tool for adding custom materials to the local library;
Modified features
V-Ray
- Improve VRayMtl's representation in the viewport;
- Option to render the Physical Material as VRayMtl;
- Preserve opacity, bump and refraction with Override material;
V-Ray GPU
- Rounded corners support with Out-Of-Core geometry
- Support for VRayDirt and VRayCurvature with Out-Of-Core geometry
- Support for VRayFastSSS2 with Out-Of-Core geometry
- Support for VRayALSurfaceMtl with Out-Of-Core geometry
- Support for VRayClipper with Out-Of-Core geometry
- Add support for normal maps in world space
V-Ray GPU/Chaos Cloud
- Support for Forest Color's Tint mapped by a texture;
- Support for tyFlow instances rendering;
VRayCryptoMatte
- Support for Multi/Sub-object materials;
Build 5.00.05
Official Release, Hotfix 2
Date 29 July, 2020
Modified features
New VFB
- Max Script access for OCIO settings with vfbcontrol;
V-Ray scene converter
- Converting CoronaBumpConverter to VRayColor2Bump;
Bug fixes
V-Ray
- An error is printed when rendering with disabled memory frame buffer option;
- Auto white balance renders differently when transferred to camera;
- Missing plugin error when loading scene saved with hotfix 1;
- More noise occurs with Blue noise sampling enabled for grid volumes;
- Crash with a specific scene upon opening in 3ds Max 2021, 2020, 2019;
V-Ray GPU
- Matte objects' primary Visibility is not working correctly;
- The VRayEnvironmentFog parameters (which are last on the list) are applied to all fogs;
V-Ray Dirt
- Ambient + inner occlusion mode results are darker than they should be;
New VFB
- Avoid IPR restart on zoom, resize and side panels collapse;
- Crash when opening old scene with empty New VFB OCIO settings;
- Window position can not be saved on a non-primary monitor;
- Window position is offset on rendering after every scene reset when the persistent settings are saved with collapsed history menu
Build 5.00.04
Official Release, Hotfix 1
Date 14 July, 2020
New features
VRayBackToBeauty
- Add render element that will expand to all beauty render channels;
Modified features
V-Ray
- Simplify the Image sampler options;
VRayBitmap
- View image button should work for .tx bitmaps;
VRayDistanceTex
- Add an option to not compute for the viewports;
VRayMtl
- Raise the default Refraction and Reflection Max depth to 8;
New VFB
- Add keyboard shortcut for Lock Pixel Coordinates ("L");
- Support for the color corrections and VRayDenoiser in V-Ray Viewport IPR;
- Zoom key combinations support;
Installer
- Progress of V-Ray Material Library download should display downloaded/total size in the installer;
Bug fixes
V-Ray
- VRayDisplacementMod's Subdivision not working far from scene origin;
V-Ray GPU
- Activating 3ds Max menus during IPR stops image updates in the VFB;
- Memory leak with VRayDistanceTex;
V-Ray GPU IPR
- Orthographic projection is not rendered properly with RTX;
VRayClipper
- Wrong objects in the exclude list when merged in scene;
VRayLight
- NaN pixels occur with textured adaptive dome light;
VRayToonMtl
- Overlapping MaxScript names of gradient parameters;
VRayTriplanarTex
- Incorrect motion blur;
VRayVolumeGrid
- More noise with Blue Noise Sampling enabled for grid volumes;
New VFB
- Artifacts with Filmic tonemap;
- Colorful halo with Lens Effects and positive Lightness values in the Hue/Saturation color correction;
- Crash on consecutive V-Ray GPU IPR restarts when selecting different layers;
- Crash on scene open when the scene was saved with legacy VFB LUT color correction;
- Different convert to composite result if the first light is turned off;
- Large color values are not formatted properly in pixel info;
- Missing color corrections/post effects on image copied to clipboard;
- Resize on region IPR when an image has been previously loaded from history;
- Show corrected colors doesn't work;
- Switching from OCIO to sRGB and back loses the OCIO settings;
VFB
- "Too many open files" error when loading many LUT files;
Installer
- Downloading the V-Ray Material Library does not work with network paths starting with "\\";
- The install log is empty when an error occurs;
Build 5.00.03
Official Release
Date 16 June, 2020
New features
V-Ray GPU
- Add support for the VRayNormalMap rotation parameter
VRayDirt
- Add Streaks generation options
New VFB
- Add magenta-green tint slider to the White Balance color correction
- History saved render settings loading and comparing
