VRay SDK for C++
Loading...
Searching...
No Matches
VRay::PropertyMeta Class Reference
Static meta information about a plugin property. More...
#include <vraysdk.hpp>
Inheritance diagram for VRay::PropertyMeta:
VRay::PropertyRuntimeMeta
Public Member Functions
 PropertyMeta (const PropertyMeta &propertyMeta)
StringList getAliases () const
 Returns a list of alias names of this property.
Value getDefaultValue () const
const char * getDeprecation () const
 Returns a deprecation string for this property. May be nullptr!
std::string getDescription () const
 Returns a short description of this property. May be empty.
int getElementsCount () const
 Returns the number of elements for the property if it is a list and -1 otherwise.
Type getElementType () const
 Returns the type of the property by definition or the type of the list elements when it's a typed list.
GPUParamSupport getGPUSupport () const
 Returns to what extent the property is supported by V-Ray GPU.
const char * getName () const
 Returns the primary name of this property.
Type getType () const
const char * getTypeAsString () const
std::string getUIGuides () const
UIGuides getUIGuidesObject () const
 Returns an object used to obtain meta information about a plugin property uiGuides.
 operator bool () const
 Returns true if the PropertyMeta is valid property meta, therefore can be used for valid checks of parameters.
PropertyMeta & operator= (const PropertyMeta &propertyMeta)
void swap (PropertyMeta &propertyMeta) noexcept
Static Public Member Functions
static const char * typeToString (const Type type)
Protected Member Functions
 PropertyMeta (const VRayRenderer *pRenderer, const char *pluginClassName, const char *propertyName)
Protected Attributes
GPUParamSupport gpuSupport
const void * pParamDef
Friends
class PluginMeta
Detailed Description
Member Function Documentation
◆ getDefaultValue()
Value VRay::PropertyMeta::getDefaultValue ( ) const
Returns the default value of this property. This will never be a list. For list types the default value of an element is returned, if any. The returned value will have TYPE_UNSPECIFIED if a default value is not available and the .isOK() method will return false.
◆ getType()
Type VRay::PropertyMeta::getType ( ) const
inline
Returns the type of the property value by definition. The runtime type may be slightly different for texture objects - they can be Plugin references or plain AColor, Vector, etc. values.
◆ getUIGuides()
std::string VRay::PropertyMeta::getUIGuides ( ) const
inline
Returns a short description of what the name of this property in UI should be, min and max values, etc. This information is not available for many properties.
The documentation for this class was generated from the following file:
