Square Enix © Goodbye Kansas
Version 1 Next »
This page gives an overview of the Metalness Render Element.
The Metalness Render Element is only available for V-Ray 6 for Maya, Beta
The Metalness Render Element shows areas, where a V-Ray Material, with Metalness is applied. The Metalness values are baked into an image, where black corresponds to 0, and white - to 1. The image created can be used as a metalness mask when creating PBR shaders in post-processing.
Note that values between 0 and 1 give an unrealistic metalness effect. They can be used creatively and for smooth transitions from a metal to a non-metal material on the same geometry. For more information on metalness and it's role when creating PRB shaders, visit Understanding Metalness.
Attributes
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.metalness.vrimg).
This render element is not supported with V-Ray GPU rendering.
