This page provides details on the render settings used to adjust the V-Ray renderer.
In order to use V-Ray, you must first select one of its renderers as your current renderer.
Older scenes saved with ActiveShade mode can still be opened in V-Ray in order to convert them to Production Rendering Mode. |
V-Ray parameters are under several tabs in the Render Setup window. Additionally, each tab is divided into several rollouts.
In V-Ray, the two tools that most greatly impact the balance of render quality vs. speed are the image sampler (under the V-Ray tab) and GI engine(s) (under the GI tab). Learning the basics of how these two features work will greatly enhance your ability to adjust settings in V-Ray and maximize image quality while keeping render times to a minimum. See the linked pages for explanations on how these features work. |
