VRay SDK for C++
Loading...
Searching...
No Matches
VRay::VRayRenderer Class Reference
#include <vraysdk.hpp>
Classes
struct  UserCameraChanged
struct  UserLightChanged
struct  UserNodeChanged
struct  UserPropertyChanged
 Definition of one changed property for LiveLink scene updates. More...
class  VFB
 This class groups all VFB related methods. More...
struct  VRayProfiler
Public Types
enum class  DebugShadingMode : int {
  isolateSelect , globalLighting , globalAO , globalWireframe ,
  globalNormal , globalUV , globalBarycentric
 Enum with the different debug shading modes. More...
typedef void * InstanceHandleType
enum  RenderMode {
  RENDER_MODE_PRODUCTION = -1 , RENDER_MODE_INTERACTIVE = 0 , RENDER_MODE_INTERACTIVE_CUDA = 4 , RENDER_MODE_INTERACTIVE_OPTIX = 7 ,
  RENDER_MODE_INTERACTIVE_METAL = 8 , RENDER_MODE_INTERACTIVE_METALRT = 9 , RENDER_MODE_PRODUCTION_CUDA = 104 , RENDER_MODE_PRODUCTION_OPTIX = 107 ,
  RENDER_MODE_PRODUCTION_METAL = 108 , RENDER_MODE_PRODUCTION_METALRT = 109
enum  UserPropertyType {
  UPType_int = 0 , UPType_bool = 1 , UPType_double = 2 , UPType_float = 3 ,
  UPType_string = 4 , UPType_vector = 5 , UPType_color = 6
 Property types for UserPropertyChanged.
enum  UserSceneManipType { USMType_Transform_Set = 0 , USMType_Show = 1 , USMType_Hide = 2 }
enum  UserSceneNodeObjectType { USNOType_Node = 0 , USNOType_Camera = 1 , USNOType_Light = 2 }
enum class  VFBSourceButton : int { Default = 0 , InteractiveRendering = 1 , Maximum }
enum class  WaitTime : int { AwaitingOrIdle = -1 , Idle = -2 }
 Used with waitForRenderEnd() More...
Public Member Functions
 VRayRenderer ()
 VRayRenderer (const RendererOptions &rendererOptions)
 VRayRenderer (InstanceHandleType handle)
 ~VRayRenderer ()
 Destructor.
void abort () const
 Flags the image rendering thread to abort and returns immediately (without waiting for it to join)
AddHostsResult addHosts (const char *hosts) const
AddHostsResult addHosts (const std::string &hosts) const
 This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
bool addVRayProfilerMetadata (const char *category, const char *key, const char *value)
bool addVRayProfilerMetadata (const std::string &category, const std::string &key, const std::string &value)
int append (const char *fileName, bool drSendNameOnly=false)
int append (const std::string &fileName, bool drSendNameOnly=false)
int append (const std::vector< const char * > &fileNames)
int append (const std::vector< std::string > &fileNames)
int appendAsText (const char *text)
template<typename T = void>
int appendAsText (const char *text, size_t length, void(*freeFn)(char *text, size_t size, T *holderObject)=nullptr, T *holderObject=nullptr)
int appendAsText (const std::string &text)
int appendAsText (const std::vector< const char * > &sceneTexts)
int appendAsText (const std::vector< std::string > &sceneTexts)
int appendAsText (std::string &&text)
int appendAsTextFiltered (const char *fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
template<class T , bool(T::*)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *) TMethod>
int appendAsTextFiltered (const char *fileName, T &obj, const void *userData=nullptr)
int appendAsTextFiltered (const std::string &fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendAsTextFiltered (const std::string &fileName, T &obj, const void *userData=nullptr)
int appendAsTextFiltered (const std::vector< const char * > &sceneTexts, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendAsTextFiltered (const std::vector< const char * > &sceneTexts, T &obj, const void *userData=nullptr)
int appendAsTextFiltered (const std::vector< std::string > &sceneTexts, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendAsTextFiltered (const std::vector< std::string > &sceneTexts, T &obj, const void *userData=nullptr)
int appendFiltered (const char *fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendFiltered (const char *fileName, T &obj, const void *userData=nullptr)
int appendFiltered (const std::string &fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendFiltered (const std::string &fileName, T &obj, const void *userData=nullptr)
int appendFiltered (const std::vector< const char * > &fileNames, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendFiltered (const std::vector< const char * > &fileNames, T &obj, const void *userData=nullptr)
int appendFiltered (const std::vector< std::string > &fileNames, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int appendFiltered (const std::vector< std::string > &fileNames, T &obj, const void *userData=nullptr)
void bucketRenderNearest (int x, int y) const
bool clearAllPropertyValuesUpToTime (double time)
 Removes all keyframe values at times less than 'time'.
void clearLastError ()
 Clears the last error code.
bool clearPropertyValuesUpToTime (double time, PluginCategories categories)
 Removes all keyframe values at times less than 'time' only from plugins of given categories.
bool clearScene ()
 Wipes the scene contents (all plugin instances). This implicitly calls stop() if necessary.
unsigned long long commit (bool force=false)
void continueSequence () const
 When rendering a sequence this starts the next frame after the previous one has completed. It does not continue automatically.
bool deletePlugin (const char *pluginName)
bool deletePlugin (const Plugin &plugin)
bool deletePlugin (const std::string &pluginName)
bool deletePlugins (const char *names[], size_t namesCount)
bool deletePlugins (const std::vector< std::string > &names)
bool deletePlugins (const std::vector< VRay::Plugin > &plugins)
template<class T , void(T::*)(VRayRenderer &, VRayImage *, void *) TMethod>
bool denoiseNow (T &object, bool shouldPassImage=true, const void *userData=nullptr)
bool denoiseNow (void(*userCb)(VRayRenderer &, VRayImage *, void *)=0, bool shouldPassImage=true, const void *userData=nullptr)
bool disableDRClient ()
bool enableDRClient (const EnableDRClientParams &enableParams)
bool enableLiveLinkClient (const LiveLinkClientParameters &params)
int exportScene (const char *filePath) const
int exportScene (const char *filePath, const VRayExportSettings &settings) const
int exportScene (const std::string &filePath) const
int exportScene (const std::string &filePath, const VRayExportSettings &settings) const
std::string exportSceneToBuffer () const
std::string exportSceneToBuffer (const VRayExportSettings &settings) const
std::string getActiveHosts () const
std::string getAllHosts () const
std::vector< std::string > getAllPluginTypes () const
 Returns the class names of all available V-Ray plugin classes loaded from dynamic libraries.
bool getAutoCommit () const
 Get the current state of the autoCommit flag.
AutoExposureResult getAutoExposureResult () const
 Returns the auto-exposure and auto-white balance values computed during the last light cache calculation.
Box getBoundingBox () const
 Returns the current bounding box of the scene.
Box getBoundingBox (bool &ok) const
bool getBucketReadyHasBuffer () const
 Gets if an image will be passed in the BucketReady callback parameters.
Plugin getCamera () const
 Gets the current camera plugin. Don't use this unless you need to use setCamera() - see the comments on setCamera.
const char * getCameraName () const
 Gets the camera name override previously set by setCameraName().
size_t getCausticsSize () const
unsigned long long getChangeIndex () const
std::vector< ComputeDeviceInfo > getComputeDevicesCUDA () const
std::vector< ComputeDeviceInfo > getComputeDevicesCurrentEngine () const
std::vector< ComputeDeviceInfo > getComputeDevicesDenoiser () const
std::vector< ComputeDeviceInfo > getComputeDevicesMetal () const
std::vector< ComputeDeviceInfo > getComputeDevicesMetalRT () const
std::vector< ComputeDeviceInfo > getComputeDevicesOptix () const
bool getCropRegion (int &srcWidth, int &srcHeight, float &rgnLeft, float &rgnTop, float &rgnWidth, float &rgnHeight) const
 Gets the virtual crop region (RgnLeft, RgnTop, RgnWidth, RgnHeigt) within a virtual source image space with sizes SrcWidth, SrcHeight.
double getCurrentEventTime () const
 Get the current value (in seconds) of the relative time used in event callbacks.
int getCurrentFrame () const
double getCurrentTime () const
bool getDREnabled () const
float getIESPrescribedIntensity (const char *iesLightFileName) const
float getIESPrescribedIntensity (const std::string &iesLightFileName) const
VRayImage * getImage () const
VRayImage * getImage (const GetImageOptions &options) const
size_t getImageIntoBuffer (const GetImageOptions &options, void *buf) const
bool getImageSize (int &width, int &height) const
 Returns the frame buffer width and height.
std::string getInactiveHosts () const
bool getInProcess () const
InstanceHandleType getInstanceHandle () const
template<class T >
T getInstanceOf () const
Plugin getInstanceOf (const char *pluginType) const
Plugin getInstanceOf (const std::string &pluginType) const
Plugin getInstanceOf (PluginTypeId pluginTypeId) const
template<class T >
T getInstanceOrCreate ()
template<class T >
T getInstanceOrCreate (const char *pluginName)
Plugin getInstanceOrCreate (const char *pluginName, const char *pluginType)
Plugin getInstanceOrCreate (const char *pluginName, const std::string &pluginType)
Plugin getInstanceOrCreate (const char *pluginName, PluginTypeId pluginTypeId)
Plugin getInstanceOrCreate (const char *pluginType)
template<class T >
T getInstanceOrCreate (const std::string &pluginName)
Plugin getInstanceOrCreate (const std::string &pluginName, const char *pluginType)
Plugin getInstanceOrCreate (const std::string &pluginName, const std::string &pluginType)
Plugin getInstanceOrCreate (const std::string &pluginName, PluginTypeId pluginTypeId)
Plugin getInstanceOrCreate (const std::string &pluginType)
Plugin getInstanceOrCreate (PluginTypeId pluginTypeId)
InteractiveStatistics getInteractiveStatistics () const
 Returns some performance statistics from the Interactive (RT) engine.
size_t getIrradianceMapSize () const
bool getKeepInteractiveRunning () const
 Get the current state of the keepInteractiveRunning flag.
Error getLastError () const
 Returns the last error that occurred when a method was called. Use this to understand why a method returned false.
ParserError getLastParserError () const
 Returns the parser error that occurred when a scene was last loaded or appended.
LicenseError getLicenseError () const
 Returns the license error (if any) that occurred when the renderer was constructed or when rendering was started.
size_t getLightCacheSize () const
int getNumThreads () const
 Return the number of threads that will be used for rendering. 0 means all CPU logical threads.
const RendererOptions getOptions () const
 Return the options used to construct this renderer.
template<class T >
T getOrCreatePlugin (const char *pluginName)
Plugin getOrCreatePlugin (const char *pluginName, const char *pluginType)
Plugin getOrCreatePlugin (const char *pluginName, const std::string &pluginType)
Plugin getOrCreatePlugin (const char *pluginName, PluginTypeId pluginTypeId)
template<class T >
T getOrCreatePlugin (const std::string &pluginName)
Plugin getOrCreatePlugin (const std::string &pluginName, const char *pluginType)
Plugin getOrCreatePlugin (const std::string &pluginName, const std::string &pluginType)
Plugin getOrCreatePlugin (const std::string &pluginName, PluginTypeId pluginTypeId)
size_t getPhotonMapSize () const
Plugin getPlugin (const char *pluginName) const
template<class T >
T getPlugin (const char *pluginName) const
Plugin getPlugin (const std::string &pluginName) const
template<class T >
T getPlugin (const std::string &pluginName) const
PluginMeta getPluginMeta (const char *pluginClassName) const
 Return static meta information about a given plugin type.
PluginMeta getPluginMeta (const PluginTypeId pluginTypeId) const
PluginMeta getPluginMeta (const std::string &pluginClassName) const
std::vector< Plugin > getPlugins () const
 Returns all plugin instances in the current scene.
template<class T , class RetT = T>
std::vector< RetT > getPlugins () const
std::vector< Plugin > getPlugins (const char *pluginClassName) const
std::vector< Plugin > getPlugins (const std::string &pluginClassName) const
std::vector< Plugin > getPluginsOfCategories (const PluginCategories &categories) const
 Returns all plugin instances that belong to all passed categories.
std::vector< Plugin > getPluginsOfCategories (const std::vector< PluginCategories > &categories) const
std::vector< Plugin > getPluginsOfCategory (PluginCategory category) const
 Returns all plugin instances that belong to the passed category.
std::vector< std::string > getPluginTypesOfCategories (const std::vector< PluginCategories > &categories) const
std::vector< std::string > getPluginTypesOfCategories (PluginCategories categories) const
std::vector< std::string > getPluginTypesOfCategory (PluginCategory category) const
bool getProgresiveImageUpdatedHasBuffer () const
bool getProgressiveImageUpdatedHasBuffer () const
 Gets if an image will be passed in the ProgressiveImageUpdated callback parameters.