Modified features
V-Ray
- Add UI option to enable the MikkTSpace calculations from Global Switches
- Add UI option to switch back to the Native 3ds Max material swatches
- Optimize conversions between sRGB and ACEScg color spaces when using an OCIO configuration
- Faster calculation of VRaySun
V-Ray Cloud
- Animated parameters of VRayDistanceTex are not exported properly
- Animated position of geometry with large stationary interval differs
V-Ray Cloud/V-Ray GPU
- Add initial support for tyFlow instances rendering
V-Ray GPU
- Automatically disable Out-of-core rendering when the engine type is RTX
- Implement Box sampler type for VRayVolumeGrid
V-Ray GPU IPR
- Endless updates when having a camera with tweaked tilt and shift parameters
V-Ray Standalone
- No image buffer rendering is implemented with new VFB, still processed output is written
VRayDenoiser
- Remove "Generate render elements" UI option
VRayBitmap
- Automatically set the transfer function and RGB color space for normal maps
VRayLightSelect
- Add Subsurface mode
VRayMtl
- Add some tooltips
- Add fabric presets based on Sheen
VRayOSL
- Print warnings for unsupported OSL shader parameters
New VFB
- Add "None" option to hide the secondary color info in the status bar
- Add a progress bar for the loading of the History images
- Add image fitting types option and "Save in image" to the Background layer
- Group the History compare buttons in a single flyout button
- Implement renderer stats
- Preserve the original RGB channel when saving
- Save persistent settings independent on the scenes
- Support for color corrections and settings transfer for V-Ray Cloud
V-Ray Asset Browser
- Add "Use real world scale" and "Use triplanar mapping" options on import
- Rename the "ME" button to "Open ME on apply" to be more descriptive
- Put the converted material nodes in Slate Material Editor for displayed materials after scene conversion
V-Ray Toolbar
- V-Ray Toolbar to look relative to the vrenderXXXX.dlr directory for icon files to aid network installations
Bug fixes
V-Ray
- Body objects are always rendered with draft quality
V-Ray IPR
- Incorrect VRayMtl with displacement texture after IPR update
V-Ray Cloud
- Per-frame export for animated parameters of Noise map
V-Ray GPU
- Crash or artifacts when VRaySwitchMtl uses the default submaterial (since Beta 1)
- Renders may get overexposed with VRaySun when changing scene units due to overflow
V-Ray GPU CUDA
- CPU bucket rendering crashes with On-demand mip-mapped textures
- Crash with Fractal_3.osl OSL shader
- IPR crashes when rendering Out-of-core with CPU device
V-Ray GPU RTX
- OSL maps crash with shaders with string outputs
- Random crash with particle system in the scene
VRayDisplacementMod
- Vector displacement produces wrong geometry with scaled objects
VRayIES
- Incorrect light cutoff when using the light shape for both shadows and illumination
VRayOSL
- Crash after deleting maps linked to VRayOSLOutputSelector
- Shader and VRayOSLOutputSelector output values are reset when path to the OSL asset is modified
VRayPhysicalCamera
- Transfer exposure to camera is not working properly with Exposure Value (EV) mode
VRayProxy
- Wrong VRayParticleTex shading with alembic particle color (since Beta 1)
VRayVolumeGrid
- .AUR files where the grid data is over 8GB are unreadable, fix requires Phoenix 4.20 and newer
- Meshes are rendering without motion blur and the Mesh preview is broken when a modifier is applied
- The resolved cache paths show huge numbers if looking at a frame outside the Timeline Origin - Play Length range
New VFB
- Crash when loading Layer presets (since Beta 2)
- Crash when saving all channels to .vrimg with LightMix, LUT and high resolutions
- MaxScript error that prevents rendering occurs when submitting scenes to Thinkbox Deadline
- Random crash with bucket rendering after multiple frames
- Render view not updated when compare is disabled with no image loaded
- Slowdown when rendering a scene with LightMix on V-Ray GPU
- Sometimes Lens Effects layer UI becomes disabled no matter the enable flag
.vrscene exporter
- Error when exporting a scene with empty mesh object
- Long string parameters containing escape characters get trimmed after 1023 symbols
V-Ray Material Preview
- 3ds Max 2021 hangs when creating Double Sided material in Slate Material Editor
V-Ray Toolbar
- Missing icons with light theme (since Beta 2)
Build 5.00.02
