This page describes how to set up your local system so that it loads the files for the correct V-Ray version.
Since V-Ray 6, update 1 the Portable installation replaces the .zip builds. See the Portable installation page for more.
« Previous Version 12 Current »
Installing V-Ray for Cinema 4D from a .zip file provides the advantage of easy setup and flexible folder management.
When installing V-Ray for Cinema 4D from a .zip file, note that Chaos Cosmos is not included by default in the installation. To add it, you can separately download and install it.
Note also that the EULA is not automatically accepted when installing from a .zip file. A window pops up, when V-Ray is first initiated in Cinema, which prompts you to accept the End User License Agreement.
Paste it to the Maxon's plugins folder.
For Windows, by default, it is located in C:\Program Files\Maxon Cinema 4D Rxx\plugins.
For macOS, by default, it is located in /Aplications/Maxon Cinema 4D RXX/plugins.
If you already have an existing V-Ray folder there, replace it with the one from the archive.