RenderElements getRenderElements ()
 Returns an object that groups render element management methods.
RenderMode getRenderMode () const
 Get the current render mode.
bool getRenderRegion (int &rgnLeft, int &rgnTop, int &rgnWidth, int &rgnHeight) const
bool getRenderSizes (RenderSizeParams &sizes, bool &regionButtonState) const
RendererState getState () const
bool getUseAnimatedValuesState () const
 Returns true if setting parameter values adds keyframes and false if it overwrites.
std::string getUserSceneName ()
bool getVFBContextMenuItemValue (int commandId, int &value) const
bool getVisualDebuggerEnabled () const
 Returns whether the Visual Debugger is enabled.
bool isAborted () const
bool isDRClientEnabled () const
bool isFrameSkipped () const
bool isRenderEnded () const
bool isRenderingInHalfResolution () const
bool isSequenceEnded () const
int load (const char *fileName)
int load (const std::string &fileName)
int loadAsText (const char *text)
int loadAsText (const char *text, size_t length, void(*freeFn)(char *text, size_t size, T *holderObject)=nullptr, T *holderObject=nullptr)
int loadAsText (const std::string &text)
int loadAsText (std::string &&text)
int loadAsTextFiltered (const char *fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int loadAsTextFiltered (const char *fileName, T &obj, const void *userData=nullptr)
int loadAsTextFiltered (const std::string &fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int loadAsTextFiltered (const std::string &fileName, T &obj, const void *userData=nullptr)
int loadFiltered (const char *fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int loadFiltered (const char *fileName, T &obj, const void *userData=nullptr)
int loadFiltered (const std::string &fileName, bool(*callback)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *), const void *userData=nullptr)
int loadFiltered (const std::string &fileName, T &obj, const void *userData=nullptr)
void lockScene ()
template<class T >
T newPlugin ()
template<class T >
T newPlugin (const char *pluginName)
Plugin newPlugin (const char *pluginName, const char *pluginType)
Plugin newPlugin (const char *pluginName, const std::string &pluginType)
Plugin newPlugin (const char *pluginName, PluginTypeId pluginTypeId)
Plugin newPlugin (const char *pluginType)
template<class T >
T newPlugin (const std::string &pluginName)
Plugin newPlugin (const std::string &pluginName, const char *pluginType)
Plugin newPlugin (const std::string &pluginName, const std::string &pluginType)
Plugin newPlugin (const std::string &pluginType)
Plugin newPlugin (PluginTypeId pluginTypeId)
 operator bool () const
bool operator! () const
bool optimizeMaterialGraph (const Plugin &topPlugin)
bool pause () const
Plugin pickPlugin (int x, int y) const
Plugin pickPlugin (int x, int y, int timeout) const
std::vector< PickedPluginInfo > pickPlugins (double x, double y, int maxcount=0, int timeout=-1) const
int removeHosts (const char *hosts) const
int removeHosts (const std::string &hosts) const
void renderSequence () const
 Begins rendering an animation sequence in a separate thread. A non-blocking call.
void renderSequence (SubSequenceDesc descriptions[], size_t count) const
bool replacePlugin (const Plugin &oldPlugin, const Plugin &newPlugin)
int resetHosts (const char *hosts=nullptr) const
int resetHosts (const std::string &hosts) const
bool resume () const
bool saveCausticsFile (const char *fileName)
bool saveCausticsFile (const std::string &fileName)
bool saveIrradianceMapFile (const char *fileName)
bool saveIrradianceMapFile (const std::string &fileName)
bool saveLightCacheFile (const char *fileName)
bool saveLightCacheFile (const std::string &fileName)
bool savePhotonMapFile (const char *fileName)
bool savePhotonMapFile (const std::string &fileName)
bool serializeScene ()
void setAutoCommit (bool autoCommit)
int setBitmapCache (bool onOff)
void setBucketReadyHasBuffer (bool hasBuffer)
 Sets if an image passed in the BucketReady event parameters is needed. If not, no unnecessary copies would be made.
bool setCamera (const Plugin &plugin)
void setCameraName (const char *name)
 Camera name override. Current camera is selected internally using the scene_name property of the camera plugins.
bool setComputeDevicesCUDA (const std::vector< int > &indices)
bool setComputeDevicesCurrentEngine (const std::vector< int > &indices)
bool setComputeDevicesDenoiser (const std::vector< int > &indices)
bool setComputeDevicesEnvironmentVariable ()
bool setComputeDevicesMetal (const std::vector< int > &indices)
bool setComputeDevicesMetalRT (const std::vector< int > &indices)
bool setComputeDevicesOptix (const std::vector< int > &indices)
bool setCropRegion (int srcWidth, int srcHeight, float rgnLeft, float rgnTop)
bool setCropRegion (int srcWidth, int srcHeight, float rgnLeft, float rgnTop, float rgnWidth, float rgnHeight)
bool setCurrentFrame (int frame)
bool setCurrentTime (double time)
void setDebugShadingSelection (const std::vector< Plugin > &selection)
void setDenoiserOptions (const DenoiserOptions &denoiserOptions)
bool setDREnabled (bool drEnabled, bool enableBroadcastListener=true)
bool setImageSize (int width, int height, bool resetCropRegion=true, bool resetRenderRegion=true)
bool setImprovedDefaultSettings (DefaultsPreset preset=quality_medium)
void setIncludePaths (const char *includePaths, bool overwrite=true)
void setIncludePaths (const std::string &includePaths, bool overwrite=true)
bool setInProcess (bool inProcess)
bool setInteractiveNoiseThreshold (float threshold)
bool setInteractiveSampleLevel (int samplesPerPixel)
bool setInteractiveTimeout (int timeoutMsec)
void setKeepBucketsInCallback (bool keep)
 This method allows you to change the default behavior of keeping an image copy in a BucketReady callback parameter.
void setKeepInteractiveRunning (bool keepRunning)
void setKeepProgressiveFramesInCallback (bool keep)
 This method allows you to change the default behavior of keeping an image copy in a progressiveImageUpdated callback parameter.
bool setNumThreads (int numThreads)
template<class T , void(T::*)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData) TMethod>
void setOnBucketFailed (T &object, const void *userData=nullptr)
void setOnBucketFailed (void(*callback)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData), const void *userData=nullptr)
void setOnBucketInit (T &object, const void *userData=nullptr)
void setOnBucketInit (void(*callback)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData), const void *userData=nullptr)
void setOnBucketReady (std::nullptr_t null)
template<class T , void(T::*)(VRayRenderer &, int x, int y, const char *host, VRayImage *img, ImagePassType pass, double instant, void *userData) TMethod>
void setOnBucketReady (T &object, const void *userData=nullptr)
void setOnBucketReady (void(&callback)(VRayRenderer &, int x, int y, const char *host, VRayImage *img, ImagePassType pass, double instant, void *userData), const void *userData=nullptr)
void setOnBucketReady (void(&callback)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, int imageLoaded, int enhanceSupported, double instant, void *userData) TMethod>
void setOnCollaborationImageChange (T &object, const void *userData=nullptr)
void setOnCollaborationImageChange (void(*callback)(VRayRenderer &, int imageLoaded, int enhanceSupported, double instant, void *userData), const void *userData=nullptr)
void setOnEnhanceOnCollaboration (int(*callback)(VRayRenderer &, const std::vector< std::string > &fileList, double instant, void *), const void *userData=nullptr)
template<class T , int(T::*)(VRayRenderer &, const std::vector< std::string > &fileList, double instant, void *userData) TMethod>
void setOnEnhanceOnCollaboration (T &object, const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, const char *hostName, double instant, void *userData) TMethod>
void setOnHostConnected (T &object, const void *userData=nullptr)
void setOnHostConnected (void(*callback)(VRayRenderer &, const char *hostName, double instant, void *userData), const void *userData=nullptr)
void setOnHostDisconnected (T &object, const void *userData=nullptr)
void setOnHostDisconnected (void(*callback)(VRayRenderer &, const char *hostName, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &renderer, const char *msg, int errorCode, LicenseUserStatus userStatus, double instant, void *userData) TMethod>
void setOnLicenseError (T &object, const void *userData=nullptr)
void setOnLicenseError (void(*callback)(VRayRenderer &, const char *msg, int errorCode, LicenseUserStatus userStatus, double instant, void *userData), const void *userData=nullptr)
void setOnLightMixTransferToScene (int(*callback)(VRayRenderer &, const std::vector< LightMixChange > &changes, double instant, void *), const void *userData=nullptr)
template<class T , int(T::*)(VRayRenderer &, const std::vector< LightMixChange > &lightMixChanges, double instant, void *userData) TMethod>
void setOnLightMixTransferToScene (T &object, const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &renderer, const char *msg, MessageLevel level, double instant, void *userData) TMethod>
void setOnLogMessage (T &object, MessageLevel minLevel=MessageInfo, const void *userData=nullptr)
void setOnLogMessage (void(*callback)(VRayRenderer &, const char *msg, MessageLevel level, double instant, void *userData), MessageLevel minLevel=MessageInfo, const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, double instant, void *userData) TMethod>
void setOnPostEffectsUpdated (T &object, const void *userData=nullptr)
void setOnPostEffectsUpdated (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, const char *msg, int elementNumber, int elementsCount, double instant, void *userData) TMethod>
void setOnProgress (T &object, const void *userData=nullptr)
void setOnProgress (void(*callback)(VRayRenderer &, const char *msg, int elementNumber, int elementsCount, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, VRayImage *img, unsigned long long changeIndex, ImagePassType pass, double instant, void *userData) TMethod>
void setOnProgressiveImageUpdated (T &object, const void *userData=nullptr)
void setOnProgressiveImageUpdated (void(*callback)(VRayRenderer &, VRayImage *img, unsigned long long changeIndex, ImagePassType pass, double instant, void *userData), const void *userData=nullptr)
void setOnRendererClose (T &object, const void *userData=nullptr)
void setOnRendererClose (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, const char *propName, double instant, void *userData) TMethod>
void setOnRenderViewChanged (T &object, const void *userData=nullptr)
void setOnRenderViewChanged (void(*callback)(VRayRenderer &, const char *propName, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, RendererState oldState, RendererState newState, double instant, void *userData) TMethod>
void setOnStateChanged (T &object, const void *userData=nullptr)
void setOnStateChanged (void(*callback)(VRayRenderer &, RendererState oldState, RendererState newState, double instant, void *), const void *userData=nullptr)
void setOnUploadToCollaboration (int(*callback)(VRayRenderer &, const std::vector< std::string > &fileList, double instant, void *), const void *userData=nullptr)
void setOnUploadToCollaboration (T &object, const void *userData=nullptr)
void setOnVFBAddRenderElementToScene (bool(*callback)(VRayRenderer &, VFBRenderElementType type, double instant, void *userData), const void *userData=nullptr)
template<class T , bool(T::*)(VRayRenderer &, VFBRenderElementType type, double instant, void *userData) TMethod>
void setOnVFBAddRenderElementToScene (T &object, const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, int itemId, VFBSourceButton sourceButton, void *userData) TMethod>
void setOnVFBCameraSelection (T &object, const void *userData=nullptr)
void setOnVFBCameraSelection (void(*callback)(VRayRenderer &renderer, int itemId, VFBSourceButton sourceButton, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, VFBMouseButton button, int x, int y, bool ctrl, bool shift, void *userData) TMethod>
void setOnVFBClick (T &object, const void *userData=nullptr)
void setOnVFBClick (void(*callback)(VRayRenderer &, VFBMouseButton button, int x, int y, bool ctrl, bool shift, void *userData), const void *userData=nullptr)
void setOnVFBClosed (T &object, const void *userData=nullptr)
void setOnVFBClosed (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
void setOnVFBCopyToHostFrameBufferNotify (T &object, const void *userData=nullptr)
void setOnVFBCopyToHostFrameBufferNotify (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, int enabled, int mode, int selectionLocked, double instant, void *userData) TMethod>
void setOnVFBDebugShadingNotify (T &object, const void *userData=nullptr)
void setOnVFBDebugShadingNotify (void(*callback)(VRayRenderer &, int enabled, DebugShadingMode mode, int selectionLocked, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, bool isRendering, double instant, void *userData) TMethod>
void setOnVFBInteractiveStart (T &object, const void *userData=nullptr)
void setOnVFBInteractiveStart (void(*callback)(VRayRenderer &, bool isRendering, double instant, void *userData), const void *userData=nullptr)
void setOnVFBLayersChanged (T &object, const void *userData=nullptr)
void setOnVFBLayersChanged (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
void setOnVFBOpenUpdateNotify (T &object, const void *userData=nullptr)
void setOnVFBOpenUpdateNotify (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
void setOnVFBPauseIPR (T &object, const void *userData=nullptr)
void setOnVFBPauseIPR (void(*callback)(VRayRenderer &, bool isRendering, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, bool isRendering, double, void *userData) TMethod>
void setOnVFBRenderLast (T &object, const void *userData=nullptr)
void setOnVFBRenderLast (void(*callback)(VRayRenderer &, bool isRendering, double instant, void *userData), const void *userData=nullptr)
void setOnVFBSaveSettingsNotify (T &object, const void *userData=nullptr)
void setOnVFBSaveSettingsNotify (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
void setOnVFBShowMessagesWindow (T &object, const void *userData=nullptr)
void setOnVFBShowMessagesWindow (void(*callback)(VRayRenderer &, double instant, void *userData), const void *userData=nullptr)
void setOnVFBUpdateIPR (T &object, const void *userData=nullptr)
void setOnVFBUpdateIPR (void(*callback)(VRayRenderer &, bool isRendering, double instant, void *userData), const void *userData=nullptr)
template<class T , void(T::*)(VRayRenderer &, const std::string &outputFile, int fileType, double instant, void *userData) TMethod>
void setOnVRayProfilerWrite (T &object, const void *userData=nullptr)
void setOnVRayProfilerWrite (void(*callback)(VRayRenderer &, const std::string &outputFile, int fileType, double instant, void *), const void *userData=nullptr)
void setProgresiveImageUpdatedHasBuffer (bool hasBuffer)
void setProgressiveImageUpdatedDataType (RenderElement::Type renderChannel=RenderElement::AUTO, RenderElement::DataIntent intent=RenderElement::DI_INTENT_VIEWPORT_IPR, bool hasAlpha=true, bool flipImage=false)
void setProgressiveImageUpdatedHasBuffer (bool hasBuffer)
 Sets if an image passed in the ProgressiveImageUpdated event parameters is needed. If not, no unnecessary copies would be made.
