Emit Mode | ifnotsolid – Specifies the way the objects in the Emitter Nodes emit fluid. Surface Force – The surface of the emitters will eject the selected fluid channels along the geometry normals. In this mode, the discharge is named Outgoing Velocity and it specifies the speed of the emitted fluid in units/sec. The displayed units will change accordingly if the scene units change. This mode can work with both Solid and non-Solid emitters. If you use a Mask for the discharge in Surface Force mode, white areas of the emitter's surface will eject fast fluid, while darker ones would emit more slowly. Black areas will not emit at all. Volume Brush – The fluid inside the volume of the emitters will gradually change towards the selected channel values. When this mode is selected, the discharge is named Brush Effect (%) and it specifies the rate at which the transition takes place. When Brush Effect is 100%, the fluid will immediately reach the selected channel values, and if Brush Effect is less, it specifies how close the fluid values will get to the values from the Source over 1 second. E.g. if the Temperature inside an emitter's volume is 1000 and the Source emits Temperature 2000 with Brush Effect of 80%, then after 1 second the temperature will have risen to 1800. Note that the Volume Brush mode can both increase or decrease the fluid values, for example if the Smoke in the Source is set to 0.5, the Source would increase the smoke in voxels that have 0.0 smoke until it reaches 0.5, but will decrease the smoke in voxels having 1.0 smoke, again - until it reaches 0.5. This mode is useful for creating standing volumes of fluid with a high Brush Effect, or alternatively - to slowly convert the fluid inside the volume of the emitters to the values selected below over a period of time. Note that you can both increase or decrease the values of the fluid channels in Volume Brush mode. When Brush Effect (%) is 0, then the Source has no effect. This mode requires that all selected emitters are set into non-Solid mode from their Per-Node Properties. If you use a Mask for the discharge in Volume Brush mode, white zones in the volume will have the Brush Effect you have specified, while darker zones will use a smaller Brush Effect. Completely back zones in the mask would not be affected at all by this Source. Volume Inject – The volume of the emitters will discharge the selected fluid channels with added pressure. When this mode is selected, the discharge is named Inject Power and it specifies the added volume of the injected fluid per second. This mode is useful for getting explosive discharge. Inject Power can be negative, in which case the Source will suck in and delete the fluid. This mode requires that all selected emitters are set into non-Solid mode from their Per-Node Properties. If you use a Mask for the discharge in Volume Inject mode, white zones in the volume will have the Inject Power you have specified, while darker zones will use a smaller Inject Power. Completely back zones in the mask would not be affected at all by this Source. When emitting from particles in any of the 'Sphere' Prt Shape modes, the Surface Force Emit Mode is not supported - Phoenix will automatically fall back to Volume Inject mode. Only Use Particle Shape supports all 3 emit modes. |
