When you drag-n-drop a a .vrscene or a .vrmesh file in Chaos Vantage, you are presented with a pop-up menu with the following options: Merge/Place filtering – Filter setting for the drag-n-dropped .vrscene or .vrmesh. Cameras – When enabled, imports the cameras from the drag-n-dropped .vrscene. Geometry – When enabled, imports the geometry from the drag-n-dropped .vrscene or .vrmesh file. Lights – When enabled, imports the lights from the drag-n-dropped .vrscene. Materials – When enabled, imports the materials from the drag-n-dropped .vrscene. Scene options – Additional options for the merged/placed scene. Loop animation – When enabled, loops the imported animated .vrscene from the start. Useful in cases where the timeline length is longer than the animation length. You can disable it again by going into the Preferences menu. Do not ask again – When enabled, stores the currently enabled options and the type of action (Open/Place/Merge) and executes it the next time a .vrscene or .vrmesh file is drag-n-dropped. You can enable this pop-up again by going into the Preferences menu.
Open – Opens the drag-n-dropped .vrscene or .vrmesh. This entirely overrides the currently opened scene. For more details, check Opening Scene Files. Place – Merges the drag-n-dropped .vrscene or .vrmesh at the drop position and align it to the surface normals. For more details, check Place Scene. Merge – Merges drag-n-dropped .vrscene or .vrmesh at the scene origin. For more details, check Merge Scene. Cancel – Cancels the merging process. |
