The parameters for this render element appear in the Attribute Editor under Extra V-Ray Attributes. Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer. Deep output – Specifies whether to include this render element in deep images. Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.rawRefraction.vrimg). Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. |
