This page provides information on the Coat Filter Render Element.
Applying the Coat Filter RE and the Raw Coat Reflection RE to the composition in Multiply blend mode produces Coat Reflection RE. This method is used to allow for better fine-tuning of the coat reflections in the scene.
You can enhance the coat reflections of your composition by applying the Coat Filter RE and the Raw Coat Reflection RE in Add blend mode inside the VFB. In this example, the effect is applied only in areas selected with a Cryptomatte mask. See how the composition changes after the enhancement.
