Build 6.00.21
Official Release
Date - Dec. 13, 2022
New features
V-Ray
- Integrated the Chaos Cosmos asset library for Houdini 19 and up, under Windows
- Implemented the V-Ray Profiler
- Implemented the V-Ray Memory Tracker
- Added Adaptive Bucket Splitting
- Implemented the V-Ray Enmesh for render-time generation of patterns over a mesh surface
- Updated V-Ray IPR for better interactive feedback
Lights
- Added V-Ray Procedural Clouds in the Sun Light
- Added "Finite Dome" option to Dome Light
- V-Ray Light Cache is now available in IPR
- Added "Grouped Lights" option for Light Select AOV
- Added "Volumetric Contribution" control for Lights
- Added new "PRG Clear Sky" model for V-Ray Sun
- Added support for Location/Date/Time in V-Ray Sun
Volumes
- Added Volume Shader "Absorption Color" support
- Added Volume Shader "Phase Function" (anisotropic scattering) support
- Added support for Vector fields for the Volume Grid Shader
Materials
- Added Thin Film layer for V-Ray Material
- Added new random walk scattering "SSS" and "Volumetric" modes for V-Ray Material Translucency
- Added Coat and Sheen layers for V-Ray Material
Textures
- Now shipping the "MakeTX" utility with V-Ray for Houdini
- Implemented V-Ray Random VOP to generate a random value in the range of 0-1 based on an Float or Color input
- Curvature texture can now work either in "Convex" or "Concave" mode
- Added input sockets for arbitrary "rest" attributes for the TriPlanar texture
AOV
- Added "Temporal Mode", "Hardware Acceleration" and "Denoise Alpha" options for the V-Ray Denoiser
VFB
- Added "Panorama View" and "Proportion Guides" option for the V-Ray Frame Buffer
Export
- Rest attributes for Alembics are read directly from the ABC file thus reducing export time
- Significant time to first pixel optimizations for Alembic and VDB caches
Workflow
- Implemented "Material Overrides" system for Objects under the V-Ray Renderer ROP
Solaris
V-Ray
- Add V-Ray support for Solaris Render Region Tool
- Add support for USDZ files
- Added Plate Workflow support through the V-Ray Environment settings on the Dome Light LOP
- Add texture tint/simple color correction controls for Dome and Rect lights
- Implemented LPE light tags support for lights in Solaris
- Add support for Motion blur based on velocity attribute
- Add support for integer PrimVars with User Integer VOP
- Add Deep Output support
- Add support for "constant" PrimVars in Cryptomatte
- Add Camera Overscan support
- Add support for writing Cryptomatte data though husk
- Add support for live volumes
- Add V-Ray Environment Fog
- Add Viewport Denoiser Result toggle
- Add support for MaterialX position and normal output via husk
- Add V-Ray Proxy support with V-Ray Proxy LOP
- Add support for native Houdini volumes
- Add "V-Ray Render Vars" LOP HDA similar to the Karma standard variables with presets for common AOVs
- Add Hair Properties in Geometry Render Settings LOP
- Add "Render as Disc" option for points in Geometry Render Settings LOP
- Add NSamples/Velocity support
- Add Bercon Noise support
- Add Deep Output support for VDBs
- Add support for Nested Instancing
- Add Visibility Settings for Volumes in Solaris
- Add Deep EXR options in Render Settings LOP
- GPU crash to desktop with instanced geometry
- Crash when the shader has wrong input connector type
- Combine texture causes a crash
- Crash when enabling and disabling the “instanceable” option of the Configure Primitive LOP
- Hydra delegate crash to desktop in CentOS
- Scene import (All) crashes in Python in Houdini 19.5
- Crash to desktop with new GeomInstancer plugin
- Meshlight causes "EXCEPTION IN CORE"
- Crash when toggling any of the Render Geometry Settings LOP options
- Light Linker not working
- Preview shader is rendered grayscale - Linux only
- Switching BRDFs inside the V-Ray Material Builder does not update the Viewport
- Randomizer VOP does not work
- Mismatch between Karma and V-Ray renders for points with “pscale”
- V-Ray skips point with index 0 when rendering points
- TexUserScalar does not work
- Opacity of V-Ray material is not working when color output of ImageFile VOP is used
- PrimVars/User Color on points is not rendered
- Invisible parameter state of lights is ignored when changing delegates
- Velocity blur for Volumes is not working
- Remap texture does not work in "Color" mode
- Impossible to select anything in the viewport when V-Ray is set as the Viewport Renderer
- Adding a dot in the shader graph breaks the shader
- Mesh Light Texture is not used or exported to the VRScene
