This page gives some basic details about the Raw Total Lighting Render Element and explains how it is used in compositing.
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Atmosphere
This render element is not supported with V-Ray GPU rendering. |
The Raw Total Lighting Render Element is useful for changing the appearance of the entire lighting of the scene after rendering, using a compositing or image editing application. Below are a couple of examples of possible uses. The first two images show the render element itself and the Beauty render put together. The Raw Total Lighting Render Element was brightened and tinted differently to show the range of editing possible.
Raw Total Lighting x Diffuse = Total Lighting
Raw Lighting + Raw GI = Total Lighting