float setProgressiveImageUpdateDifference (float difference)
unsigned long setProgressiveImageUpdateTimeout (unsigned long timeout)
bool setRenderMode (RenderMode mode)
bool setRenderRegion (int rgnLeft, int rgnTop, int rgnWidth, int rgnHeight)
bool setRenderSizes (const RenderSizeParams &sizes, bool regionButtonState)
bool setResumableRendering (bool enable, const ResumableRenderingOptions *options)
bool setUpdatedDefaultProperties ()
void setUserCameraChangedCB (void(*cb)(const UserCameraChanged *info, void *userData), void *userData)
void setUserLightChangedCB (void(*cb)(const UserLightChanged *info, void *userData), void *userData)
void setUserNodeChangedCB (void(*cb)(const UserNodeChanged *info, void *userData), void *userData)
void setUserSceneName (const char *sceneName)
void setUserSceneName (const std::string &sceneName)
void setVFBCameraSelectionItems (const std::vector< const char * > &items)
void setVFBCameraSelectionItems (const std::vector< std::string > &items)
void setVFBContextMenuItems (const std::vector< VFBContextMenuItem > &items)
 Set menu items for the VFB's context menu.
bool setVFBContextMenuItemValue (int commandId, int value)
template<class T , void(T::*)(VRayRenderer &, int commandId, int x, int y, void *userData) TMethod>
void setVFBContextMenuSelectedCallback (T &object, const void *userData=nullptr)
void setVFBContextMenuSelectedCallback (void(*callback)(VRayRenderer &, int commandId, int x, int y, void *userData), const void *userData=nullptr)
void setVisualDebuggerEnabled (bool enable)
 Enables/Disables the Visual Debugger functionality.
void setVRayProfiler (const VRayProfilerSettings &settings)
void start () const
int startSync () const
void stop () const
 Flags the image rendering thread to stop and waits for it to join.
bool tryLockScene ()
void unlockScene ()
bool updateLightingAnalysis ()
bool updateLightingAnalysis (VRay::Plugin plugin)
void useAnimatedValues (bool on)
bool waitForRenderEnd (const int timeout) const
bool waitForRenderEnd (const WaitTime time=WaitTime::AwaitingOrIdle) const
bool waitForSequenceEnd () const
bool waitForSequenceEnd (const int timeout) const
bool waitForVFBClosed () const
bool waitForVFBClosed (const int timeout) const
Static Public Member Functions
static bool isActiveState (RendererState value)
 Convenience function for checking if a state value is in the rendering subset (including preparing).
static bool isInactiveState (RendererState value)
 Convenience function for checking if a state value is in the idle subset (including IDLE_FRAME_DONE awaiting continue command).
Public Attributes
struct VRay::VRayRenderer::VRayProfiler * this
 "property" or "namespace" profiler within VRayRenderer
class VRay::VRayRenderer::VFB vfb
 "property" or "namespace" vfb within VRayRenderer
Protected Member Functions
int getKeyframeTimes (InstanceId pluginID, const char *propertyName, double *&times) const
Internal::VRayRendererNative * getNativeRenderer () const
Plugin getPlugin_internal (InstanceId pluginID) const
template<class T >
T getPlugin_internal (InstanceId pluginID) const
InstanceId getPluginId_internal (const char *pluginName, PluginTypeId &outTypeId) const
const char * getPluginName_internal (InstanceId pluginID) const
AColor getPluginPropertyAColor (const char *pluginName, const char *propertyName, bool &ok, double time) const
AColor getPluginPropertyAColor (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
bool getPluginPropertyBool (const char *pluginName, const char *propertyName, bool &ok, double time) const
bool getPluginPropertyBool (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
Color getPluginPropertyColor (const char *pluginName, const char *propertyName, bool &ok, double time) const
Color getPluginPropertyColor (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
const void * getPluginPropertyDefinition (const char *pluginName, const char *propertyName) const
const void * getPluginPropertyDefinition (InstanceId pluginID, const char *propertyName) const
const void * getPluginPropertyDefinitionFromClass (const char *pluginClassName, const char *propertyName) const
double getPluginPropertyDouble (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
int getPluginPropertyElementsCount (InstanceId pluginID, const char *propertyName) const
float getPluginPropertyFloat (const char *pluginName, const char *propertyName, bool &ok, double time) const
float getPluginPropertyFloat (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
int getPluginPropertyInt (const char *pluginName, const char *propertyName, bool &ok, double time) const
int getPluginPropertyInt (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
Matrix getPluginPropertyMatrix (const char *pluginName, const char *propertyName, bool &ok, double time) const
Matrix getPluginPropertyMatrix (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
std::vector< std::string > getPluginPropertyNames (const char *pluginClassName) const
PluginRef getPluginPropertyPluginRef (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
Type getPluginPropertyRuntimeType (const char *pluginName, const char *propertyName) const
Type getPluginPropertyRuntimeType (InstanceId pluginID, const char *propertyName) const
Transform getPluginPropertyTransform (const char *pluginName, const char *propertyName, bool &ok, double time) const
Transform getPluginPropertyTransform (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
template<typename T >
T getPluginPropertyTyped (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
Value getPluginPropertyValue (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
std::string getPluginPropertyValueAsString (const char *pluginName, const char *propertyName, double time) const
std::string getPluginPropertyValueAsString (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
Vector getPluginPropertyVector (const char *pluginName, const char *propertyName, bool &ok, double time) const
Vector getPluginPropertyVector (InstanceId pluginID, const char *propertyName, bool &ok, double time) const
const char * getPluginType (const char *name) const
const char * getPluginType (InstanceId pluginID) const
PluginTypeId getPluginTypeId_internal (const char *pluginType) const
PluginTypeId getPluginTypeId_internal (InstanceId pluginID) const
const char * getPluginTypeString (PluginTypeId pluginTypeId) const
int getPropertyIndexFromName (InstanceId pluginID, const char *propertyName) const
const char * getPropertyNameFromIndex (InstanceId pluginID, int idx) const
int getPropertyState (InstanceId pluginID, const char *propertyName) const
VRayImage * getRenderElementAsImage (InstanceId pluginID, int type, int layer, const GetImageOptions &options, const bool isDoColorCorrectionsUSerSet=false) const
size_t getRenderElementData (InstanceId pluginID, InstanceId alphaPluginID, int type, int layer, RenderElement::PixelFormat format, int intent, bool rgbOrder, const ImageRegion *rgn, void **buf) const
size_t getRenderElementDataIntoBuffer (InstanceId pluginID, InstanceId alphaPluginID, int type, int layer, RenderElement::PixelFormat format, int intent, bool rgbOrder, const ImageRegion *rgn, bool flipImage, void *buf) const
bool getRenderElementInfo (InstanceId pluginID, int type, RenderElement::Info &chInfo) const
std::string getRenderElementMetadata (InstanceId pluginID, int type) const
Plugin getRenderElementPlugin (int type) const
std::vector< Plugin > getRenderElementPluginsList (int type) const
Plugin newRenderElementPlugin (int type, const char *instanceName, const char *displayName)
bool pluginExists_internal (InstanceId pluginID) const
bool setPluginName (InstanceId pluginID, const char *name) const
bool setPluginPropertyValueAsString (InstanceId pluginID, const char *propertyName, const char *value) const
bool setPluginPropertyValueAsStringAtTime (InstanceId pluginID, const char *propertyName, const char *value, double time) const
bool setPluginPropertyValueAtTime (InstanceId pluginID, const char *propertyName, const void *pval, double time) const
bool setPluginPropertyValueRawAtTime (InstanceId pluginID, const char *propertyName, const void *pval, size_t count, double time) const
bool setPluginUpdatedDefaultProperties (InstanceId pluginID) const
Static Protected Member Functions
static std::vector< const char * > getCharPtrVector (const std::vector< std::string > &strVector)
template<class T >
static std::vector< T > getPluginsOfType (VRayRenderer &renderer, const char *pluginType)
template<class T >
static std::vector< T > getPluginsOfTypeId (VRayRenderer &renderer, PluginTypeId typeId)
static std::vector< std::string > getStringVector (void *pvector)
static VRayRenderer * getVRayRenderer (void *rendererNative)
Friends
class Internal::Access
class LocalBmp
class LocalJpeg
class LocalPng
class Plugin
class PluginMeta
template<class P >
class PluginRefT
class PropertyMeta
class PropertyRuntimeMeta
class RenderElement
class RenderElements
class UIGuides
template<class T , Util::PreCreateCallbackOptions(T::*)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *) TMethod, void(T::*)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *) TMethod1>
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const char *pluginType, T &obj, const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const char *pluginType, Util::PreCreateCallbackOptions(*preCreateCallback)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *), void(*postCreateCallback)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *), const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const PluginTypeId &pluginTypeId, T &obj, const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const PluginTypeId &pluginTypeId, Util::PreCreateCallbackOptions(*preCreateCallback)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *), void(*postCreateCallback)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *), const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const std::string &pluginType, T &obj, const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const std::string &pluginType, Util::PreCreateCallbackOptions(*preCreateCallback)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *), void(*postCreateCallback)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *), const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const std::vector< Plugin > &includeListOfPlugins, const std::vector< Plugin > &excludeListOfPlugins, T &obj, const void *userData)
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, const std::vector< Plugin > &includeListOfPlugins, const std::vector< Plugin > &excludeListOfPlugins, Util::PreCreateCallbackOptions(*preCreateCallback)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *), void(*postCreateCallback)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *), const void *userData)
template<class T , Util::PreCreateCallbackOptions(T::*)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *) TMethod, void(T::*)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *) TMethod1, class PluginType >
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, T &obj, const void *userData)
template<class PluginType >
int Util::copyPlugins (VRayRenderer &srcRenderer, VRayRenderer &dstRenderer, Util::PreCreateCallbackOptions(*preCreateCallback)(VRayRenderer &dstRenderer, Plugin &srcPlugin, void *), void(*postCreateCallback)(Plugin &dstPlugin, const char *srcPluginName, Util::ReasonsForAutoRename autoRenamedResult, const char *preCreateCallbackReturnedName, void *), const void *userData)
Detailed Description
This class wraps the underlying V-Ray render engine and its scene contents.