- Expose "Max. MipMap Resolution" in the Render Settings LOP > Options > Textures
- Some parameters are not taken into account when saving Deep data
- Missing "Affect Reflections" toggle on V-Ray light properties
- Light material with "Direct Illumination" enabled does not update color changes in the Viewport
- Displacement isn't present in final render through husk
- Wrong default value export for "Preserve Map Borders" parameter when using subdivision
- Hair when "Use Embree" is disabled is missing from the final render through husk
- Chaining Switch VOPs does not work
- Memory leak with husk and specific scene
- LPE render var settings are not exported
- Change render var format to color3f for color elements in VRayStandardRenderVars LOP
- Image File VOP always uses "Inverse Gamma" as "Transfer Function"
- "Use" options for Environment settings from Dome Light for GI/Reflect/Refract/Secondary Matte are not considered
- Spotlight angle does not match Karma
- Spotlight softness affects only shadows but the light borders are always sharp
- Integer attributes are not supported
- Material Output VOP does not trigger an update in Houdini 19.0
- Missing vertex, face and normals lists for reference mesh when importing alembics with rest attributes
- Vector primvars are not picked up
- Render Settings LOP fails to load V-Ray UI due to ds file typo
- Different color mapping between render passes
- "Override Settings Globally" for Displacement is not working
- Displacement VOP parameter "Use Global Settings" is ignored
- Remap texture in "Float to Color" mode does not work with Blend material
- Geometry goes missing after switching delegate to V-Ray to Karma and back to V-Ray
- Viewport selection doesn't work
- Overscan is not saved in husk's output EXR
- V-Ray Remap node adds gamma shift
- Empty viewport/render after switching delegates
Modified features
Alembic
- Add support for SOP and OBJ level transform for Alembic primitives piped into a Mesh Light
- Add support for Object Properties "Geometry Samples" for per frame particle Alembics with multiple subsamples
Chaos Cosmos
- Ability to re-import the same model from Cosmos browser without using the same node
- Keep the last imported object's node selected
IPR
- Assigning a material to many objects while IPR is running is very slow and blocks the UI
- Update V-Ray Softbox texture changes in IPR
- Changes to geometry added as a gizmo for Fog effect causes the fog to disappear in IPR
- Isolate for IPR in Light Lister does not show its status and it is impossible to find isolated light in a big list of lights
- Add support for IPR Progressive spiral pattern similar to May and Max plugins
- Remove V-Ray IPR ROP node - only keep Renderer ROP node
- Export IPR "GI Depth" 16 bounces if V-Ray Material with Translucency mode SSS is present
- Decouple IPR updates for surface and shader so e.g. displacement shader is not updated when changing the surface shader
Lights
- Dome Light - hide Adaptivity parameter and enable Adaptive Dome by default
- Light Mix - add support for HDAs when the light parameters are exposed at the HDAs top level
- Light Mix - add "Name" parameter for Grouped lights mode
Materials
- Hide the Volume Shader "Scale Opacity by Scene Units" option under Smoke tab
- Disable "Compensate Energy" for Hair material by default
- Rename "Use Subdivision from Material" to "Use Displacement from Override Material"
- Pick Velocity Blur Multiplier fix for Volume Grid Shader for single vector fields
- Update V-Ray Material Translucency parameter names when Type is changed from "SSS" to "Volumetric"
- Set V-Ray Material Reflection and Refraction depth to default 8
- Hide "Multiply by Particle Age" toggle on the Foam shader
- Add support for VRScene material overrides with Rayserver Instancer and Pattern ID texture through "scene_name" shader override
- Support SOP level material assignment to volumes
- Extend shader import to support custom plugins
- Expose input texture slots for "depth" and "amount" parameters for V-Ray Material Translucency
- Add support for camera shaders to Physical Camera
- Add support for exclusion flag in Material Overrides object list
- Add support for bundles in Material Overrides object list
- MtlX Switch to V-Ray
Textures
- Rename new sky model to "PRG Clear Sky" from "Improved" to match V-Ray for Maya
- Missing import for Tex Float Correct
- Add UV mapping tab for V-Ray Procedural textures with some UVW presets
- Remove "Lighting" mode from Gradient Ramp texture
- The TriPlanar texture now has input slots for the "frame_offset" and "texture_rotation" parameters
