The settings passed to the VRayRenderer::setVRayProfiler() interface.
More...
#include <vraysdk.hpp>
std::string | htmlTemplatePath |
| | The full path to the profiler html template. If this is left empty, the default location will be searched.
int | maxDepth |
| | The maximum ray bounces that will be profiled. Range [1, 8].
Mode | mode |
| | Specifies the operational mode of the Profiler.
std::string | outputDirectory |
| | The directory where the profiler reports will be created. If nullptr is passed, temp directory is used.
std::string | productName |
| | Name of the host product.
std::string | productVersion |
| | Version of the host product.
std::string | sceneName |
| | Name of the scene that will be profiled. Used as a suffix to the generated filename.
◆ FileType
Possible output file types from the V-Ray profiler. They are not currently set directly, but the values are used by the OnVRayProfilerWrite callback.
| Enumerator |
| FileType_HTML | An html output file. Needs a valid htmlTemplatePath or valid installation of the default path.
| FileType_JSON | This is the raw profiler output, which is passed when an HTML file could not be generated.
◆ Mode
| Enumerator |
| Off | No profiling.
| Simple | Do not use, this mode will be mapped to Full mode.
| Full | Profile the whole rendering process.
| Process | Only profile the PREPARING state (e.g., plugin initialization, geometry compilation, etc).
The documentation for this struct was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
