DR Mode RenderingOnce V-Ray Swarm is installed on all machines, the cluster is set up, and an origin node is configured with a valid Chaos account login, you are ready to initiate distributed rendering sessions from any node within the V-Ray Swarm network. When V-Ray Swarm is successfully installed, all machines are visible in the Network tab with a green dot next to them. Note that when distributed rendering is initiated for the first time, all render nodes need to download a compatible V-Ray build that matches the version installed on the machine used for the submission. This process takes a moment but only occurs once for each specific V-Ray version.