OSL
- Changing OSL code wipes all parameter values
Volumes
- Update the Foam Shader UI
- Delete old Volume Shader ramps code
Rendering
- Expose "Minimum Shading Rate" parameter on the Renderer ROP
- Expose "Metalness" and "Roughness" render elements
- Add "Ignore Render Region" option under Renderer Export tab "Batch Render" section for VRScene export
- Export proper Foam Shader "Advanced" tab visibility options when particles are in ROP node "Phantom" list
- Set "oprelative" to "/obj" instead of "." for V-Ray Renderer ROP
- Add option to set Renderer's "RGB Color Space" based on an environment variable
- Add support for animated textures in the "Render Mask" option of the Renderer ROP
- Add Renderer ROP option for multiple shader overrides for multiple object sets based on the Pattern ID workflow
- Add a Render Settings Lights option to "Disable Light Visibility" with an operator list for specifying the lights to affect
- Export the smoke volume to VRScene even if rendering of smoke is disabled to ensure the transform is inherited from the smoke field
- Match default render settings with V-Ray for Maya and 3dsMax
V-Ray
- Forbid loading of VDBs in the Volume Grid Cache SOP
- Update Image File VOP defaults in V-Ray 5.2
- 2D displacement per primitive needs to be supported by V-Ray.
- Add support for Houdini 18.5.759
- Dirt "Consider Same Object Only" option produces different results when used with packed primitives vs mesh geometry
- Improve message for failing to find .vdb and writing raw data
- Change default image file filter to "Sharp MipMap" for Image File VOP
- Update Physical Camera Cinematic Shutter Offset/Angle default ranges
- Change "VRScans" name to the "Chaos Scans"
- Improve ACEScg workflow in V-Ray for Houdini
- Update "Max. MipMap Resolution" parameter range
- Reduce DWAA EXR compression RAM usage
- Update the "Back To Beauty (Advanced)" AOV preset to ensure proper results automatically
- Old scenes with physical camera show warning for missing parameters
- Update V-Ray Renderer ROP shape in the palette
Exporter
- Speed up export of instanced VDBs
- Add optional warning for exporting large live geometries on export
- Speed up VRScene export for instanced geometry
Installer
- Remove installer python logic in favor of Houdini's houdini_python keyword in packages
- Add method for accepting EULA when installing V-Ray with the ZIP builds
VFB
- Add support for VFB control through environment variables
Bug Fixes
IPR
- VFB2 isn't updating the V-Ray Log information
- Debug flag does not work when a VOP node inside a Material Builder is assigned to the geometry
- Animated Ocean Spectra Mask is not updated on frame change
- Exporting a VRScene in "Export" mode directly after running IPR causes empty standalone renders
- Renderer "Override Camera Resolution" option changes do not update IPR
- Referenced Shader changes do not update IPR
- Parameter changes for nodes inside Material Builder piped into Multi ID material do not affect IPR
- Material Override when using Distance Texture is lost when starting second IPR session
- Persistent updates or crash when changing a Volume Shader parameter assigned at the SOP level
- Render Region disappears on Production render or IPR start
- Material Overrides are lost when changing the Timeline frame during IPR when Extra Texture with the override object in its Exclude list is present
- Removing a Decal object from the SOP network does not affect IPR
- No updates for displacement assigned at the SOP level to Alembic primitives
- Renderer ROP Objects list does not update IPR
- Deleting objects or lights does not affect IPR
- V-Ray Proxy SOP is not updated in IPR
- Geometry goes missing during IPR if there are nodes that are linked to the camera transforms in the scene
- Lost ExtraTexture elements after the first one, on frame change, and if they have the same object in Exclude List
- Material assignments for Multi ID Material are lost when using an input Material Builder instead of BRDF
- Slowly generated mesh is not updated
- No update when enabling/disabling the ROP Material Override options
- Geometry that is hidden when IPR is started remains invisible even when unhidden during IPR
- Unnecessary refresh when changing folders on a BRDF node
- Renderer Camera settings do not update IPR
- Viewport does not update view changes
- Light Instancer not updated
- V-Ray Object Properties are not updated in GPU IPR
- Rendered objects would occasionally disappear when making changes to their geometry or adding additional objects to the scene
