This page provides information about the V-Ray tab in V-Ray Render Settings.
The core of how V-Ray determines how to render your Cinema 4D scenes can be found within the VRay tab of the Render Settings window. Some basic information on each rollout can be found below, but for more details, please see the dedicated pages for each section.
UI Path: ||Render Settings|| > V-Ray > V-Ray tab
Render Engine
V-Ray allows you to use both CPU and GPU hardware for renders through the Render Engine rollout.
V-Ray GPU Engine
When the engine is set to V-Ray GPU, a number of options are exposed in the rollout.
Engine – Allows you to choose between V-Ray and V-Ray GPU engines.
GPU Engine – Specifies which GPU platform to use for calculations - CUDA or RTX.
Rendering Devices – This button opens a window where you can specify which GPU devices to be used for rendering. See more information at Rendering with V-Ray GPU.
GPU Resize Textures –Determines how textures' resolution/size are handled to help optimize memory usage. The possible values are:
Full size textures – Textures are loaded at their original size.
Resize all textures – Adjusts the size of high-resolution textures to a smaller resolution to optimize render performance.
On-demand mipmapping – Instead of loading all the texture files at their default resolution (original or resized), V-Ray loads the textures as needed and automatically creates mip-map tiles for them (regardless of their texture type). As a result, the GPU memory consumption could be decreased; textures that are not visible are not loaded, and textures that are further away from the camera are loaded with a lower resolution. During the texture-detection process, V-Ray GPU renders slower. Once it detects that all textures are loaded, it switches automatically to the traditional, faster mode, and a message about modes changing displays in the V-Ray log. This option is not available in Interactive Rendering Mode.
GPU Texture Size – When GPU Resize textures is enabled, this value specifies the resolution to which the textures are resized.
GPU Texture Format – The amount of bits per channel used to store the material texture information into memory. You can choose between 8 bit, 16 bit and 32 bit. This does not affect textures used for lights and displacement.
Out of Core (WIP) – Enables an experimental feature for evicting triangle meshes out of the GPU memory when they are no longer needed in order to make room for other resources, once the renderer has run out of memory.
When Out-of-core (WIP) is enabled, V-Ray GPU will exclude the C++/CPU device from rendering by design.
Image Sampler
Overall image sampling - Raytrace renders, like V-Ray, shoot rays out from the camera to sample what is found in the scene to help determine what color each pixel will be in a rendered image. The settings used to adjust how V-Ray does this, and the relationship between pixels in the render can be found on the Image Sampler (Anti-Aliasing) page.
Region rendering - When V-Ray uses a non-progressive image sampler, the rendered image is broken up into small pieces, also known as buckets, to help calculate and complete the image faster. The settings used to adjust these buckets can be found within the Render Region Division section.
Color Mapping
A camera in the real world uses exposure controls to determine how it handles the brightest and darkest parts of a captured image. Similarly, V-Ray uses Color Mapping to help translate the information collected by the sample rays into usable pixels we see within our rendered image. For more details on how to control the way V-Ray maps these values, please see the Color Mapping page.
Color Management
The Color Management rollout allows you to switch between the sRGB and ACEScg color spaces. For further details, see the Color Management page.
