VRay SDK for C++
Helper class that wraps a plugin instance enabling a certain render element. More...
#include <vraysdk.hpp>
Classes | |
| struct | GetDataOptions |
| Controls what the buffer returned by getData() contains. More... | |
| struct | Info |
| This structure is used to return information about a particular channel in the VFB. More... | |
Public Member Functions | |
| RenderElement () | |
| Default construct an invalid object. | |
| BinaryFormat | getBinaryFormat () const |
| Get the binary format of pixels in this render element. | |
| size_t | getData (void **data, const GetDataOptions &options) const |
| size_t | getDataIntoBuffer (const GetDataOptions &options, void *data) const |
| PixelFormat | getDefaultPixelFormat () const |
| Get the default format used by the getData method for this render element. | |
| VRayImage * | getImage (const GetImageOptions &options, int layerIndex=0) const |
| VRayImage * | getImage (const ImageRegion *rgn=nullptr, int layerIndex=0) const |
| std::string | getMetadata () const |
| Get render element metadata. Currently works only for Cryptomatte render element and returns manifest and metadata. | |
| std::string | getName () const |
| Get the display name of this render element. | |
| Plugin | getPlugin () const |
| Get the plugin instance in the scene that enables this render element. Might be invalid for special channels like EffectsResult. | |
| Type | getType () const |
| Get the type of the render element. | |
| operator bool () const | |
Static Public Member Functions | |
| static void | releaseData (void *data) |
| Call this to release data allocated by the getData method. | |
Friends | |
| class | RenderElements |
Render channel binary format / storage data type.
| Enumerator | |
| DI_INTENT_DISPLAY | The data will be shown on a display, so we want color corrections to be applied. |
| DI_INTENT_FILE | The data will be saved in a file, so we don't want color corrections applied. |
| DI_INTENT_RAW | We don't want any processing on the data. The major difference to IntentFile is in the way Vector and Vector2 color buffers are treated. In this intent mode, Vector and Vector2 buffers are stored directly, but in IntentFile mode their components are divided by 2 and then they are offset by 0.5. |
| DI_INTENT_FILE_NO_COLOR_CORRECTIONS | Image will be saved with no color corrections. The flag is introduced because IntentDisplay, IntentFile and IntentRaw are used to determine "colorCorrectionMode" parameter value when calling ColCor::Correct in VRRegionData::getChannelPixels. This way every color correction has to determine manually check "colorCorrectionMode" and many color corrections just ignore it. |
| DI_INTENT_FILE_SRGB | Same as IntentFile, but with forced sRGB/Gamma correction. |
| DI_INTENT_VIEWPORT_IPR | Image will be displayed in viewport, color corrections should be applied with the exception of sRGB and Gamma22. |
This describes the desired data format for getData().
The render channal types/aliases are used to identify some common channels.