- Material assignments are ignored in for the entire scene if a debug flag is present on a VOP node
- Displacement per primitive not always updated in IPR
- "Render with Take" uses the correct take then refreshes and reverts to Main during IPR
- Toon Effect is updated in IPR only once
- Any changes done while IPR is running cause the Fog effect to disappear
- IPR update broken in 5.x for Light Instancer
- Velocity blur is not updated when changing "Shutter Speed" of Physical Camera
- Sun parameters do not update Sky texture for IPR when used in a Dome Light
- Hang if VFB IPR button is clicked multiple times before IPR starts
- Crash with partitioned alembic when using Motion Blur and Displacement
- Crash with Alembics using Displacement and Material AOVs
- Random crash during IPR or when attempting to start a production render
- Crash when toggling on/off the Mesh Light's "Use SOP Geometry" option
- Crash when changing the "Motion Blur Multiplayer" on the Volume Shader
- Setting "Screen Window Size" to negative during IPR crashes V-Ray and Houdini
- Crash when starting IPR first then Production Render if "Cache Bitmaps" is enabled
- Crash when disabling the V-Ray Physical Camera during IPR in "Render View" or Viewport
- Crash if starting a production render after an IPR session
Rendering
- OSL crash when redrawing UI after render
- Crash with Light Mix on render start
- Crash rendering groomed fur/hair with V-Ray
- Crash when attempting to render a volume without volume shader assigned to it
- Karma hangs on GUI sequence renders when V-Ray is installed
- Freeze on production render start with Rayserver Instancer and Displacement
- Crash if render is quickly started, stopped and started again multiple times
- "-imgFile" flag for standalone rendering causes double output
- VFB is brought to foreground on every frame when rendering a sequence, even when Houdini is minimized
- Wrong frame token exported when using $F4 tag for textures
- Per-primitive displacement does not render correctly
- Add support for vray_renderable packed attribute
- Texture for Dome light is not exported when using a referenced Image File VOP
- Geometry nodes in an Object network inside a parent Geometry node are rendered even when the parent Geometry node has visibility disabled
- Color AOV name expression is not evaluated for VFB
- Material Overrides do not work for more than one object in pattern list
- Forced hidden object with material override does not have material in render
- Overscan disables render region
- When using shader overrides with VRScene SOP the render becomes darker
- NUMA slowdown when rendering Alembics
- Double camera export when using a Switcher to change the render camera per frame
- VFB Render Region in viewport is not always rendered
- Render Region resizes unproportionally when Camera Resolution is increased
- "Visible in Refraction" causes wrong render output when a glossy material is present
- Baked volumes in VRScene produce empty renders in some frames
- Render Mask in "Object" mode does not work
- Physical Camera missing "specify_focus" export causes wrong DoF renders
GPU
- V-Ray Material Translucency parameters are grayed out for GPU but should not be anymore
- Wrong Light Linking export for GPU
- Matte Surface not working in GPU render for poly geometry
- Lighting discrepancy between CPU and GPU results when Direct light is used with Intensity higher than 1
- Square artifacts on using Adaptive Dome light on GPU
- CPU instead of RTX mode is started
- Image sequence as texture not rendered on GPU
- Attributes for shading with User Color and User Float do not work for Alembic hair and particles on the GPU
- Freeze with specific volume when using GPU
- Crash with a specific setup including V-Ray UV Explicit and BerconNoise
V-Ray
- In a newly created blank scene using certain python code provokes a crash
- Crash with Light Mix "To Scene" option when using lights that are not inside an HDA
- Crash in a specific scene with adaptive lights
- Crash on Python module load on Linux
- UDIM tag in the output image name is missing when baking a single UDIM tile
- Fixed an OCIO slowdown in 5.10.20
- Decal include and exclude lists work on single objects only - multiple objects are ignored
- Wrong filename output when using an expression sampling a point attribute with Python
- Add support for time-dependent values for image output file name and folder path
- State of "Enable Large Mesh Warning" toggle is not saved
- Camera motion blur not working with specific builds
- Difference in Ocean surface render compared to Mantra