  • Rendering is always started in a separate thread. In Interactive mode changes to the scene are disabled for the period between calling start and receiving the 'started' event. After that changes can be made. They get applied asynchronously to the V-Ray engine in its own threads.
  • VRayRenderer callbacks are emitted from their own separate dedicated thread where events are queued and dispatched.This means that they may be seen later than the precise time they occurred and in some cases the state of the renderer could have changed meanwhile. The callbacks that you attach should be fast because their execution blocks any other queued event callbacks.
Member Enumeration Documentation
◆ DebugShadingMode
enum class VRay::VRayRenderer::DebugShadingMode : int
strong
Enumerator
isolateSelect
Render only selected nodes/the nodes with the selected textures/materials.
globalLighting
Render everything with a gray Lambert material.
globalAO
Render everything with a TexDirt material.
globalWireframe
Render everything with a TexEdges material.
globalNormal
Render everything with a TexSampler normal material.
globalUV
Render everything with a TexSampler uvCoord material.
globalBarycentric
Render everything with a TexSampler barycentryc_coords material.
◆ WaitTime
enum class VRay::VRayRenderer::WaitTime : int
strong
Enumerator
AwaitingOrIdle
When used with keepInteractiveRunning will return on RENDERING_AWAITING_CHANGES or any idle state
Idle
Will return on any idle state. When used with keepInteractiveRunning, this means only stop or error.
Constructor & Destructor Documentation
◆ VRayRenderer() [1/3]
VRay::VRayRenderer::VRayRenderer ( )
Default constructor which uses default rendering options The default render mode is Interactive.
◆ VRayRenderer() [2/3]
VRay::VRayRenderer::VRayRenderer ( const RendererOptions &  rendererOptions)
Constructor which uses supplied immutable rendering options. The default render mode is Interactive.
◆ VRayRenderer() [3/3]
VRay::VRayRenderer::VRayRenderer ( InstanceHandleType  handle)
explicit
Creates a new shared VRayRenderer from an instance handle. This allows sharing a VRayRenderer instance among different programming languages and/or shared libraries in the same process. Use with extreme caution! Do not use unless you know exactly what you're doing!
Member Function Documentation
◆ addHosts()
AddHostsResult VRay::VRayRenderer::addHosts ( const char *  hosts) const
Adds hosts to the list for distributed rendering. If rendering is already in process, they are connected directly.
hostsIP:port (or hostname:port) pairs as string delimited by ',' or ';'
Returns
See the AddHostsResult enum comments
◆ addVRayProfilerMetadata()
bool VRay::VRayRenderer::addVRayProfilerMetadata ( const char *  category,
const char *  key,
const char *  value
Add a key-value pair to VRay Profiler metadata under a specific category (key). Should be called as early as possible before setVRayProfiler, otherwise it will have no effect.
category- a key to which the key-value pair will be added
key- a preferably unique identifier. If duplicated the last value entry will be set to correspond to this key
value- the value to the corresponding key
Returns
true if the key-value pair has been successfully added and false if there was a problem
◆ append() [1/2]
int VRay::VRayRenderer::append ( const char *  fileName,
bool  drSendNameOnly = false
Appends the specified scene file data to the currently loaded scene without wiping it.
fileNameThe file path to the .vrscene file which will be appended.
drSendNameOnlyIndicates whether the whole file should be sent to the DR hosts or the name only.
Returns
0 - no error; check getLastParserError() if != 0
◆ append() [2/2]
int VRay::VRayRenderer::append ( const std::vector< const char * > &  fileNames)
Appends the specified scene files data to the currently loaded scene without wiping it. This treats all files as one.
fileNamesThe file paths vector to the .vrscene files which will be appended. The files are interpreted as one. If one fails, they all fail.
Returns
◆ appendAsText() [1/3]
int VRay::VRayRenderer::appendAsText ( const char *  text)
Similar to append() but this takes as input directly the text contents of a scene file
Returns
◆ appendAsText() [2/3]
int VRay::VRayRenderer::appendAsText ( const char *  text,
size_t  length,
void(*)(char *text, size_t size, T *holderObject)  freeFn = nullptr,
T *  holderObject = nullptr
Similar to append() but this takes as input the text contents of a scene file The text is used directly and is NOT copied into V-Ray internal memory.
textThe text contents of a vrscene.
lengthThe length in bytes of the text contents (without a terminating zero character).
freeFnA pointer to a custom free function to be called when the data is no longer needed. If omitted, the data won't be freed.
holderObjectA pointer to a custom object that manages the text memory.
Returns
◆ appendAsText() [3/3]
int VRay::VRayRenderer::appendAsText ( const std::vector< const char * > &  sceneTexts)
Appends the specified scene texts to the currently loaded scene without wiping it. This treats all texts as one.
sceneTextsThe vector with scene texts which will be appended. The texts are interpreted as one. If one fails, they all fail.
Returns
◆ appendAsTextFiltered() [1/4]
int VRay::VRayRenderer::appendAsTextFiltered ( const char *  fileName,
bool(*)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *)  callback,
const void *  userData = nullptr
Similar to appendFiltered() but this takes as input directly the text contents of a scene file.
Returns
◆ appendAsTextFiltered() [2/4]
T &  obj,
Returns
◆ appendAsTextFiltered() [3/4]
int VRay::VRayRenderer::appendAsTextFiltered ( const std::vector< const char * > &  sceneTexts,
Appends the specified scene texts to the currently loaded scene without wiping it. This treats all texts as one. A callback function is called for each plugin before it is created in memory. The user can decide whether he wants the plugin to be created or not and whether he wants to change its name.
callbackThe callback function called for each plugin. Return true if you want the plugin to be created or false otherwise. You can also change the plugin name in the callback.
userDataA pointer to optional user data which is then passed to the callback function.
Returns
◆ appendAsTextFiltered() [4/4]
T &  obj,
TThe type of the object containing a callback member function.
TMethodA pointer to the callback member function. Return true if you want the plugin to be created or false otherwise. You can also change the plugin name in the callback.
objThe object containing the callback member function called for each plugin.
Returns
◆ appendFiltered() [1/4]
int VRay::VRayRenderer::appendFiltered ( const char *  fileName,
Appends the specified scene file data to the currently loaded scene without wiping it. The file can be exported from a previous session with this SDK or from V-Ray for 3dsMax, Maya, etc. A callback function is called for each plugin before it is created in memory. The user can decide whether he wants the plugin to be created or not and whether he wants to change its name.
Returns
◆ appendFiltered() [2/4]
T &  obj,
Returns
◆ appendFiltered() [3/4]
int VRay::VRayRenderer::appendFiltered ( const std::vector< const char * > &  fileNames,
Appends the specified scene files data to the currently loaded scene without wiping it. This treats all files as one. A callback function is called for each plugin before it is created in memory. The user can decide whether he wants the plugin to be created or not and whether he wants to change its name.
Returns
◆ appendFiltered() [4/4]
T &  obj,
Returns
◆ bucketRenderNearest()
void VRay::VRayRenderer::bucketRenderNearest ( int  x,
int  y
) const
When using the bucket sampler in production mode this sets a "focus point" for the follow mouse cursor feature of the VFB. This API allows you to do this without the VFB. Buckets are generated in a circle outward from the point.
xThe x-coordinate of the focus point. If set to negative this will reset the "follow cursor" behavior and continue with the normal bucket generator.
yThe y-coordinate of the focus point. If set to negative this will reset the "follow cursor" behavior and continue with the normal bucket generator.
◆ commit()
unsigned long long VRay::VRayRenderer::commit ( bool  force = false)
Commits any accumulated scene changes. This is necessary if the autoCommit flag is set to false.
Returns
The new change index if the changes were successfully committed, 0 otherwise. See setOnProgressiveImageUpdated().
◆ deletePlugin() [1/3]
bool VRay::VRayRenderer::deletePlugin ( const char *  pluginName)
Remove the plugin from the scene. Plugin object handles becomes invalid if the call is successful.
Returns
true if removal was successful
◆ deletePlugin() [2/3]
bool VRay::VRayRenderer::deletePlugin ( const Plugin &  plugin)
Remove the plugin from the scene. The Plugin object becomes invalid if the call is successful.
Returns
◆ deletePlugin() [3/3]
bool VRay::VRayRenderer::deletePlugin ( const std::string &  pluginName)
Returns
◆ deletePlugins() [1/3]
bool VRay::VRayRenderer::deletePlugins ( const char *  names[],
size_t  namesCount
Remove the plugins from the scene. If removal of any plugin fails, it continues to the next. Plugin object handles become invalid if successful.
Returns
true if all plugin removals were successful, false if any of them failed
◆ deletePlugins() [2/3]
bool VRay::VRayRenderer::deletePlugins ( const std::vector< std::string > &  names)
Returns
◆ deletePlugins() [3/3]
bool VRay::VRayRenderer::deletePlugins ( const std::vector< VRay::Plugin > &  plugins)
Returns
◆ denoiseNow()
bool VRay::VRayRenderer::denoiseNow ( void(*)(VRayRenderer &, VRayImage *, void *)  userCb = 0,
bool  shouldPassImage = true,
Explicitly starts the denoiser. Requires a RenderChannelDenoiser instance in the scene. This can be run while rendering is ongoing or when it's paused or after it is stopped. Denoising parameters are taken from the RenderChannelDenoiser plugin. The denoising is run asynchronously, so this function will return as soon as the thread is started. When denoising is done the postEffectsUpdated callback will be called. Additionally, if specified, a user callback will be called (with an option to also pass an image to it).
userCb[optional] A callback function to be called when denoising is finished.
shouldPassImage[optional] Whether to pass an image to the callback function.
Returns
true if the denoising thread is started successfully and false if there is a problem with the parameters or renderer state
◆ disableDRClient()
bool VRay::VRayRenderer::disableDRClient ( )
NOTE: Available in DR2 only Toggles off the current VRayRenderer to act as a DR2 client.
Returns
False if this failed, e.g. when a render is already running.
◆ enableDRClient()
bool VRay::VRayRenderer::enableDRClient ( const EnableDRClientParams &  enableParams)
NOTE: Available in DR2 only Toggles on the current VRayRenderer to act as a DR2 client.
enableParamsThe necessary parameters.
Returns
False if this failed, e.g. when a render is already running or V-Ray failed to initialize its DR subsystem.
◆ enableLiveLinkClient()
bool VRay::VRayRenderer::enableLiveLinkClient ( const LiveLinkClientParameters &  params)
NOTE: Available in DR2 only Toggles on the current VRayRenderer to act as a DR2 LiveLink client
paramsPre-configured parameters to enable livelink
Returns
◆ exportScene() [1/2]
int VRay::VRayRenderer::exportScene ( const char *  filePath) const
Exports the current scene contents to the specified file. The exporter serializes all plugins in text format.
filePathThe path to the file where the scene will be exported. The file path must contain the name and extension of the destination file.
Returns
0 - no error
◆ exportScene() [2/2]
int VRay::VRayRenderer::exportScene ( const char *  filePath,
const VRayExportSettings &  settings
) const
settingsAdditional options such as plugin list, compression and file splitting
Returns
0 - no error
◆ exportSceneToBuffer() [1/2]
std::string VRay::VRayRenderer::exportSceneToBuffer ( ) const
Exports the current scene contents and return the generated vrscene stream as a string. The exporter serializes all plugins in text format.
Returns
the vrscene stream as a string
◆ exportSceneToBuffer() [2/2]
std::string VRay::VRayRenderer::exportSceneToBuffer ( const VRayExportSettings &  settings) const
settingsOptions such as plugin list, compression and file splitting
Returns
◆ getActiveHosts()
std::string VRay::VRayRenderer::getActiveHosts ( ) const
Returns all active hosts during distributed rendering.
Returns
semicolon separated string of IP:port (or hostname:port) pairs
◆ getAllHosts()
std::string VRay::VRayRenderer::getAllHosts ( ) const
Returns all hosts set for distributed rendering.
Returns
◆ getCausticsSize()
size_t VRay::VRayRenderer::getCausticsSize ( ) const
Returns
The size in bytes of the caustics photon map in memory. This is 0 if no data is available.
◆ getChangeIndex()
unsigned long long VRay::VRayRenderer::getChangeIndex ( ) const
Returns the last change index for interactive changes on the renderer instance.
Returns
The last applied change index. Should be equal to result from the last commit() call, if there are no pending changes.