| Enumerator | |
| NONE | Unspecified channel. |
| AUTO | Not an actual channel, used by e.g. setProgressiveImageUpdatedDataType() |
| ATMOSPHERE | Atmospheric effects channel. |
| DIFFUSE | Diffuse filter VFB channel. This channel is generated by V-Ray. |
| REFLECT | Reflection VFB channel. This channel must be generated by shaders. |
| REFRACT | Refraction VFB channel. This channel must be generated by shaders. |
| SELFILLUM | Self-illumination VFB channel. This channel must be generated by shaders. |
| SHADOW | Shadow VFB channel. This channel is generated by V-Ray. |
| SPECULAR | Specular VFB channel. This channel is generated by V-Ray. |
| LIGHTING | Lighting VFB channel. This channel is generated by V-Ray. |
| GI | GI VFB channel. This channel is generated by V-Ray. |
| CAUSTICS | Caustics VFB channel. This channel is generated by V-Ray. |
| RAWGI | Raw GI VFB channel. This channel is generated by V-Ray. |
| RAWLIGHT | Raw light VFB channel. This channel is generated by V-Ray. |
| RAWSHADOW | Raw shadow VFB channel. This channel is generated by V-Ray. |
| VELOCITY | Velocity VFB channel. This channel is generated by V-Ray. |
| RENDERID | Render ID VFB channel. This channel is generated by V-Ray. |
| MTLID | Mtl ID VFB channel. This channel is generated by V-Ray. |
| NODEID | Node ID VFB channel. This channel is generated by V-Ray. |
| ZDEPTH | Z-Depth VFB channel. This channel is generated by V-Ray. |
| REFLECTION_FILTER | Reflection filter VFB channel. This channel must be generated by shaders. |
| RAW_REFLECTION | Raw reflection VFB channel. This channel must be generated by shaders. |
| REFRACTION_FILTER | Refraction filter VFB channel. This channel must be generated by shaders. |
| RAW_REFRACTION | Raw refraction VFB channel. This channel must be generated by shaders. |
| REALCOLOR | Real color VFB channel. |
| NORMALS | Normals VFB channel. This channel is generated by V-Ray. |
| BACKGROUND | Background VFB channel. This channel is generated by V-Ray. |
| ALPHA | Alpha VFB channel. This is always created by V-Ray and there can't be multiple instances. It's easier to use getImage() for Alpha. |
| COLOR | RGB VFB channel. This is always created by V-Ray and there can't be multiple instances. It's easier to use getImage() for RGB. |
| WIRECOLOR | Wire color channel where each object appears with a solid color. This channel is generated by V-Ray. |
| MATTESHADOW | Matte shadow channel where full shadows are white and areas not in shadow are black; essentially this is (rawShadow)/(rawLight+rawShadow). This channel is generated by V-Ray. |
| TOTALLIGHT | The total diffuse lighting (direct+indirect) falling on a surface. This channel is generated by V-Ray. |
| RAWTOTALLIGHT | The raw total diffuse lighting (direct+indirect) falling on a surface. This channel is generated by V-Ray. |
| BUMPNORMALS | The normals modified with bump map. This channel must be generated by shaders. |
| SAMPLERATE | The sample rate for the image samplers. |
| SSS | A channel used for VRayFastSSS2 material sub-surface portion. |
| DRBUCKET | A channel that keeps track of which DR server rendered a particular bucket (it is a Color buffer that stores server name strings prerendered, as text, white on black) |
| VRMTL_REFLECTGLOSS | A VRayMtl reflection glossiness VFB channel. This channel is generated by V-Ray. |
| VRMTL_REFLECTHIGLOSS | A VRayMtl reflection hilight glossiness VFB channel. This channel is generated by V-Ray. |
| VRMTL_REFRACTGLOSS | A VRayMtl reflection glossiness VFB channel. This channel is generated by V-Ray. |
| SHADEMAP_EXPORT | A channel that keeps the fragment coordinates in camera space. |
| REFLECT_ALPHA | Used by matte materials to store the alpha of the reflections. |
| VRMTL_REFLECTIOR | A VRayMtl reflection IOR VFB channel. This channel is generated by V-Ray. |
| MTLRENDERID | Mtl render ID VFB channel. This channel is generated by V-Ray. |
| NOISE_LEVEL | The noise level as estimated by the Adaptive and Progressive image samplers. Used for denoising purposes. |
| WORLD_POSITION | The position in world space. Used for denoising purposes. |