- Empty export for "Exclude List" in Extra Texture AOV
- Wrong default values for OCIO texture
- Wrong output for Remap texture in "Value" to "Value" mode
- Object Properties SOP overrides own settings when chained in a Geometry network
- Wrong animated visibility output for objects
- Swapped logic for "Use Main Line Controls" toggle
- Set "Adaptive Dome" to enabled by default for Dome light
- Object Level transformations are ignored for Motion Blur when "Use Velocity Blur" is enabled
- Displacement does not accept negative "Amount" values
- Environment Fog does not work with specific builds
- "Geometry Samples" option for Motion Blur for Points has no effect
- Fixed issue causing truncated paths when over 255 characters are used on Linux
- Wrong output for Integer to Float texture
- Added support for per-face string attribute sampling with the PatternID texture
- Added support for V-Ray Scenes for Texture Baking
- Added support for Cryptomatte by attribute for crowds
- Wrong output for Multi ID Texture when using "Round to Integer" option
- Fixed Volume Grid Cache SOP is ignored by Renderer "Force Objects" list
- Fixed Python issue causing empty "About V-Ray" window
VFB
- Light Mix in "Manual" mode does not pick up Light Select elements
- Do not tint RGB channels when displaying them isolated
- ".cube" files specified in the OCIO config for the OCIO View Transform are not used
- Background layer does not work
- Using an EXR as Background image with "As Foreground" enabled causes the image to go black
Lights
- Light Lister "Isolate" button does not work
- Light Select wildcard "*" for lights parameter returns all scene nodes causing a slowdown with heavy geometry
- Light Mix - Dome Light "Intensity" and "Color" are not updated when inside a locked HDA
- Light Mix crash when attempting to send the changes "To Scene" if the lights are in a locked HDA
Materials
- Material Library download fails if the provided disk path does not exist
- Cryptomatte by material ID and material HDA
- Displacement is not overridden when using multiple Material Overrides on the Renderer ROP
- Parameters set with textures for OSL Material are ignored
- Wrong material assignments when using animated Switch node and uploading to Chaos Cloud
- Enabling Motion Blur breaks Material Overrides
- Add support for Null VOP for Referenced Shader
- Unlocked Depth and Scale Max value for V-Ray Material Translucency
- Lag in V-Ray Material Builder VOP context when opening the nodes menu with Tab or RMB click
- Add support for pattern based material overrides on the Renderer ROP through Pattern ID texture
- Disabling "Primary Visibility" for object with Light material does not work
- ROP's "Disable Light Materials" does not affect Light materials with Direct Illumination enabled
- Material Override is applied to Mesh Light when using wildcard flag for selection
- Enmesh material ignores custom attributes
- Crash with material overrides enabled when a light is present in the scene and using a wildcard flag
- Hang during Light Cache step when using Decal, Rect Light and Diffuse BRDF
- Crash with HDA holding Volume Grid Shader VOPs made in 4.3 when loading the HDA in V-Ray 5 builds
Textures
- Import of Remap texture selects "color" output regardless of what input it is connected to
- Empty drop-down for OCIO tab in Image File VOP
- OCIO node is missing input texture slot
- Distance Texture Objects list is empty when a Subnetwork is specified
- Some TriPlanar texture options do not work
- Image File VOP "Transfer Function" parameter is ignored
- Distance Texture ignores animated transform of target object
- Update User Float and User Integer default attribute names
- Wrong gamma applied to textures in Dome light when using ACES
- Very small triangles are ignored when Texture Baking which causes artifacts
- Adding an object to the Distance Texture "Exclude List" will disable its visibility globally
OSL
- Particular texture file UI is not loaded
- Warnings printed with specific scene with OSL
Alembic
- Expression including frames and subframes on Alembics isn't working as expected with V-Ray Core 5.10.20
- TriPlanar swimming coordinates when using "rest" attributes with Alembic file
- Double motion blur for Mesh lights using Alembic as source geometry
- Material Overrides do not work for multiple Alembic objects
- Poor Cryptomatte element sampling over overlapping multimaterial Alembic when using Depth of Field
- Triangular artifacts on packed Alembic when texture Filtering type is not set to None or Nearest