◆ getComputeDevicesCUDA()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesCUDA ( ) const
Returns a list of all devices available for use by the CUDA engine. The "CUDA CPU" device uses the CUDA engine code compiled for the x86-64 architecture. It is not the CPU V-Ray engine. It is disabled by default but you can enable it for faster "hybrid" rendering.
Returns
If the list is empty, check getLastError() for failure.
See also
struct ComputeDeviceInfo
◆ getComputeDevicesCurrentEngine()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesCurrentEngine ( ) const
Returns a list of all devices available for use by the current engine (Optix, CUDA, Metal).
Returns
If the list is empty, check getLastError() for failure. The list will be empty without error if the current render mode is CPU.
See also
◆ getComputeDevicesDenoiser()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesDenoiser ( ) const
Returns a list of all devices available for denoising.
Returns
See also
◆ getComputeDevicesMetal()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesMetal ( ) const
Returns a list of all devices available for use by the Metal engine. macOS only.
Returns
See also
◆ getComputeDevicesMetalRT()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesMetalRT ( ) const
Returns a list of all devices available for use by the MetalRT engine. macOS only.
Returns
See also
◆ getComputeDevicesOptix()
std::vector< ComputeDeviceInfo > VRay::VRayRenderer::getComputeDevicesOptix ( ) const
Returns a list of all devices available for use by the Optix engine.
Returns
See also
◆ getCurrentFrame()
int VRay::VRayRenderer::getCurrentFrame ( ) const
Get the currently set animation frame number. This is related to the current scene time through the SettingsOutput.frames_per_second parameter. If called during render sequence will return the frame number that will be rendered after the call to continueSequence().
◆ getCurrentTime()
double VRay::VRayRenderer::getCurrentTime ( ) const
Gets the current scene time. This is related to the current frame number through the SettingsOutput.frames_per_second parameter. If called during render sequence will return the time of the frame that will be rendered after the call to continueSequence().
◆ getDREnabled()
bool VRay::VRayRenderer::getDREnabled ( ) const
NOTE: Available in DR1 only Return whether distributed rendering is currently enabled or not.
◆ getIESPrescribedIntensity()
float VRay::VRayRenderer::getIESPrescribedIntensity ( const char *  iesLightFileName) const
Returns the prescribed intensity from an ies file
iesLightFileNamestring Path to the ies file
◆ getImage() [1/2]
VRayImage * VRay::VRayRenderer::getImage ( ) const
Returns a pointer to a copy of the image contained in the renderer image buffer at this moment. The caller is responsible for deleting it. WARNING: If Nvidia AI upscaling is enabled, then the returned image/data will have even dimentions.
◆ getImage() [2/2]
VRayImage * VRay::VRayRenderer::getImage ( const GetImageOptions &  options) const
optionsUse to modify behavior compared to getImage(void) - crop, color correct, etc.
◆ getImageIntoBuffer()
size_t VRay::VRayRenderer::getImageIntoBuffer ( const GetImageOptions &  options,
void *  buf
) const
Retrieves the render image raw data into the buffer. WARNING: If Nvidia AI upscaling is enabled, then the returned image/data will have even dimentions.
optionsImage options (crop, color correct, etc.).
bufThe output data buffer. If nullptr - returns required buffer size.
Returns
If data is nullptr returns required buffer size; 0 on error; 1 on success.
◆ getInactiveHosts()
std::string VRay::VRayRenderer::getInactiveHosts ( ) const
Returns all inactive hosts during distributed rendering.
Returns
◆ getInProcess()
bool VRay::VRayRenderer::getInProcess ( ) const
NOTE: Available in DR1 only Return the current value of the inProcess flag.
◆ getInstanceHandle()
InstanceHandleType VRay::VRayRenderer::getInstanceHandle ( ) const
Returns a handle which allows sharing a VRayRenderer instance among different programming languages and/or shared libraries in the same process. Use with extreme caution! Do not use unless you know exactly what you're doing!
◆ getInstanceOf() [1/2]
Plugin VRay::VRayRenderer::getInstanceOf ( const char *  pluginType) const
Returns the latest instance of a given plugin type if any exist. Should be used for singleton plugins. Settings plugins are singletons.
pluginTypeThe plugin class name.
Returns
The plugin instance which may be invalid if one does not exist.
◆ getInstanceOf() [2/2]
Plugin VRay::VRayRenderer::getInstanceOf ( PluginTypeId  pluginTypeId) const
pluginTypeIdThe plugin type id.
Returns
◆ getInstanceOrCreate() [1/3]
Plugin VRay::VRayRenderer::getInstanceOrCreate ( const char *  pluginName,
Returns an existing instance (the last one) of a given plugin type or creates a new instance otherwise, using the given instance name. Should be used for singleton plugins. Settings plugins are singletons. Use getOrCreatePlugin() for other plugin types.
pluginNameThe plugin instance name if it has to be created.
Returns
The plugin instance which may be invalid if the requested type itself is invalid.
◆ getInstanceOrCreate() [2/3]
Plugin VRay::VRayRenderer::getInstanceOrCreate ( const char *  pluginType)
Returns an existing instance (the last one) of a given plugin type or creates a new instance otherwise. Should be used for singleton plugins. Settings plugins are singletons. Use getOrCreatePlugin() for other plugin types.
Returns
◆ getInstanceOrCreate() [3/3]
Plugin VRay::VRayRenderer::getInstanceOrCreate ( PluginTypeId  pluginTypeId)
Returns
◆ getIrradianceMapSize()
size_t VRay::VRayRenderer::getIrradianceMapSize ( ) const
Returns
The size in bytes of the irradiance map in memory. This is 0 if no IM is available.
◆ getLightCacheSize()
size_t VRay::VRayRenderer::getLightCacheSize ( ) const
Returns
The size in bytes of the light cache in memory. This is 0 if no LC is available.
◆ getOrCreatePlugin()
Plugin VRay::VRayRenderer::getOrCreatePlugin ( const char *  pluginName,
Returns an existing plugin instance with the given instance name and of the given type. A new instance is created if one does not exist with the given name. This behaves like getInstanceOrCreate if no instance name is given (empty/null), i.e. returns any instance of this type as long as one exists. For singleton plugins like the settings plugins use getInstanceOrCreate() to avoid inadvertently creating more than one instance.
pluginNameThe plugin instance name. If empty, any existing plugin might be returned.
Returns
The plugin instance which should not be invalid unless the plugin type is not available.
◆ getPhotonMapSize()
size_t VRay::VRayRenderer::getPhotonMapSize ( ) const
Returns
The size in bytes of the global photon map in memory. This is 0 if no PM is available.
◆ getPlugin()
Plugin VRay::VRayRenderer::getPlugin ( const char *  pluginName) const
Search for a plugin instance with the given name.
Returns
Invalid Plugin object if not found.
◆ getPlugins()
std::vector< RetT > VRay::VRayRenderer::getPlugins ( ) const
Returns all plugin instances of a given type T in the current scene. If you want to get an std::vector<Plugin> instead of std::vector<T> pass Plugin as a second template parameter e.g. getPlugins<Node, Plugin>()
◆ getPluginsOfCategories()
std::vector< Plugin > VRay::VRayRenderer::getPluginsOfCategories ( const std::vector< PluginCategories > &  categories) const
Returns all plugin instances that belong to all passed categories in categories[0] or all in categories[1], etc.
◆ getPluginTypesOfCategories() [1/2]
std::vector< std::string > VRay::VRayRenderer::getPluginTypesOfCategories ( const std::vector< PluginCategories > &  categories) const
Returns the class names of all available V-Ray plugin classes loaded from dynamic libraries which belong to all specified categories in categories[0] or all in categories[1], etc.
categoriesPlugin categories
Returns
vector of class names
◆ getPluginTypesOfCategories() [2/2]
std::vector< std::string > VRay::VRayRenderer::getPluginTypesOfCategories ( PluginCategories  categories) const
Returns the class names of all available V-Ray plugin classes loaded from dynamic libraries which belong to all specified categories.
Returns
◆ getPluginTypesOfCategory()
std::vector< std::string > VRay::VRayRenderer::getPluginTypesOfCategory ( PluginCategory  category) const
Returns the class names of all available V-Ray plugin classes loaded from dynamic libraries which belong to the specified category.
categoryPlugin category
Returns
◆ getRenderRegion()
bool VRay::VRayRenderer::getRenderRegion ( int &  rgnLeft,
int &  rgnTop,
int &  rgnWidth,
int &  rgnHeight
) const
Gets the rendering region within the image width and height. (width and height are the rendering sizes set by other methods or constructors, etc.)
◆ getRenderSizes()
bool VRay::VRayRenderer::getRenderSizes ( RenderSizeParams &  sizes,
bool &  regionButtonState
) const
Gets the frame buffer width and height, the rendering region and the crop region.
sizesStructure of all applicable parameters and a bitmask which indicates which ones have been set.
regionButtonStatethe state of the VFB's region button.
◆ getState()
RendererState VRay::VRayRenderer::getState ( ) const
Returns the current state of the renderer. The state could change asynchronously as rendering occurs in another thread.
Note
Use the static helpers IsInactiveState and IsActiveState to check for multiple values.
See also
RendererState
◆ getUserSceneName()
std::string VRay::VRayRenderer::getUserSceneName ( )
Returns the current scene name. Currently used as metadata in some places
Returns
- the name set with setUserSceneName.
◆ getVFBContextMenuItemValue()
bool VRay::VRayRenderer::getVFBContextMenuItemValue ( int  commandId,
int &  value
) const
Get the value from a VFB context menu checkbox item.
commandIdcommandId of the menu item
valueoutput parameter for the value
Returns
false if the menu item does not exist or is not a checkbox
◆ isAborted()
bool VRay::VRayRenderer::isAborted ( ) const
Returns if the rendering has been aborted.
Returns
true if the user has clicked on the Stop button in VFB, false otherwise.
◆ isDRClientEnabled()
bool VRay::VRayRenderer::isDRClientEnabled ( ) const
NOTE: Available in DR2 only Returns whether the current VRayRenderer acts as a DR2 client or not.
◆ isFrameSkipped()
bool VRay::VRayRenderer::isFrameSkipped ( ) const
Returns whether the frame has been skipped.
Returns
true if the frame has been skipped, false otherwise.
◆ isRenderEnded()
bool VRay::VRayRenderer::isRenderEnded ( ) const
Checks if rendering is complete. If it ended in failure or got cancelled, this will still return true. Notice that an intermediate image may be available from getImage even if this returns false (because rendering is ongoing).
Remarks
It is recommended to use waitForRenderEnd instead of polling this in a loop.
◆ isRenderingInHalfResolution()
bool VRay::VRayRenderer::isRenderingInHalfResolution ( ) const
inline
True if V-Ray is rendering internally half resolution (the images/data returned are upsampled to full resolution). False if V-Ray is rendering in full resolution.
◆ isSequenceEnded()
bool VRay::VRayRenderer::isSequenceEnded ( ) const
Gets the status of the sequence rendering process. This is not meaningful if you're not rendering a sequence.
Returns
true if the whole sequence has been rendered, false otherwise.
◆ load()
int VRay::VRayRenderer::load ( const char *  fileName)
Loads the specified V-Ray scene file (.vrscene) into memory. Previous scene contents are wiped. The file can be exported from a previous session with this SDK or from V-Ray for 3dsMax, Maya, etc.
fileNameThe file path to the .vrscene file which will be loaded.
Returns
◆ loadAsText() [1/2]
int VRay::VRayRenderer::loadAsText ( const char *  text)
Similar to load() but this takes as input the text contents of a scene file The text is copied into V-Ray internal memory. Consider using another overload if the text string is long.
Returns
◆ loadAsText() [2/2]
template<typename T = void>
int VRay::VRayRenderer::loadAsText ( const char *  text,
size_t  length,
Similar to load() but this takes as input the text contents of a scene file The text is used directly and is NOT copied into V-Ray internal memory.
Returns
◆ loadAsTextFiltered() [1/2]
int VRay::VRayRenderer::loadAsTextFiltered ( const char *  fileName,
Similar to loadFiltered() but this takes as input directly the text contents of a scene file.
Returns
◆ loadAsTextFiltered() [2/2]
template<class T , bool(T::*)(VRayRenderer &, const char *pluginType, std::string &pluginName, void *) TMethod>
T &  obj,
Returns
◆ loadFiltered() [1/2]
int VRay::VRayRenderer::loadFiltered ( const char *  fileName,
Loads the specified V-Ray scene file (.vrscene) into memory. Previous scene contents are wiped. The file can be exported from a previous session with this SDK or from V-Ray for 3dsMax, Maya, etc. A callback function is called for each plugin before it is created in memory. The user can decide whether he wants the plugin to be created or not and whether he wants to change its name.