Beta Release
Date 28 May, 2020
New features
V-Ray
- Add light path expressions support through mode of VRayLightSelect;
- Add RGB primaries override for VRayBitmap option in the Color management;
- Implement blue-noise optimization for the DMC sampler;
V-Ray GPU
- Support for Environment and Self Illumination contribution for VRayLightSelect;
VRayNormalMap
- Add Map rotation parameter;
VRayPhysicalCamera
- Add EV parameter;
VRayProxy
- Support common particle interface (IParticleObjExt) for Alembic that can be used with VRayInstancer and Phoenix FD;
VRaySun
- Implement "Improved" Sky model;
VRayVolumeGrid
- Velocity streamline preview;
New VFB
- Background color correction;
- Filmic tonemap color correction;
- Image search in the History based on the saved scene name and note text;
- Solo button Alt+mouse click enables only one light and toggles all the rest in LightMix;
- Special element "Rest" in LightMix that includes everything not in the other elements;
- Support for rendering without a memory frame buffer;
- Undo for Layers actions;
.vrscene exporter
- Add option to export only selected nodes;
- Implement a converter for Physical Material to VRayMtl;
Modified features
V-Ray
- Remove some old stale options from the Global switches;
- Remove the Use local subdivs from Global DMC along with the subdivs parameter of Brute force GI, materials and lights that was dependent on it;
- Simplify the Color mapping options;
- Simplify the Light cache options;
V-Ray GPU
- Add support for VRayUVWRandomizer stochastic tiling options;
- Optimize memory footprint for motion blurred geometry both on CPU and GPU;
- Skip degenerate faces when serializing the Embree tree;
- Support for matte objects through VRayObjectProperties;
- Support for VRayCarPaintMtl2 and VRayFlakesMtl2;
VRayALSurfaceMtl
- Prevent values for the SSS radius parameters that cause artifacts;
VRayMtl
- Add a "Default" preset;
- Use GGX shadowing for all NDF-based BRDFs;
VRayVolumeGrid
- Speed up and use less memory for blending frames having Grid Velocity with Time Bend controls;
New VFB
- Bucket outline improvements;
- Enable the denoiser for history and loaded images;
- Various usability improvements;
New VFB/VFB
- Render button to execute Render command instead of Render Last;
VFB
- Use all supported formats as default filter for loading image
Build 5.00.01
Beta Release
Date - Apr 29, 2020
New features
New VFB
- Add entirely new implementation of VFB with integrated Layers compositing
LightMix
- Add support for lights post-processing in the new VFB
V-Ray
- Support for rendering in ACEScg color space with option to recognize the texture color space from the file name
- Improve precision when rendering large scenes
- MikkTSpace support for tangent normal maps
- New version notifications in the new VFB and render settings About section
- Include the V-Ray AppSDK Python binding with the installation
V-Ray Asset Browser
- A material library browser utility for the V-Ray Material Library
- Add material library downloader working both standalone and as part of the installation
- Render the material previews with a custom .vrscene
VRayMtl
- Add Coat and Sheen layers
- Add simple presets
VRayHairNextMtl
VRayCarPaintMtl2
- Add new car paint material with more precise flakes filtering and reduced memory usage
VRayUVWRandomizer
- Add a texmap that should be used solely with the VRayBitmap's and VRayTriplanarTex's mapping source input with stochastic tiling support
VRayMultiSubTex
- Add randomized hue, saturation and gamma variance options
- Add new Random by Face material ID/Object ID/Element modes
VRayBitmap
- Rename VRayHDRI to VRayBitmap
VRayCompTex
- Add new blending modes Color Shift, Color Tint, Blend Alpha Straight, Blend Alpha Premultiplied
VRayTriplanarTex
- Ability to be used as Mapping source for VRayBitmap
VRayPointCloudColor
- Add a map that supports PointCloud Color Channel
VRayLightSelect
- Support for environment lighting
Installer
- New installer experience with integrated bundled products: Chaos License Server, Chaos Cloud client and V-Ray Material Library
V-Ray GPU
- Add support for Out-of-Core codepath
- Support for 2D displacement
- Rendering of Phoenix FD Particle Shader in Fog mode
- Add support for OSL shaders
- Add support for Cellular map
- Add support for BerconTiles and Bercon Wood maps
- Implement a per-device GPU memory tracker
- Resumable rendering with progressive sampling
