VRay SDK for C++
Used for GPU device selection by VRayRenderer::getComputeDevicesCurrentEngine() & co. More...
#include <vraysdk.hpp>
Public Types | |
| enum | Type { deviceType_default = (1 << 0) , deviceType_CPU = (1 << 1) , deviceType_GPU = (1 << 2) , deviceType_ACCEL = (1 << 3) } |
Public Attributes | |
| struct { | |
| int isSupported | |
| Is device supported. | |
| int useForDenoising | |
| Device is used for denoising. | |
| int useForRendering | |
| Device is used for rendering. | |
| Device type. | |
| int | busId |
| Bus ID. | |
| int | ccMajor |
| CUDA Compute Capability Major version number. | |
| int | ccMinor |
| CUDA Compute Capability Minor version number. | |
| int | cudaOrdinalIndex |
| Cuda ordinal index. | |
| long long | deviceHandle |
| Device handle. | |
| Type | deviceType |
| Device type. | |
| int | frequencyMHz |
| Base clock frequency or -1 if not available. | |
| int | gFlops |
| Theoretical GFLOPS. 0 or -1 if not available. | |
| int | gfxArchNum |
| HIP device architecture. | |
| int | isCpuEmulation |
| Is device CPU emulated. | |
| int | localIndex |
| Local index. | |
| std::string | name |
| Non-unique displayable name. Device index is its unique identifier. More... | |
| int | numConnectedDisplays |
| Number of displays (monitors) attached to this device. -1 if this information is unavailable. | |
| long long | platform |
| Platform. | |
| int | rtCoreVersion |
| The version of the raytracing cores (if supported). 0 if the GPU does not support RT Cores. | |
| int | shaderProcessorsCount |
| Shader processors count. | |
| int | tccMode |
| TCC mode. | |
| int | totalMemoryMB |
| MegaBytes. | |
| std::string VRay::ComputeDeviceInfo::name |
"Pick state"