Returns
◆ loadFiltered() [2/2]
T &  obj,
Returns
◆ lockScene()
void VRay::VRayRenderer::lockScene ( )
Locks the scene for writing and reading This will block until rendering stops and will not resume until unlockScene is called This method is usefull when there are a batch of changes to be made while interactive rendering is running. Locking scene before all changes and then unlocking after finished updating, may increase performance significantly when there are many changes.
◆ newPlugin() [1/2]
Plugin VRay::VRayRenderer::newPlugin ( const char *  pluginName,
Creates an instance of a specific Plugin type with the given instance name.
pluginNameThe plugin name.
Returns
The new plugin instance (an invalid Plugin on error).
◆ newPlugin() [2/2]
Plugin VRay::VRayRenderer::newPlugin ( const char *  pluginType)
Creates an instance of a specific Plugin type with an autogenerated instance name.
Returns
◆ operator bool()
VRay::VRayRenderer::operator bool ( ) const
If exceptions are not enabled use this function to test whether you have a valid renderer.
Returns
true - renderer instance is valid, false - renderer instance is invalid
◆ operator!()
bool VRay::VRayRenderer::operator! ( ) const
If exceptions are not enabled you can use this function to test whether you have a valid renderer.
Returns
true - renderer instance is invalid, false - renderer instance is valid
◆ optimizeMaterialGraph()
bool VRay::VRayRenderer::optimizeMaterialGraph ( const Plugin &  topPlugin)
Optimizes the plugin graph with the provided top plugin by merging instances with the same parameters. Note that plugins outside the graph may be modified as well. The graph defined by the topPlugin should be acyclic.
topPluginThe top plugin for which the optimization will be performed.
Returns
true on success, false on failure
Remarks
The optimized plugins are not removed from the scene by this call.
◆ pause()
bool VRay::VRayRenderer::pause ( ) const
Pauses interactive rendering. Only sampling is stopped, so that the CPU/GPU will be idle, but everything else is the same. Returns true if the pause operation was successful, false otherwise (the renderer is in invalid state and transition could not be applied).
◆ pickPlugin() [1/2]
Plugin VRay::VRayRenderer::pickPlugin ( int  x,
int  y
) const
Returns the first scene Node intersected by tracing a camera ray from image space coordinates (x;y), if any
xImage space X
yImage space Y
◆ pickPlugin() [2/2]
int  y,
int  timeout
) const
xImage space X
yImage space Y
timeoutMaximum milliseconds to spend before returning a result
◆ pickPlugins()
std::vector< PickedPluginInfo > VRay::VRayRenderer::pickPlugins ( double  x,
double  y,
int  maxcount = 0,
int  timeout = -1
) const
Returns a list of scene Node intersected by tracing a camera ray from image space coordinates (x;y) ordered by depth
xImage space X
yImage space Y
maxcountMaximum number of nodes to include in the list
◆ removeHosts()
int VRay::VRayRenderer::removeHosts ( const char *  hosts) const
Disconnects and removes hosts from the distributed rendering host lists.
Returns
0 - no error
◆ renderSequence()
void VRay::VRayRenderer::renderSequence ( SubSequenceDesc  descriptions[],
size_t  count
) const
descriptionsFrame ranges to render
countThe number of elements in descriptions
◆ replacePlugin()
bool VRay::VRayRenderer::replacePlugin ( const Plugin &  oldPlugin,
const Plugin &  newPlugin
Replaces all references (in the scene) of oldPlugin with newPlugin.
oldPluginThe plugin whose references are to be replaced.
newPluginThe plugin which will replace the old one. This can be an empty Plugin() in which case all references to oldPlugin will be removed.
Returns
Remarks
The oldPlugin does not get removed from the scene by this call
◆ resetHosts()
int VRay::VRayRenderer::resetHosts ( const char *  hosts = nullptr) const
Resets the hosts list for distributed rendering. If rendering is in process, hosts that are not on the new list are disconnected.
Returns
0 - no error
◆ resume()
bool VRay::VRayRenderer::resume ( ) const
Resumes interactive rendering. Returns true if the resume operation was successful, false otherwise (the renderer is in invalid state and transition could not be applied).
◆ saveCausticsFile()
bool VRay::VRayRenderer::saveCausticsFile ( const std::string &  fileName)
fileNameDestination caustics photon map file
Returns
false if an error ocurred or there is no data to save. Check getLastError() for additional info.
◆ saveIrradianceMapFile()
bool VRay::VRayRenderer::saveIrradianceMapFile ( const std::string &  fileName)
fileNameDestination irradiance map file
Returns
◆ saveLightCacheFile()
bool VRay::VRayRenderer::saveLightCacheFile ( const std::string &  fileName)
fileNameDestination light cache file
Returns
◆ savePhotonMapFile()
bool VRay::VRayRenderer::savePhotonMapFile ( const std::string &  fileName)
fileNameDestination global photon map file
Returns
◆ serializeScene()
bool VRay::VRayRenderer::serializeScene ( )
Serializes the whole scene (plugins with their property values) contained in the renderer into a single memory stream no matter if they originate from a loaded or appended vrscene file or are created by code. The whole stream will be always transferred when DR hosts are connected. No DR hosts should have been connected before serialization. (Currently only one type of serialization is supported but other types may be added in the future.) This method is here mainly for debug purposes but it can be helpful in some other cases as well. Do not use it unless you know exactly what you're doing.
◆ setAutoCommit()
void VRay::VRayRenderer::setAutoCommit ( bool  autoCommit)
Change the autoCommit state of the renderer. When true, every parameter change is applied immediately. Otherwise you have to call commit() yourself to apply changes. 'false' allows you to batch changes together for efficiency.
◆ setBitmapCache()
int VRay::VRayRenderer::setBitmapCache ( bool  onOff)
Cache bitmaps between renders. If enabled, bitmap textures will be stored in memory and won't be unloaded / loaded again on the next render. This may save a lot of time loading heavy textures before every render.
onOffEnable / disable bitmap texture cache. Disabling cache will clear cached data.
Returns
True if cache interfaces were added; false - otherwise.
◆ setCamera()
bool VRay::VRayRenderer::setCamera ( const Plugin &  plugin)
This method is only used when doing out-of-process rendering (inProcess=false). It updates the camera plugin used on DR machines when adding/removing CameraPhysical or another specific camera.
◆ setComputeDevicesCUDA()
bool VRay::VRayRenderer::setComputeDevicesCUDA ( const std::vector< int > &  indices)
Set which devices to use for rendering with the CUDA engine.
indicesThe indices of the devices to use as returned by getComputeDevicesCUDA
Returns
false if an error occurred. Check getLastError() for additional info.
◆ setComputeDevicesCurrentEngine()
bool VRay::VRayRenderer::setComputeDevicesCurrentEngine ( const std::vector< int > &  indices)
Set which devices to use for rendering with the current engine (Optix, CUDA, Metal).
indicesThe indices of the devices to use as returned by getComputeDevicesCurrentEngine
Returns
false if an error occurred. Check getLastError() for additional info. This will fail without error if the current render mode is CPU.
◆ setComputeDevicesDenoiser()
bool VRay::VRayRenderer::setComputeDevicesDenoiser ( const std::vector< int > &  indices)
Set which devices to use for denoising, when GPU denoiser is selected.
indicesThe indices of the devices to use as returned by getComputeDevicesDenoiser
Returns
◆ setComputeDevicesEnvironmentVariable()
bool VRay::VRayRenderer::setComputeDevicesEnvironmentVariable ( )
Set the user environment to the currently selected devices for each engine. Note that this will affect other V-Ray products as well.
Returns
◆ setComputeDevicesMetal()
bool VRay::VRayRenderer::setComputeDevicesMetal ( const std::vector< int > &  indices)
Set which devices to use for rendering with the Metal engine. macOS only.
indicesThe indices of the devices to use as returned by getComputeDevicesMetal
Returns
◆ setComputeDevicesMetalRT()
bool VRay::VRayRenderer::setComputeDevicesMetalRT ( const std::vector< int > &  indices)
Set which devices to use for rendering with the MetalRT engine. macOS only.
indicesThe indices of the devices to use as returned by getComputeDevicesMetalRT
Returns
◆ setComputeDevicesOptix()
bool VRay::VRayRenderer::setComputeDevicesOptix ( const std::vector< int > &  indices)
Set which devices to use for rendering with the Optix engine.
indicesThe indices of the devices to use as returned by getComputeDevicesOptix
Returns
◆ setCropRegion() [1/2]
bool VRay::VRayRenderer::setCropRegion ( int  srcWidth,
int  srcHeight,
float  rgnLeft,
float  rgnTop
Sets a virtual crop region (rgnLeft, rgnTop, width, height) within a virtual source image space with size srcWidth, srcHeight. width and height are the rendering sizes set by other methods or constructors, etc. Set to an invalid size, like (0, 0, 0, 0), to reset the region and render the whole image. This (creates if necessary and) changes SettingsOutput in the scene. The size is reset after clearing the scene or loading another scene file.
◆ setCropRegion() [2/2]
int  srcHeight,
float  rgnLeft,
float  rgnTop,
float  rgnWidth,
float  rgnHeight
Sets a virtual crop region (rgnLeft, rgnTop, rgnWidth, rgnHeigt) within a virtual source image space with sizes srcWidth, srcHeight. The output image pixel width and height do not change. Set to an invalid size, like (0, 0, 0, 0, 0, 0), to reset the region and render the whole image. This (creates if necessary and) changes SettingsOutput in the scene. The size is reset after clearing the scene or loading another scene file.
◆ setCurrentFrame()
bool VRay::VRayRenderer::setCurrentFrame ( int  frame)
Change the current animation frame number. Setting properties after this will add keyframe values for this frame if useAnimatedValues(true) was called. This is related to the current scene time through the SettingsOutput.frames_per_second parameter.
Returns
false if called during renderSequence. Then the current frame is not set.
◆ setCurrentTime()
bool VRay::VRayRenderer::setCurrentTime ( double  time)
Sets the current scene time. This is related to the current frame number through the SettingsOutput.frames_per_second parameter.
Returns
false if called during renderSequence. Then the current time is not set.
◆ setDebugShadingSelection()
void VRay::VRayRenderer::setDebugShadingSelection ( const std::vector< Plugin > &  selection)
Selection for Debug Shading Isolate Selected mode.
selection- A list of plugins to be selected.
◆ setDenoiserOptions()
void VRay::VRayRenderer::setDenoiserOptions ( const DenoiserOptions &  denoiserOptions)
Use this to controls some additional denoiser flags that are not exposed as plugin properties. Call before rendering.
◆ setDREnabled()
bool VRay::VRayRenderer::setDREnabled ( bool  drEnabled,
bool  enableBroadcastListener = true
NOTE: Available in DR1 only Toggles distributed rendering on or off. This can only be done when the renderer is idle. When this is disabled (default) it saves some memory. When it is enabled remote render machines added with addHosts() will be connected and contribute to the render.
drEnabledTrue to enable the DR subsystem.
enableBroadcastListenerOnly when drEnabled=true: Whether a socket will be created to listen for remote machine broadcast messages over LAN.
Returns
◆ setImageSize()
bool VRay::VRayRenderer::setImageSize ( int  width,
int  height,
bool  resetCropRegion = true,
bool  resetRenderRegion = true
Sets the frame buffer width and height. This (creates if necessary and) changes SettingsOutput in the scene. The size is reset after clearing the scene or loading another scene file.
◆ setImprovedDefaultSettings()
bool VRay::VRayRenderer::setImprovedDefaultSettings ( DefaultsPreset  preset = quality_medium)
Execute this on an empty scene to create some settings plugins and initialize some of their properties to values better than the defaults. The defaults remain as they are for compatibility reasons. This should be done before applying your own settings and before starting a render. To see what got changed, export the scene after that to a file and inspect it.
presetAmount of sampling to perform - tradeoff between render time and noise
◆ setIncludePaths()
void VRay::VRayRenderer::setIncludePaths ( const char *  includePaths,
bool  overwrite = true
Set search paths for scene include files.
includePathsstring that looks like "assets;assets/meshes;assets/textures". These are relative paths where the parser looks in when including files.
overwriteindicates whether to overwrite the existing search paths with the given string or to add it to them.
