This page provides information about the Render Parameters rollout in the Settings tab of the V-Ray Asset Editor.
Render Parameters rollout of the Settings tab exposes several options that control the Progressive or Bucket image samplers. You can also select an Antialiasing Filter and find a number of Optimization settings here. Note that the exposed controls vary depending on the combination of selections between CPU/GPU, Interactive/Production, and Progressive/Bucket options. Changing the Quality preset from the Render rollout sets a number of options with appropriate values for the selected preset. Generally, the Quality presets work for a wide variety of scenes and you do not need to adjust the settings any further.
Quality
The Quality settings are only available when the Interactive Renderer is turned off. The Shading Rate option is not available when using the GPU engine.
Noise Limit – Specifies the acceptable level of noise/grain in the rendered image. The smaller the number, the higher the quality (less noisy) the image is.
Time Limit (minutes) – Specifies the maximum render time in minutes. When this number of minutes is reached, the renderer stops. This is the render time for the whole frame; it includes any GI prepasses like light cache, irradiance map, etc. If this is 0.0, the render is not limited in time.
Bucket Size – Determines the bucket (render region division) size, measured in pixels. Buckets rendered by NVidia GPU devices are always produced with a minimum size of 32 pixels.
Min Subdivs – Determines the initial (minimum) number of samples taken for each pixel. This value rarely needs to be higher than 1, except in the case of very thin lines or fast-moving objects combined with motion blur. The actual number of samples taken is the square of this number. For instance, a value of 4 subdivisions produces 16 samples per pixel.
Max Subdivs – Determines the maximum number of samples taken for a pixel. The actual number of samples taken is the square of this number. For instance, a value of 4 subdivisions produces 16 samples per pixel. Note that V-Ray may take less than the maximum number of samples if the difference in intensity of the neighboring pixels is small enough.
Shading Rate – Controls how many rays is used for calculating shading effects (e.g. glossy reflections, GI, area shadows, etc) instead of anti-aliasing. Higher values mean that less time is spent on anti-aliasing, and more effort is put in the sampling of shading effects.
Interactive Off and Progressive On Advanced UI
Interactive Off and Progressive Off Advanced UI
Interactive Parameters
Allow Interactive LC – Allows Light Cache secondary GI engine to be used during interactive rendering. When disabled, BF is automatically selected as both a primary and secondary engine in interactive sessions.
Interactivity – Controls the number of rays that are traced for each pixel during one image pass.
Antialiasing Filter
Antialiasing Filter – Enables or disables anti-aliasing.
Size / Type – Controls the strength of the anti-aliasing filter and the type of anti-aliasing filter to use. See the Antialiasing Filter example below.
Color Management
The Color Management rollout allows you to switch between sRGB and ACEScg workflow.
The ACEScg is a linear color working space that specifies a wider gamut of colors than the sRGB linear gamut. It allows for a greater range of colors transformations in post as its gamut envelopes not only sRGB, but also P3, Rec709, and Rec2020. Archived assets in ACEScg do not need to be remastered in case the displays standards are improved in future.
RGB primaries – Selects a display color space for the rendered image. The selected mode is saved as metadata to vrimg. The color space used in the render also affects how the rendered image is displayed in VFB when the default Display correction sRGB is set in VFB.
sRGB – Image is rendered in sRGB color space. This is the color space for most monitors and computer displays.
ACEScg – Image is rendered in ACEScg color space. This color space allows for greater range of color transformations in post. It has a wider gamut of colors than the sRGB linear gamut and should be encoded into a 16 bit floating exr.
Subpixel Clamp – Specifies the clamping level for the color components.
Highlight Burn – Selectively applies exposure corrections to highlights in the image. The Highlight Burn parameter in the VFB can be used for non-destructive color edits instead.
Note that changing the value leads to render elements that can't be composited together to produce the RGB/Beauty image. This is the reason why we recommend that the parameter is set to 1.
ACES is the Academy Color Encoding System and developed by the Academy of Motion Picture Arts and Sciences. ACEScg is the version of the ACES encoding system for computer graphics, widely adopted in the industry. It has become the industry standard, because compared to sRGB, ACEScg works with a lot more color information, illustrated in this gamut graph.
To see ACEScg setup in V-Ray for SketchUp, expand below.
Optimizations
Some of the options are different when the Render Engine is set to GPU.
Adaptive Lights – Number of lights from the scene that are evaluated by V-Ray when the Adaptive Lights option is enabled. Lower values make the rendering go faster, but the result is potentially noisier. Higher values cause more lights to be computed at each hit point, thus producing less noise but increasing render times.
When enabled, V-Ray chooses at random the specified number of lights and evaluates only those for the rendering, thus speeding up render time. This option can introduce a visible degree of additional noise, but it makes it possible to render images that would otherwise take a very long time.
Max Trace Depth – Overrides globally the reflection and refraction depth (number of ray bounces/refractions). When this is disabled, the depth is controlled locally by the materials/maps. When enabled, all materials and maps use the depth specified here. If GPU is the render engine, it limits the reflection and refraction trace depth.
Opacity Depth – Controls to what depth transparent objects are traced.
Max Ray Intensity – Specifies the level to which all secondary rays are clamped.
Secondary Ray Bias – A small positive offset that is applied to all secondary rays; this can be used if you have overlapping faces in the scene to avoid the black splotches that may appear.
Blue Noise Sampling – Enables an optimization that in the general case leads to better noise distribution with fewer samples.
Embree – Enables the Intel Embree raycaster. Note: The Embree raycaster derives its speed from the usage of single-precision floating-point numbers, whereas the standard V-Ray raycaster selectively uses double precision. This lower precision of Embree may lead to artifacts in some scenes with very large extents.
Conserve Memory – Embree uses a more compact method for storing triangles, which might be slightly slower but reduces memory usage.
Switches
The Switches in this rollout have a global effect over the whole scene.
Displacement – Enables (default) or disables V-Ray's displacement mapping. Note that SketchUp's displacement feature is supported.
Lights – Enables lights globally. Note that if disabled, V-Ray only uses Global Illumination to light the scene.
Hidden Lights – Enables or disables the usage of hidden lights. When this is enabled, lights are rendered regardless of whether they are hidden or not. When this option is off, any lights that are hidden for any reason (either explicitly or by type) is not included in the rendering.
Shadows – Enables or disables shadows globally.
V-Ray GPU
This rollout is available only when the Render Engine is set to CUDA or RTX.
Out of Core (WIP) – Enables an experimental feature for evicting triangle meshes out of the GPU memory when they are no longer needed in order to make room for other resources, once the GPU device(s) has run out of memory. This option is available only for CUDA and is not yet supported for RTX.
Texture Mode – Determines how textures size is handled offering several options to optimize their memory load.
Full-size textures – Textures are loaded at their original size.
Resize textures – Limits the size of textures to a specified resolution reducing only those above the limit
Composed textures – all textures are loaded with the compression to decrease their consumption without decreasing in size
On-demand mipmapping – Mip-map tiles are generated for each texture so they can be loaded at lower resolution the further away they are from the camera. Mipmapped textures that are not visible are not loaded.
Texture Size – Specifies the resolution to which textures are resized when Resize is set to Resize textures.
Bit Depth – Specifies the resolution and bit depth to which the texture is resized.
The GPU Textures mode does not affect textures attached to the V-Ray Dome Light and Environment Background and Overrides.
