Provides static meta information about a specific Plugin type.
More...
#include <vraysdk.hpp>
| PluginMeta (const PluginMeta &pluginMeta)=default |
| bool | checkPluginUIGuides (std::string &errMsg) const |
PluginCategories | getCategories () const |
| | Returns all the plugin categories this plugin type belongs to, such as being a Light or a Material, etc.
const char * | getDeprecation () const |
| | Returns a deprecation string for this render plugin type. May be nullptr!
std::string | getDescription () const |
| | Returns a description for this render plugin type. May be empty.
GPUPluginSupport | getGPUSupport () const |
| | Returns to what extent the plugin is supported by V-Ray GPU.
PropertyMeta | getPropertyMeta (const char *propertyName) const |
| | Returns an object used to obtain meta information about a plugin property.
PropertyMeta | getPropertyMeta (const std::string &propertyName) const |
std::vector< std::string > | getPropertyNames () const |
| | Returns the names of all properties.
const char * | getType () const |
| | Returns the type (name of the class) of the plugin or nullptr on ivalid type.
PluginTypeId | getTypeId () const |
| | Returns the type id of the plugin.
bool | isValid () const |
| | Checks if the object is valid.
PluginMeta & | operator= (const PluginMeta &pluginMeta)=default |
bool | operator== (const PluginMeta &pluginMeta) const |
void | swap (PluginMeta &pluginMeta) noexcept |
| PluginMeta (const Plugin &plugin) |
| PluginMeta (const VRayRenderer *renderer, const char *typeStr) |
| PluginMeta (const VRayRenderer *renderer, PluginTypeId pluginTypeId) |
class | Plugin |
class | VRayRenderer |
◆ checkPluginUIGuides()
| bool VRay::PluginMeta::checkPluginUIGuides |
std::string & |
errMsg | ) |
const |
Check validity of the uiguide strings of a plugin's properties. Mainly for debug purpose.
- Parameters
| errMsg | A message explaining the error if such occurs. |
- Returns
- Returns true if all uiGuides of the plugin's properties are valid and false otherwise.
The documentation for this class was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
