The Source Property Panel allows you to view custom layers in .exr and .vrimg files.
UI Path: ||Property Panel|| > Source panel
Different layers of an EXR file
The following image shows a composition in which a multi-channel EXR file with render elements has been split into layers and composited additively into back-to-beauty. On the left we can see the original RGB beauty layer. The image on the right is composited using the Add operator for the render elements. It is clearly visible that the two images look the same. However using render elements allows for much more control when applying color corrections for example.
Open EXR with Render Elements
Chaos Player will recognize versioned footage when the file path contains a directory with a name of the form prefix_v#_suffix, where prefix and suffix are arbitrary strings, and # is a sequence of digits. The prefix_ and _suffix parts are optional. Examples of versioned directory names: v2, V004, v04_before_cc, animation_v05, scene_v2_2009_05_31.The version string is automatically replaced in the file name, if present.
Examples of versioned footage:
D:\shot08\scene_15\v02\bg\bg_v02_0001.exr D:\shot08\scene_15\v03\bg\bg_v03_0001.exr |
C:\projects\promo\v2_before_cc\0001.exr C:\projects\promo\v3_after_cc\0001.exr |
X:\Footage\conv\V002_2009_05_27\conv_proxy.exr X:\Footage\conv\V003_2009_05_31\conv_proxy.exr |
D:\shot08\scene15_v2\bg\shot08_scene15_v2_bg_0001.exr D:\shot08\scene15_v3\bg\shot08_scene15_v3_bg_0001.exr |
C:\projects\promo_v2_before_cc\v2_0001.exr C:\projects\promo_v3_after_cc\v3_0001.exr |
X:\Footage\conv\V002_2009_05_27\conv_V002_proxy.exr X:\Footage\conv\V003_2009_05_31\conv_V003_proxy.exr |