◆ setInProcess()
bool VRay::VRayRenderer::setInProcess ( bool  inProcess)
NOTE: Available in DR1 only Specify whether the executing process participates in the rendering (when true, default) or whether the rendering is executed entirely by V-Ray DR render slaves (when false)
inProcessshould the client process participate in the rendering tasks
Returns
false if renderer is not idle - the change is not applied
◆ setInteractiveNoiseThreshold()
bool VRay::VRayRenderer::setInteractiveNoiseThreshold ( float  threshold)
Set noise threshold for a frame when using interactive mode. Value 0 means unlimited. This (creates if necessary and) changes SettingsRTEngine in the scene. The setting is reset after clearing the scene or loading another scene file.
◆ setInteractiveSampleLevel()
bool VRay::VRayRenderer::setInteractiveSampleLevel ( int  samplesPerPixel)
Set the maximum camera samples per pixel when using interactive mode. Value 0 means unlimited. This (creates if necessary and) changes SettingsRTEngine in the scene. The setting is reset after clearing the scene or loading another scene file.
◆ setInteractiveTimeout()
bool VRay::VRayRenderer::setInteractiveTimeout ( int  timeoutMsec)
Set a timeout value (in milliseconds) for a frame when using interactive mode. Value 0 means unlimited. This (creates if necessary and) changes SettingsRTEngine in the scene. The setting is reset after clearing the scene or loading another scene file.
◆ setKeepInteractiveRunning()
void VRay::VRayRenderer::setKeepInteractiveRunning ( bool  keepRunning)
When set to true V-Ray won't quit interactive rendering even if timeout or noise threshold are reached. Defaults to false. If a noise/time limit is reached, the render engine will become idle, but it will not unload and it will restart sampling when a scene change is applied. The only way to end the render is to explicitly stop() it.
◆ setNumThreads()
bool VRay::VRayRenderer::setNumThreads ( int  numThreads)
Set the number of threads that will be used for rendering. 0 (the default) means all CPU logical threads. This can only be changed while the renderer is idle.
numThreadsnumber of render threads V-Ray will use
Returns
◆ setOnBucketFailed()
void VRay::VRayRenderer::setOnBucketFailed ( void(*)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData)  callback,
Set callback function for the event when an image bucket fails to render. This usually happens when a DR host drops. Callback arguments: renderer - The renderer which produced the event x - left border coordinate in full frame space y - top border coordinate in full frame space width - bucket width height - bucket height host - Hostname of the machine that works on the bucket if DR is enabled pass - Which render pass generated the image instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnBucketInit()
void VRay::VRayRenderer::setOnBucketInit ( void(*)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData)  callback,
Set callback function for the event when an image bucket has been assigned and started rendering. Callback arguments: renderer - The renderer which produced the event x - left border coordinate in full frame space y - top border coordinate in full frame space width - bucket width height - bucket height host - Hostname of the machine that works on the bucket if DR is enabled pass - Which render pass generated the image instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnBucketReady() [1/2]
void VRay::VRayRenderer::setOnBucketReady ( void(&)(VRayRenderer &, int x, int y, const char *host, VRayImage *img, ImagePassType pass, double instant, void *userData)  callback,
Set callback function for the event when an image bucket is completed. Callback arguments: renderer - The renderer which produced the event x - left border coordinate in full frame space y - top border coordinate in full frame space host - Hostname of the machine that works on the bucket if DR is enabled img - A copy of the bucket image buffer. This is deleted internally after the callback (unless setKeepBucketsInCallback(true) was called) pass - Which render pass generated the image instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnBucketReady() [2/2]
void VRay::VRayRenderer::setOnBucketReady ( void(&)(VRayRenderer &, int x, int y, int width, int height, const char *host, ImagePassType pass, double instant, void *userData)  callback,
Set callback function for the event when an image bucket is completed. Callback arguments: renderer - The renderer which produced the event x - left border coordinate in full frame space y - top border coordinate in full frame space width - bucket width height - bucket height host - Hostname of the machine that works on the bucket if DR is enabled pass - Which render pass generated the image instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnCollaborationImageChange()
void VRay::VRayRenderer::setOnCollaborationImageChange ( void(*)(VRayRenderer &, int imageLoaded, int enhanceSupported, double instant, void *userData)  callback,
Set callback function to handle VFB render view events related to collaboration e.g. clearing the render view/finishing a render. The callback shouldn't assume any particular thread, it can be called from the AppSDK render thread or a VFB thread. Callback arguments: imageLoaded - Whether there's an image loaded in the VFB enhanceSupported - Whether the image loaded in the VFB supports enhancement instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnEnhanceOnCollaboration()
void VRay::VRayRenderer::setOnEnhanceOnCollaboration ( int(*)(VRayRenderer &, const std::vector< std::string > &fileList, double instant, void *)  callback,
Set callback function for the Enhance On Collaboration callback. Callback arguments: renderer - The renderer which produced the event fileList - an array holding the paths to the files that should be uploaded instant - Relative time of the event in seconds since V-Ray initialization return - The callback has to return true if the files should be deleted, or false if they should be kept
◆ setOnHostConnected()
void VRay::VRayRenderer::setOnHostConnected ( void(*)(VRayRenderer &, const char *hostName, double instant, void *userData)  callback,
Set callback function for the event when a DR host is connected. Callback arguments: renderer - The renderer which produced the event hostname - IP address or hostname instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnHostDisconnected()
void VRay::VRayRenderer::setOnHostDisconnected ( void(*)(VRayRenderer &, const char *hostName, double instant, void *userData)  callback,
Set callback function for the event when a DR host is disconnected. Callback arguments: renderer - The renderer which produced the event hostname - IP address or hostname instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnLicenseError()
void VRay::VRayRenderer::setOnLicenseError ( void(*)(VRayRenderer &, const char *msg, int errorCode, LicenseUserStatus userStatus, double instant, void *userData)  callback,
Set callback function for the event when V-Ray encounters a licensing error (in its rendering thread). Callback arguments: renderer - The renderer which produced the event msg - The error message contents. errorCode - An exact integer error code which may be used to define more specialized error. userStatus - A user status detail value. Non-zero only if named licensing is used and it is used with automatic ULA token query. instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnLightMixTransferToScene()
void VRay::VRayRenderer::setOnLightMixTransferToScene ( int(*)(VRayRenderer &, const std::vector< LightMixChange > &changes, double instant, void *)  callback,
Set callback function for the light mix transfer to scene callback. Callback arguments: renderer - The renderer which produced the event changes - an array holding the light mix changes instant - Relative time of the event in seconds since V-Ray initialization return - The callback has to return 0 on success, or a non-zero value to cancel the operation.
◆ setOnLogMessage()
void VRay::VRayRenderer::setOnLogMessage ( void(*)(VRayRenderer &, const char *msg, MessageLevel level, double instant, void *userData)  callback,
MessageLevel  minLevel = MessageInfo,
Set callback function for the event when V-Ray logs a text message. Callback arguments: renderer - The renderer which produced the event msg - The log message text level - Type of message, e.g. info, warning, error instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnPostEffectsUpdated()
void VRay::VRayRenderer::setOnPostEffectsUpdated ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when a new post-processed (denoised, lens effects) image is available. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnProgress()
void VRay::VRayRenderer::setOnProgress ( void(*)(VRayRenderer &, const char *msg, int elementNumber, int elementsCount, double instant, void *userData)  callback,
Set callback function for the event when V-Ray updates its current computation task and the number of workunits done. This is usually used to implement progress bars. Callback arguments: renderer - The renderer which produced the event msg - The title of the ongoing task elementNumber - Number of work items processed so far elementsCount - Total number of work items for the task instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnProgressiveImageUpdated()
void VRay::VRayRenderer::setOnProgressiveImageUpdated ( void(*)(VRayRenderer &, VRayImage *img, unsigned long long changeIndex, ImagePassType pass, double instant, void *userData)  callback,
Set callback function for the event when an updated image is available in progressive rendering mode. Callback arguments: renderer - The renderer which produced the event img - A copy of the image buffer. This is deleted internally after the callback (unless setKeepProgressiveFramesInCallback(true) was called) pass - Which render pass generated the image changeIndex - A linearly growing index reflecting the number of changes applied to the scene in interactive mode. Corresponds to value returned by commit(). instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnRendererClose()
void VRay::VRayRenderer::setOnRendererClose ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the VRayRenderer object is destroyed. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnRenderViewChanged()
void VRay::VRayRenderer::setOnRenderViewChanged ( void(*)(VRayRenderer &, const char *propName, double instant, void *userData)  callback,
Set callback function for the event when the RenderView (camera) plugin has changed in interactive mode. Callback arguments: renderer - The renderer which produced the event propName - name of the RenderView parameter that was changed instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnStateChanged()
void VRay::VRayRenderer::setOnStateChanged ( void(*)(VRayRenderer &, RendererState oldState, RendererState newState, double instant, void *)  callback,
Set callback function for transitions between rendering states. See enum RendererState. Callback arguments: renderer - The renderer which produced the event oldState - The state before this event newState - The new state as of the time of the event ocurrence instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnUploadToCollaboration()
void VRay::VRayRenderer::setOnUploadToCollaboration ( int(*)(VRayRenderer &, const std::vector< std::string > &fileList, double instant, void *)  callback,
Set callback function for the upload to collaboration callback. Callback arguments: renderer - The renderer which produced the event fileList - an array holding the paths to the files that should be uploaded instant - Relative time of the event in seconds since V-Ray initialization return - The callback has to return true if the files should be deleted, or false if they should be kept
◆ setOnVFBAddRenderElementToScene()
void VRay::VRayRenderer::setOnVFBAddRenderElementToScene ( bool(*)(VRayRenderer &, VFBRenderElementType type, double instant, void *userData)  callback,
Set callback function for the event when the "Add 'Render Element' to the scene" VFB button is pressed. The button does nothing by default. Callback arguments: renderer - The renderer which produced the event type - The type of the render element. Can be renderElementType_lightMix or renderElementType_denoiser. instant - Relative time of the event in seconds since V-Ray initialization return - The callback has to return true on success and false on an error
◆ setOnVFBCameraSelection()
void VRay::VRayRenderer::setOnVFBCameraSelection ( void(*)(VRayRenderer &renderer, int itemId, VFBSourceButton sourceButton, void *userData)  callback,
Set callback function for camera selection popup menu shown when starting a render Callback arguments: renderer - The renderer which produced the event itemId - The index of the menu item clicked sourceButton - The button associated with the popup that was clicked
◆ setOnVFBClick()
void VRay::VRayRenderer::setOnVFBClick ( void(*)(VRayRenderer &, VFBMouseButton button, int x, int y, bool ctrl, bool shift, void *userData)  callback,
Set callback function a mouse button is pressed within the VFB render area. Callback arguments: renderer - The renderer which produced the event button - the mouse button that was pressed x - X coordinate of the click y - Y coordinate of the click ctrl - true if the ctrl button was down when the click occured shift - true if the shift button was down when the click occured
◆ setOnVFBClosed()
void VRay::VRayRenderer::setOnVFBClosed ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the VFB window is closed. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBCopyToHostFrameBufferNotify()
void VRay::VRayRenderer::setOnVFBCopyToHostFrameBufferNotify ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the "Duplicate to host frame buffer" VFB button is pressed. Callback arguments: instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBDebugShadingNotify()
void VRay::VRayRenderer::setOnVFBDebugShadingNotify ( void(*)(VRayRenderer &, int enabled, DebugShadingMode mode, int selectionLocked, double instant, void *userData)  callback,
Set callback function for the event when VFB IPR Debug Shading is enabled or its mode is changed. Callback arguments: enabled - Whether Debug Shading is enabled or disabled mode - The Debug Shading mode chosen selectionLocked - Whether selection is locked. Considered only when mode is isolateSelect instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBInteractiveStart()
void VRay::VRayRenderer::setOnVFBInteractiveStart ( void(*)(VRayRenderer &, bool isRendering, double instant, void *userData)  callback,
Set callback function for the event when the "Start IPR" VFB button is pressed. Callback arguments: renderer - The renderer which produced the event isRendering - false if the renderer was idle/stopped instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBLayersChanged()
void VRay::VRayRenderer::setOnVFBLayersChanged ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the VFB color corrections or compositing layers have changed. Note that this callback may be called multiple times in short time, when a parameter is changed by a slider. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBOpenUpdateNotify()
void VRay::VRayRenderer::setOnVFBOpenUpdateNotify ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the user clicks the update available notification in VFB. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBPauseIPR()
void VRay::VRayRenderer::setOnVFBPauseIPR ( void(*)(VRayRenderer &, bool isRendering, double instant, void *userData)  callback,
Set callback function for the event when the "Pause IPR" VFB button is pressed. The button pauses the rendering by default. Callback arguments: renderer - The renderer which produced the event isRendering - false if the renderer was idle/stopped instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBRenderLast()
void VRay::VRayRenderer::setOnVFBRenderLast ( void(*)(VRayRenderer &, bool isRendering, double instant, void *userData)  callback,
Set callback function for the event when the "render last" VFB button is pressed. Callback arguments: renderer - The renderer which produced the event isRendering - false if the renderer was idle/stopped instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBSaveSettingsNotify()
void VRay::VRayRenderer::setOnVFBSaveSettingsNotify ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when some settings have been changed from VFB UI. Callback arguments: instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBShowMessagesWindow()
void VRay::VRayRenderer::setOnVFBShowMessagesWindow ( void(*)(VRayRenderer &, double instant, void *userData)  callback,
Set callback function for the event when the message window button in the VFB is clicked. Callback arguments: renderer - The renderer which produced the event instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVFBUpdateIPR()
void VRay::VRayRenderer::setOnVFBUpdateIPR ( void(*)(VRayRenderer &, bool isRendering, double instant, void *userData)  callback,
Set callback function for the event when the "Update IPR" VFB button is pressed. The button restarts the rendering by default. Callback arguments: renderer - The renderer which produced the event isRendering - false if the renderer was idle/stopped instant - Relative time of the event in seconds since V-Ray initialization
◆ setOnVRayProfilerWrite()
void VRay::VRayRenderer::setOnVRayProfilerWrite ( void(*)(VRayRenderer &, const std::string &outputFile, int fileType, double instant, void *)  callback,
Set callback function for the profiler output write to be called when the output is finished. Callback arguments: renderer - The renderer which produced the event outputFile - an array holding the paths to the files that should be uploaded fileType - The type of the file being saved, one of the values of the VRayProfilerSettings::FileType enum instant - Relative time of the event in seconds since V-Ray initialization
◆ setProgressiveImageUpdatedDataType()
void VRay::VRayRenderer::setProgressiveImageUpdatedDataType ( RenderElement::Type  renderChannel = RenderElement::AUTO,
RenderElement::DataIntent  intent = RenderElement::DI_INTENT_VIEWPORT_IPR,
bool  hasAlpha = true,
bool  flipImage = false
Sets what type of image data the ProgressiveImageUpdated callback will receive as its VRayImage parameter
renderChannelThe render channel used as source for the image. AUTO means automatic mode. In automatic mode the renderer will select and pass to the callback the best image available by automatically choosing between the main COLOR (RGB) channel and EFFECTS_RESULT. This is the default and recommended option. NONE will disable image passing (nullptr will be passed as image argument).
