This page provides information about the V-Ray SphereFade Gizmo.
V-Ray SphereFade Gizmo is a volumetric node used to render just a small part of the scene by putting it in a special spherical locator.
UI Path: ||obj Network|| > Geometry node > V-Ray > V-Ray SphereFade Gizmo
Shape – Specifies the gizmo shape:
Sphere
Box
Cylinder
Radius – Controls the size of the gizmo shape.
Invert – Inverts the volume that is shaded, rendering the part of the scene that is outside the sphere.
Workflow
- Create a Geometry node with a V-Ray SphereFade Gizmo node inside.
- Enable the Sphere Fade effect from |out| > V-Ray Renderer ROP > Effects > Sphere Fade.
- Set the color and falloff of the sphere fade gizmo.
- Set the shape and the radius of the sphere fade gizmo.
Example: Invert
The Invert can be turned on to only show everything visible in the scene outside of the Sphere fade volume. In the example shown below, a Falloff value of 0.1 has been used.
