VRay SDK for C++
Loading...
Searching...
No Matches
VRay::VRayImage Struct Reference
#include <vraysdk.hpp>
Classes
struct  DrawToBitmapParams
Public Types
enum  DrawMode : int { DRAW_MODE_COPY = 0 , DRAW_MODE_BLEND_FAST }
enum  IntList_DataType {
  bgra_byte = 0 , rgba_float = 1 , rgba_16bit = 3 , bgr_byte = 4 ,
  rgba_float16 = 5
 These correspond to (some of) the values of RawBitmapBuffer::pixels_type. More...
enum  WhiteBalanceMode { WHITE_BALANCE_NONE , WHITE_BALANCE_AVERAGE , WHITE_BALANCE_WEIGHTED_AVERAGE , WHITE_BALANCE_HIGHLIGHTS }
Public Member Functions
bool addColor (const AColor &color)
bool addColor (const Color &color)
float calculateDifference (const VRayImage *image) const
AColor calculateWhiteBalanceMultiplier (WhiteBalanceMode mode) const
 Returns a color multiplier to pass to mulColor function.
bool changeContrast (float contrast)
bool changeExposure (float ev)
bool changeGamma (float gamma)
bool changeSRGB (bool apply=true)
VRayImage * clone () const
Bmp * compressToBmp (bool preserveAlpha=false, bool swapChannels=false) const
 Returns a new BMP object with a copy of this image's contents. Caller has to delete it.
Bmp * compressToBmp (const VRayRenderer &renderer, bool preserveAlpha=false, bool swapChannels=false) const
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
Bmp * compressToBmp (size_t &size, bool preserveAlpha=false, bool swapChannels=false) const
Bmp * compressToBmp (size_t &size, const VRayRenderer &renderer, bool preserveAlpha=false, bool swapChannels=false) const
Jpeg * compressToJpeg (const VRayRenderer &renderer, int quality=0) const
Jpeg * compressToJpeg (int quality=0) const
 Returns a new JPEG object with a compressed copy of this image's contents. Caller has to delete it.
Jpeg * compressToJpeg (size_t &size, const VRayRenderer &renderer, int quality=0) const
Jpeg * compressToJpeg (size_t &size, int quality=0) const
Png * compressToPng (bool preserveAlpha=false) const
 Returns a new PNG object with a compressed copy of this image's contents. Caller has to delete it.
Png * compressToPng (const VRayRenderer &renderer, bool preserveAlpha=false) const
Png * compressToPng (size_t &size, bool preserveAlpha=false) const
Png * compressToPng (size_t &size, const VRayRenderer &renderer, bool preserveAlpha=false) const
bool draw (const VRayImage *image, int x, int y, DrawMode mode=DRAW_MODE_COPY)
size_t drawToBitmap (const DrawToBitmapParams &params) const
VRayImage * getCropped (int x, int y, int width, int height) const
 Returns a new cropped image. Caller has to delete it.
VRayImage * getCutIn (int width, int height) const
VRayImage * getDownscaled (int width, int height) const
VRayImage * getDownscaledCropped (int srcX, int srcY, int srcWidth, int srcHeight, int dstWidth, int dstHeight) const
VRayImage * getFitIn (int width, int height) const
VRayImage * getFitOut (int width, int height) const
float getGamma () const
int getHeight () const
AColor * getPixelData ()
 Returns a direct pointer to the image contents for in-place modification.
const AColor * getPixelData () const
 Returns a direct pointer to the image contents for reading.
AColor * getPixelData (size_t &count)
const AColor * getPixelData (size_t &count) const
VRayImage * getResized (int width, int height) const
 Returns a new resized/rescaled image. Caller has to delete it.
VRayImage * getResizedCropped (int srcX, int srcY, int srcWidth, int srcHeight, int dstWidth, int dstHeight) const
 Returns a new cropped and then resized/rescaled image. Caller has to delete it.