intentThe desired image DataIntent. In most cases the default DI_INTENT_VIEWPORT_IPR is the best option so that the received image will have all color corrections applied but the colors will be kept linear and sRGB or gamma correction will be applied only when 8 or 16-bit bitmap data is exctracted.
hasAlphaShould the alpha channel be included in the image.
flipImageFlip the image upside down.
◆ setProgressiveImageUpdateDifference()
float VRay::VRayRenderer::setProgressiveImageUpdateDifference ( float  difference)
Sets the difference threshold for emitting a progressiveImageUpdated event. If V-Ray produces an image below the threshold, the event will not be emitted. The initial threshold value is 2.0.
◆ setProgressiveImageUpdateTimeout()
unsigned long VRay::VRayRenderer::setProgressiveImageUpdateTimeout ( unsigned long  timeout)
Set the maximum time before emitting a progressiveImageUpdated event. If the timeout is reached, an image will be emitted even if it's the same as the previous update.
Returns
The previous timeout value
◆ setRenderMode()
bool VRay::VRayRenderer::setRenderMode ( RenderMode  mode)
Changes the render mode if the renderer is in an idle state. If a rendering is in process, it will not be affected. You can switch between Production and Interactive mode with this without clearing the scene.
Returns
True if the render mode has been successfully changed; check getLastError() otherwise.
◆ setRenderRegion()
bool VRay::VRayRenderer::setRenderRegion ( int  rgnLeft,
int  rgnTop,
int  rgnWidth,
int  rgnHeight
Sets the rendering region within the image width and height. (width and height are the rendering sizes set by other methods or constructors, etc.) Set to an invalid size, like (0, 0, 0, 0), to reset the region and render the whole image. This (creates if necessary and) changes SettingsOutput in the scene. The size is reset after clearing the scene or loading another scene file.
◆ setRenderSizes()
bool VRay::VRayRenderer::setRenderSizes ( const RenderSizeParams &  sizes,
bool  regionButtonState
Sets the frame buffer width and height, the rendering region and the crop region.
sizesStructure of all applicable parameters and a bitmask which indicates which ones to be set.
regionButtonStatethe new state of the VFB's region button if applicable.
◆ setResumableRendering()
bool VRay::VRayRenderer::setResumableRendering ( bool  enable,
const ResumableRenderingOptions *  options
Use this to enable resumable rendering before starting a render.
enableWhether to enable or disable for this VRayRenderer
optionsoptional additional settings. Passing nullptr is valid.
Returns
◆ setUpdatedDefaultProperties()
bool VRay::VRayRenderer::setUpdatedDefaultProperties ( )
Updates all default (unmodified) properties in the scene to updated values based on UI Guides. The original defaults remain as they are for compatibility reasons.
◆ setUserCameraChangedCB()
void VRay::VRayRenderer::setUserCameraChangedCB ( void(*)(const UserCameraChanged *info, void *userData)  cb,
void *  userData
NOTE: Available in DR2 only. Requires LiveLink to be enabled Installs (or replaces a previously installed) callback to listen for events related to changed camera properties in a connected downstream LiveLink partner. The callback shouldn't assume any particular thread
cbthe callback to be installed
userDataany required user data, will be passed unmodified
◆ setUserLightChangedCB()
void VRay::VRayRenderer::setUserLightChangedCB ( void(*)(const UserLightChanged *info, void *userData)  cb,
void *  userData
NOTE: Available in DR2 only. Requires LiveLink to be enabled Installs (or replaces a previously installed) callback to listen for events related to changed light properties in a connected downstream LiveLink partner. The callback shouldn't assume any particular thread
◆ setUserNodeChangedCB()
void VRay::VRayRenderer::setUserNodeChangedCB ( void(*)(const UserNodeChanged *info, void *userData)  cb,
void *  userData
NOTE: Available in DR2 only. Requires LiveLink to be enabled Installs (or replaces a previously installed) callback to listen for events related to hiding, showing and transforming (rotation and position) properties of a scene light, camera or geometry node in a connected downstream LiveLink partner. The callback shouldn't assume any particular thread
◆ setUserSceneName()
void VRay::VRayRenderer::setUserSceneName ( const char *  sceneName)
Sets the current scene name. Currently used as metadata in some places
sceneName- the name to be set. A copy is made internally, so the lifetime of the string is not a concern.
◆ setVFBCameraSelectionItems()
void VRay::VRayRenderer::setVFBCameraSelectionItems ( const std::vector< const char * > &  items)
Set the menu items for camera selection popup menu shown when starting a render Setting an empty array disables the menu
◆ setVFBContextMenuItemValue()
bool VRay::VRayRenderer::setVFBContextMenuItemValue ( int  commandId,
int  value
Set the value of a VFB context menu checkbox item.
valuevalue to set. 0 means cleared and 1 means ticked.
Returns
◆ setVFBContextMenuSelectedCallback()
void VRay::VRayRenderer::setVFBContextMenuSelectedCallback ( void(*)(VRayRenderer &, int commandId, int x, int y, void *userData)  callback,
Set the callback function to handle the custom context menu items commands. Callback arguments: renderer - The renderer which produced the event commandId - ID of the command x - the X component of the position, where the context menu is called y - the Y component of the position, where the context menu is called
◆ setVRayProfiler()
void VRay::VRayRenderer::setVRayProfiler ( const VRayProfilerSettings &  settings)
Sets up the VRay Profiler. Should be called as early as possible (e.g. before rendering start), otherwise it will have no effect. If you want to record other events diffrent from the default ones, you must start the profiler manually through profilerInitializeManually and use the ProfilerDurationScope class or profiler* methods in the API.
settings- The settings, which contain the requested VRayProfiler operational mode, outputDirectory, max depth and other metadata
◆ start()
void VRay::VRayRenderer::start ( ) const
Begins the rendering process in a separate thread. A non-blocking call. Scene changes and DR host changes are forbidden until the StateChanged event transitions out of PREPARING state.
◆ startSync()
int VRay::VRayRenderer::startSync ( ) const
Begins the rendering process in a separate thread. Blocks until the preparation stage is complete and rendering has actually started.
Returns
0 - no error; check getLastError() if != 0
◆ tryLockScene()
bool VRay::VRayRenderer::tryLockScene ( )
Attempts to lock the scene, without blocking, for writing and reading If scene is locked, rendering stops and will not resume until unlockScene is called
See also
lockScene This is usefull when changes can be done only from the UI thread of the application. If locking fails then it can be attempted at a later time, allowing the UI thread to not block the UI.
Returns
true if the scene was locked, and false if not
◆ unlockScene()
void VRay::VRayRenderer::unlockScene ( )
Unlocks previously locked scene This must be called after the scene has been locked with lockScene or tryLockScene
◆ updateLightingAnalysis() [1/2]
bool VRay::VRayRenderer::updateLightingAnalysis ( )
Invokes an update to the lighting analysis render element. Requires RenderChannelLightingAnalysis to be present in the scene. This can be run while rendering is ongoing or when it's paused or after it is stopped. Lighting analysis parameters are taken from the RenderChannelLightingAnalysis plugin. The update is asynchronous, so the funtion will return as soon as the thread is started. When the channel is updated the postEffectsUpdated callback will be called.
Returns
true if the thread is started successfully and false if there is a problem with the parameters or renderer state.
◆ updateLightingAnalysis() [2/2]
bool VRay::VRayRenderer::updateLightingAnalysis ( VRay::Plugin  plugin)
Invokes an update to the lighting analysis render element. This can be run while rendering is ongoing or when it's paused or after it is stopped. The update is asynchronous, so the funtion will return as soon as the thread is started. When the channel is updated the postEffectsUpdated callback will be called.
pluginA RenderChannelLightingAnalysis plugin to read the lighting analysis parameters.
Returns
◆ useAnimatedValues()
void VRay::VRayRenderer::useAnimatedValues ( bool  on)
When enabled, setting parameter values will add keyframe values for animation. Otherwise the old value is just overwritten. The initial state is off.
◆ waitForRenderEnd() [1/2]
bool VRay::VRayRenderer::waitForRenderEnd ( const int  timeout) const
Waits for rendering to finish but no more than the specified timeout. If the keepInteractiveRunning flag is set, this event may occur without ending the render session.
timeoutin milliseconds
Returns
true if image has been rendered, false if timeout or error occurred.
◆ waitForRenderEnd() [2/2]
bool VRay::VRayRenderer::waitForRenderEnd ( const WaitTime  time = WaitTime::AwaitingOrIdle) const
Waits for rendering to finish, regardless of the outcome (success, cancel, error). If the keepInteractiveRunning flag is set and WaitTime::AwaitingOrIdle is passed this event may occur without ending the render session (when the renderer state becomes RENDERING_AWAITING_CHANGES or any of the idle states).
Returns
true if image has been rendered, false if an error occurred.
◆ waitForSequenceEnd() [1/2]
bool VRay::VRayRenderer::waitForSequenceEnd ( ) const
Waits for rendering of the sequence to finish, regardless of the outcome (success, cancel, error).
Returns
true if rendering of the sequence has finished successfully, false if an error occurred.
◆ waitForSequenceEnd() [2/2]
bool VRay::VRayRenderer::waitForSequenceEnd ( const int  timeout) const
Waits for rendering of the sequence to finish but no more than the specified timeout.
Returns
true if rendering of the sequence has finished, false if timeout or error occurred.
◆ waitForVFBClosed() [1/2]
bool VRay::VRayRenderer::waitForVFBClosed ( ) const
Waits for the VFB window to be closed or hidden.
Returns
true if VFB has been closed, false if an error occurred.
◆ waitForVFBClosed() [2/2]
bool VRay::VRayRenderer::waitForVFBClosed ( const int  timeout) const
Returns
true if VFB has been closed, false if timeout or error occurred.
The documentation for this class was generated from the following file:
