This page provides information about the Clipper tool in V-Ray for Cinema 4D.
The images at right show geometry before and after being clipped with VRayClipper.
UI Path: V-Ray menu > Geometry > V-Ray Clipper
General
Enabled – Turns the clipper effect on and off.
Affect Light – Enables the clipper to also affect area light sources.
Only Camera Rays – The clipper affects objects as they are directly seen by the camera, but they appear unchanged to reflection/refraction/GI rays.
Clip Lights Geometry – Enables the clipping of lights geometry (for example a mesh light).
Fill Inner Cavities – When enabled, shades the clipped part of the object with the clipper object's shader.
Mode – Specifies how Objects list items are clipped. You can include or exclude an object(s) from the clipper effect.
Objects – Specifies a list of objects that are affected by the clipper.
Mesh Operation – Determines how to use the mesh when a geometry is selected as a clipper:
Intersection – Clips away anything that is outside the specified mesh; only renders objects and parts of objects inside the specified mesh;
Subtraction (scene-mesh) – Clips away anything inside the specified mesh; only renders objects and parts of objects outside of the specified mesh.