- Primitive attributes are ignored for splines/hair
- Add support for velocity sampling even when using single-file deforming Alembics
- Primitive hair attributes are not interpolated correctly for Alembics
- Shading artifacts with Random VOP when using float attribute in Alembic file
Volumes
- Possible crash when shader for volume is not a Volume material
- Immediate crash when Denoiser and Volume material with the Volumetric Z-Depth parameter set to 'Separate V-Ray Element' is added on volumes
- Crash when try to convert particular VDB with the V-Ray VDB to AUR node
- Immediate crash when importing big “.aur” files in V-Ray Volume Grid Cache
Instancing
- Orientation of instances calculated from @N or @N + @up vectors is wrong
- Invalid velocity handling for Rayserver Instancer when using Motion Blur
- Shadow artifacts with Rayserver Instancer
- Crash with SSS and multiple instances when using new instancing plugin
- Crash with Light Instancer with scene containing 250 000 lights
Exporter
- Remove file exists check when exporting packed disk primitive volume by path to speed up VRScene export
- Slow VRScene export time for instances with Motion Blur
- Slow export of animated cached VDBs
- Very slow export and high memory usage for Mesh Light using deforming alembic as source geometry
- Wrong export for frame($F2) token in texture path
- Channel string reference for VRScene Export path on Renderer ROP with frame token causes wrong export
- VRScene export for per frame Alembic files with time offset is not animated
- Export Mesh Lights generated by Light Material with "Direct Illumination" enabled to Light Select element
- No VRScene export for animated objects after first frame when Motion Blur is Enabled
- Empty plugin export for Extra Texture element
- Empty parameters export for Distance Texture - only Objects list is exported
- Empty export for Renderer Image Sampler parameters
- Float to Color is always exported, even when the float output is connected to a float input
- Light Instancer is not exported when texture baking
- Distance Texture object is not exported if part of an Override Material
- Wrong Displacement export for "Vector Displacement" assigned through Material SOP at the SOP level
- VRScene export - missing material AOVs with Alembics and Motion Blur when Offset is 0 and Duration is 1
- Only first frame is exported to VRScene for animated objects in Distance Texture list if their visibility is disabled
- Reflect/Refract mask are exported incorrectly
- Crash if you use VRScene Shader Overrides without typing Scene Name
- Material Overrides are lost for VRScene export after the first frame
- "Clip Mesh" parameter for V-Ray Clipper is not exported
- No export for Image File OCIO tab
- Animated shader parameters are not exported for static meshes
- Proxy Export not working in latest nightly builds
- VRScene export for Mesh Lights with Alembics only uses the first frame of the sequence
- Issues with Proxy export and particles
- Multi-valued params are not exported
- Light Textures - frame ($F) token is exported in the file path instead of evaluating the expression
- Wrong export for Image File VOP into Layered texture causes no color output
- Wrong UV set export for Image File VOP when exporting a .vrscene
- When Mapping of Procedural textures is set to UV, parameters are not exported to .vrscene
- Object Scale for V-Rya Enmesh is always exported as 1.0
- Multiple plugin exports when generating per frame VRScene files
- Crash on last alembic frame export when motion blur is enabled and using per-frame alembic files
VRayScene
- Incorrect import of Remap Texture from a VRScene file exported from Maya
- Incorrect import of volumeNoise (3D noise) from a VRScene file exported from Maya
- VRScene "Unpack to Polygons" does nothing if a node named "vrayscene_unpack" is already present in the same SOP network
- VRScene "Unpack to Polygons" does not create a material network
- Crash when importing materials from .vrscene
Installer
- Issues with silent installation + config.xml
- Houdini 19.x can't open local help when V-Ray is installed due to QT lib errors
Chaos Cosmos
- Update the packing script to ignore the missing Cosmos files
- Cosmos Browser window does not store position
- Assets import is creating overlapping nodes
- Models are imported mirrored by X axis
OSX
- Crash on start with Houdini 19.5.303
UI
- Removed Hair Properties *Use Global Hair Tree" controls
- Displacement Properties shelf tool does not work
- Crash when clicking on the "Transfer Function" menu of the Image File VOP in Houdini 19.5