| DENOISED | A denoised version of the image. Adding this render element enables denoising. |
| WORLD_BUMPNORMAL | Normal with bump mapping in world space. |
| DEFOCUS_AMOUNT | Pixel blur, combination of DOF and moblur. Used for denoising purposes. |
| EFFECTS_RESULT | Channel for all post effects. |
| TOON | Toon effect channel. |
| RENDERTIME | Per-pixel render time. |
| CRYPTOMATTE | Used for Cryptomatte render channel output. |
| LIGHTING_ANALYSIS | The lighting analysis overlay. |
| LIGHT_SELECT | Link this in the channels parameters of your lights. |
| VRMTL_METALNESS | VRayMtl metalness parameter. |
| LIGHT_MIX | Channel for Interactive Light Mix. |
| TOON_LIGHTING | Direct toon diffuse lighting. |
| TOON_SPECULAR | Direct toon specular lighting. |
| VRMTL_SHEEN_COLOR | VRayMtl sheen color parameter (sheen filter uninfluenced by Fresnel weight, reflection and refraction color). |
| RAW_SHEEN_REFLECTION | Raw sheen indirect reflection VFB channel. |
| SHEEN_FILTER | Sheen filter VFB channel. |
| VRMTL_SHEEN_GLOSSINESS | VRayMtl sheen glossiness parameter. |
| SHEEN_REFL_ALPHA | Used by matte materials to store the alpha of the sheen reflections. |
| COAT_REFL_ALPHA | Used by matte materials to store the alpha of the coat reflections. |
| VRMTL_COAT_COLOR | VRayMtl coat highlight color (coat filter uninfluenced by Fresnel weight, reflection and refraction color). |
| RAW_COAT_REFLECTION | Raw coat indirect reflection VFB channel. |
| COAT_FILTER | Coat filter VFB channel. |
| VRMTL_COAT_GLOSSINESS | VRayMtl coat glossiness parameter. |
| SHEEN_REFLECTION | Sheen indirect reflection VFB channel. |
| LAST | not a type, just a delimiter |
| USER | User defined channel indices start from here. |
| COVERAGE | Pixel coverage. |
| MATERIAL_SELECT | Material select. |
| MULTIMATTE | RGB matte for up to 3 objects. |
| MULTIMATTE_ID | RGB matte using material IDs. |
| OBJECT_SELECT | Selects by object/material ID. |
| EXTRA_TEX | A single texture override is applied to the whole scene (e.g. Dirt) |
| EXTRA_TEX_INT | A single texture override is applied to the whole scene (e.g. Dirt) |
| EXTRA_TEX_FLOAT | A single texture override is applied to the whole scene (e.g. Dirt) |
| size_t VRay::RenderElement::getData | ( | void ** | data, |
| const GetDataOptions & | options | ||
| ) | const |
Retrieves the render element raw data. The returned memory buffer must be freed with releaseData(data)! WARNING: If Nvidia AI upscaling is enabled, then the returned image/data will have even dimentions.
| [out] | data | a pointer to a void pointer which will receive the address of the raw data buffer. Free it with releaseData() when done. |
| size_t VRay::RenderElement::getDataIntoBuffer | ( | const GetDataOptions & | options, |
| void * | data | ||
| ) | const |
Retrieves the render element raw data into the buffer. WARNING: If Nvidia AI upscaling is enabled, then the returned image/data will have even dimentions.
| options | Image options (crop, color correct, etc.). |
| buf | The output data buffer. If nullptr - returns required buffer size. |
| VRayImage * VRay::RenderElement::getImage | ( | const GetImageOptions & | options, |
| int | layerIndex = 0 |
| ) | const |
Allocate a new copy of the channel data as a VRayImage instance WARNING: If Nvidia AI upscaling is enabled, then the returned image/data will have even dimentions.
| options | Use to modify behavior compared to getImage(void) - crop, color correct, etc. |
| layerIndex | For multi-layer elements only. The Cryptomatte layer index (between 0 and num_level/2). For ObjectSelect value 1=filter layer and 2=alpha layer. |
| VRayImage * VRay::RenderElement::getImage | ( | const ImageRegion * | rgn = nullptr, |
| ) | const |
| rgn | an optional image region rectange; nullptr means the whole image. |
inline |
Check if there is a valid plugin representing this render element in the scene. If false, creation failed. Exception: COLOR, ALPHA and EFFECTS_RESULT will return false as they are implicit (without a corresponding instance), but they can still be used with getImage/getData. EFFECTS_RESULT may fail getImage/getData if there are no post effects.
