Name – The text added to the end of the rendered file, when saved as a separate file. Deep Output – Specifies whether to include this render channel in deep images. Color Mapping – Applies the color mapping options specified in the Color mapping tab of the V-Ray Renderer to this render element. Consider for AA – When enabled, antialiasing will be considered where possible. Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler panel of the Sampler tab of the V-Ray Renderer node. Denoise – Enables the render element's denoising, provided the Denoiser render element is added. Invert Color – Flips the black and white colors. |