bool getSize (int &width, int &height) const
int getWidth () const
bool makeNegative ()
bool mulColor (const AColor &color)
bool saveToBmp (const char *fileName, bool preserveAlpha=false, bool swapChannels=false) const
bool saveToBmp (const char *fileName, const VRayRenderer &renderer, bool preserveAlpha=false, bool swapChannels=false) const
bool saveToBmp (const std::string &fileName, bool preserveAlpha=false, bool swapChannels=false) const
bool saveToBmp (const std::string &fileName, const VRayRenderer &renderer, bool preserveAlpha=false, bool swapChannels=false) const
bool saveToExr (const char *fileName) const
bool saveToExr (const char *fileName, const VRayRenderer &renderer) const
bool saveToExr (const std::string &fileName) const
bool saveToExr (const std::string &fileName, const VRayRenderer &renderer) const
bool saveToJpeg (const char *fileName, const VRayRenderer &renderer, int quality=0) const
bool saveToJpeg (const char *fileName, int quality=0) const
bool saveToJpeg (const std::string &fileName, const VRayRenderer &renderer, int quality=0) const
bool saveToJpeg (const std::string &fileName, int quality=0) const
bool saveToPng (const char *fileName, bool preserveAlpha=false, int bitsPerChannel=8) const
bool saveToPng (const char *fileName, const VRayRenderer &renderer, bool preserveAlpha=false, int bitsPerChannel=8) const
bool saveToPng (const std::string &fileName, bool preserveAlpha=false, int bitsPerChannel=8) const
bool saveToPng (const std::string &fileName, const VRayRenderer &renderer, bool preserveAlpha=false, int bitsPerChannel=8) const
bool saveToTiff (const char *fileName, const VRayRenderer &renderer, int bitsPerChannel=16) const
bool saveToTiff (const char *fileName, int bitsPerChannel=16) const
bool saveToTiff (const std::string &fileName, const VRayRenderer &renderer, int bitsPerChannel=16) const
bool saveToTiff (const std::string &fileName, int bitsPerChannel=16) const
bool setGamma (float gamma)
MemoryBuffer * toBitmapData (size_t &size, bool preserveAlpha=false, bool swapChannels=false, bool reverseY=false, int stride=0, int alphaValue=-1) const
IntList toIntList (IntList_DataType type) const
Static Public Member Functions
static VRayImage * create (int width, int height)
static VRayImage * createFromBmp (const void *buffer, size_t size=0)
 Takes raw BMP contents including header to create a copy of the data in a new VRayImage.
static VRayImage * createFromBmp (const VRayRenderer &renderer, const void *buffer, size_t size=0)
static VRayImage * createFromIntList (const IntList &buffer, IntList_DataType dataType, int width, int height)
static VRayImage * createFromJpeg (const void *buffer, size_t size)
 Takes raw JPEG contents including header to create a copy of the data in a new VRayImage.
static VRayImage * createFromJpeg (const VRayRenderer &renderer, const void *buffer, size_t size)
static VRayImage * createFromPng (const void *buffer, size_t size)
 Takes raw PNG contents including header to create a copy of the data in a new VRayImage.
static VRayImage * createFromPng (const VRayRenderer &renderer, const void *buffer, size_t size)
static VRayImage * createFromRawData (const void *buffer, size_t size, IntList_DataType dataType, int width, int height)
 Takes raw pixel contents to create a copy of the data in a new VRayImage.
static VRayImage * load (const char *fileName)
static VRayImage * load (const std::string &fileName)
static void loadSize (const char *fileName, int &width, int &height)
static void loadSize (const std::string &fileName, int &width, int &height)
static void operator delete (void *bmp)
static void operator delete[] (void *)=delete
static void * operator new (size_t)=delete
static void * operator new[] (size_t)=delete
Detailed Description
Image helper class containing raw full float32 data that can export to 8-bit formats - BMP, JPEG, PNG. It also supplies some basic image manipulation methods.
Member Enumeration Documentation
◆ DrawMode
Enumerator
DRAW_MODE_COPY
Overwrite destination image pixels with the source image pixels.
Alpha-blend using only the source image alpha but keep the original destination image alpha unchanged.
◆ IntList_DataType
Enumerator
rgba_float
8-bit int BGRA
rgba_16bit
32-bit float RGBA (sRGB or gamma won't be applied automatically)
bgr_byte
16-bit unsigned int RGBA
rgba_float16
8-bit int BGR
Member Function Documentation
◆ calculateDifference()
float VRay::VRayImage::calculateDifference ( const VRayImage *  image) const
Fast difference approximation between 2 images. You can start with a difference threshold of around 2.0 as a rough estimate and then fine-tune the value. If the images have different sizes, FLT_MAX is returned.
◆ changeGamma()
bool VRay::VRayImage::changeGamma ( float  gamma)
Applies a power curve to pixel values. Note that this is a color correction, not a color space conversion. Output color space conversion is applied automatically according to the value of the gamma property (see setGamma/getGamma) when saving or compressing the image.
◆ changeSRGB()
bool VRay::VRayImage::changeSRGB ( bool  apply = true)
Applies or removes an sRGB correction curve to/from this image. Note that this changes the underlying float data values and it is NOT needed when saving or compressing to 8 or 16-bit formats. Output color space conversion is applied automatically according to the value of the gamma property (see setGamma/getGamma) when saving or compressing the image (sRGB if gamma = 2.2 or any arbitrary gamma).
applytrue - apply sRGB, false - remove sRGB.
