« Previous Version 7 Next »
This page provides information on the 2D Phoenix Grid Texture.
PhoenixFDTexture2D can be created from the Hypershade. It is a simplified version of the PhoenixFDTexture for 2D. It loads and exposes a grid channel of a selected Phoenix simulator object as a procedural texture. Using this component, you can shade the content in ways that the plain Phoenix shader does not support.
The main application of this texture is for shading the meshed of liquids which were simulated using an RGB color grid channel. The technique of mixing colored liquids and rendering their colors is available in the Paints Quick Setup preset.
You could also use it as a blending mask, as described in the Milk & Chocolate tutorial for Phoenix FD.
Another use of the PhoenixFDTexture is for rendering via an external volumetric Shader such as the V-Ray Environment Fog. See the External Volumetric Shader section on the Tips and Tricks page for more information.
UI Path: ||Hypershade|| > Create panel > Maya section > 2D Textures
UI Path:  ||Create Render Node|| > Maya section > 2D Textures
Simulator Node | simNode  – Allows you to specify the PhoenixFDSimulator node.
Channel | channel  – Specifies the channel retrieved from the Phoenix node:
Rendering Fire Color - Returns the resulting color for the Fire, as specified in the Rendering → Fire tab of the Phoenix Simulator.
Rendering Smoke Color - Returns the resulting color for the Smoke, as specified in the Rendering → Smoke tab of the Phoenix Simulator.
Rendering Smoke Opacity - Returns the resulting Smoke Opacity, as specified in the Rendering → Smoke Opacity tab of the Phoenix Simulator.
Channel Velocity - Returns the contents of the Velocity simulation channel. Velocity Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel RGB - Returns the contents of the RGB simulation channel. RGB Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel Temperature/Liquid - Returns the contents of the Temperature/Liquid simulation channel. Temper./Liquid Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel Smoke - Returns the contents of the Smoke simulation channel. Smoke Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel Fuel - Returns the contents of the Fuel simulation channel. Fuel Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel Speed - Returns the contents of the Speed simulation channel. Speed Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
Channel Viscosity - Returns the contents of the Viscosity simulation channel. Viscosity Grid Channel Output has to be enabled on the Phoenix Simulator for this to work.
When doing Liquid simulations, Phoenix populates the grid Velocity channel only for cells / voxels inside the liquid volume - empty (air) voxels contain no velocity information. To generate velocity information for the empty voxels, enable Simulate Air Effects under the Liquid rollout of the simulator and re-run the simulation.
Sampler Type samplerType – Determines the blending method between adjacent grid cells.
Box – Displays cells as cubes. There is no blending between neighbor cells. This is the fastest mode.
Linear – Linear blending occurs between neighbor cells to smooth out the fluid's look. Sometimes this mode may unveil the grid-like structure of the fluid. Up to 20-30% faster than the Spherical option.
Spherical – Uses special weight-based sampling for the smoothest looking fluid. With increasing resolution, the visual advantage between this method and the Linear method becomes less noticeable.
Color Scale | outputScale – Sets the output value of the selected channel.
Color Offset | outputOffset – Offsets the output value of the selected channel.
Rescale Grid Channel – Rescales the output values of a Grid Channel to a certain range. The colors you get from the Grid Texture can be meaningful when data that is read from the Simulator is in the 0-1 range. But in case the grid data is negative, the Grid Texture will return black color, or if the data has very large values, like e.g. the Grid Speed which can go up to several hundred, the color returned by the Grid Texture will be pure white. In such cases this data should be rescaled to meaningful color values, which usually means rescaling it to the 0-1 range. You can find out more info about the Phoenix Grid Channel Ranges here.
Rescaling using this helper simply measures the data range of the selected Channel and changes the Color Scale and Color Offset options. If you are familiar with the Phoenix channel ranges, you can directly set the Color Scale and Color Offset to the values you desire.
If you simulate new cache files, or if you load a new cache sequence in the Simulator, you will need to do this rescaling again to make sure the Grid Texture values are still in the Min-Max range. Note that rendering channels such as the Fire Color and Smoke Color/Opacity cannot be rescaled. Rescaling is especially useful when you are reading channels such as Channel Speed or Channel Temperature which can range up to several hundred or a few thousand, and you want to use them as color or opacity. With such channels, you need to scale them down between 0-1, which would require you to set a very small Color Scale multiplier - 0.001 or even smaller.
Min – Sets the minimum value.
Max – Sets the maximum value.
Rescale to Current Frame – Rescales the channel based on the value in the current frame.
Rescale to Entire Sequence – Rescales the channel based on the values in the entire cache sequence.
Close – Closes the Rescale Grid Channel dialog window.
Skip Displacement | skipDispl  – When enabled, the content is sampled without adding Phoenix displacement.
Alpha is the Color's Intensity | alphaIntens – When enabled, the alpha for the texture will be based on the color's intensity. When disabled the alpha will be solid.