◆ createFromIntList()
static VRayImage * VRay::VRayImage::createFromIntList ( const IntList &  buffer,
int  width,
int  height
static
Takes raw pixel contents from IntList to create a new VRayImage from it. buffer can be taken directly from RawBitmapBuffer::pixels_type
◆ draw()
bool VRay::VRayImage::draw ( const VRayImage *  image,
int  x,
int  y,
DrawMode  mode = DRAW_MODE_COPY
Draws the passed image over the current one at the specified position and using the specified drawing mode. If any parts of the source lie outside the current image rectangle, they get cropped.
◆ drawToBitmap()
size_t VRay::VRayImage::drawToBitmap ( const DrawToBitmapParams &  params) const
Extracts 8-bit bitmap data from this image draws it to a pre-allocated bitmap / memory buffer.
DrawToBitmapParamsparams
Returns
The count of the written image bytes. On error, 0 is returned.
◆ getCutIn()
VRayImage * VRay::VRayImage::getCutIn ( int  width,
int  height
) const
Returns a new resized and eventually cropped image with exactly width x height size. Caller has to delete it. Note: The result is similar to chained getFitOut(width, height) and getCropped() calls.
◆ getDownscaled()
VRayImage * VRay::VRayImage::getDownscaled ( int  width,
int  height
) const
Returns a new downscaled image. Caller has to delete it. Note: getResized() can both downscale and upscale.
◆ getDownscaledCropped()
VRayImage * VRay::VRayImage::getDownscaledCropped ( int  srcX,
int  srcY,
int  srcWidth,
int  srcHeight,
int  dstWidth,
int  dstHeight
) const
Returns a new cropped and then downscaled image. Caller has to delete it. Note: getResizedCropped() can both downscale and upscale.
◆ getFitIn()
VRayImage * VRay::VRayImage::getFitIn ( int  width,
int  height
) const
Returns a new resized image that can fit and touch inside a width x height rectangle, preserving the original aspect ratio. Caller has to delete it.
◆ getFitOut()
VRayImage * VRay::VRayImage::getFitOut ( int  width,
int  height
) const
Returns a new resized image so that a width x height rectangle can fit inside it, and the new image touches the rectangle outside, preserving the original aspect ratio. Caller has to delete it.
◆ getGamma()
float VRay::VRayImage::getGamma ( ) const
Gets the gamma used when converting this image to 8-bit image formats. This gamma value is used by methods like compressToBmp(), compressToJpeg(), etc.
◆ load()
static VRayImage * VRay::VRayImage::load ( const char *  fileName)
static
Creates a new VRayImage from a file Supported formats: png, jpg, bmp, exr, hdr, sgi/rgb/rgba, pic, tiff, tga, psd, dds
◆ loadSize()
static void VRay::VRayImage::loadSize ( const char *  fileName,
int &  width,
int &  height
static
Helper method to get image size from a file. Supported formats: png, jpg, bmp, exr, hdr, sgi/rgb/rgba, pic, tiff, tga, psd, dds
◆ setGamma()
bool VRay::VRayImage::setGamma ( float  gamma)
Sets 8-bit images output gamma. This doesn't change the underlying float data but affects the output of methods like compressToBmp(), compressToJpeg(), etc.
◆ toBitmapData()
MemoryBuffer * VRay::VRayImage::toBitmapData ( size_t &  size,
bool  preserveAlpha = false,
bool  swapChannels = false,
bool  reverseY = false,
int  stride = 0,
int  alphaValue = -1
) const
Extracts 8-bit bitmap data from this image (without the BMP headers that compressToBmp includes). The data is a copy from this image and the caller is responsible for deleting it. Defaults to channel order BGR, no alpha, top-bottom.
size[out] The size of the returned buffer in bytes.
preserveAlpha[in] false - BGR/RGB (bytes_per_pixel = 3), true - BGRA/RGBA (bytes_per_pixel = 4).
swapChannels[in] false - BGR(A) order, true - RGB(A) order.
reverseY[in] false - fill top-bottom bitmap, true - fill bottom-top bitmap.
stride[in] the byte offset between the beginning of two consecutive rows of the output bitmap. if (stride > 0) use max(stride, width*bytes_per_pixel). if (stride== 0) use width*bytes_per_pixel rounded up to the smallest factor of 4 (this the default for BMP). if (stride < 0) use width*bytes_per_pixel rounded up to the smallest factor of -stride; -stride must be a power of 2.
alphaValueForce the alpha channel to the given value in the [0, 255] range. Forces BGRA/RGBA format. -1 means do not force.
Returns
A pointer to the BMP pixel data. On error, nullptr is returned and size == 0.
The documentation for this struct was generated from the following file:
