VRay SDK for C++
Public Member Functions | |
| bool | isEnabled () const |
| bool | isHidden () const |
Public Member Functions inherited from VRay::UIGuides | |
| UIGuides (const UIGuides &uiGuides) | |
| int | getCountOfOverrides () const |
| std::string | getDisplayName () const |
| std::vector< std::string > | getEnableDepends () const |
| std::vector< EnumItem > | getEnumStrings () const |
| std::vector< std::string > | getFileAssetExts () const |
| std::vector< std::string > | getFileAssetNames () const |
| FileAssetOpType | getFileAssetOp () const |
| float | getFloat (const GuideType type) const |
| std::vector< float > | getFloats (const GuideType type) const |
| GPUParamSupport | getGPUSupportStatus () const |
| std::vector< std::string > | getHideDepends () const |
| QuantityTypeEnum | getQuantityType () const |
| std::string | getRolloutName () const |
| std::vector< std::string > | getStringEnumStrings () const |
| std::string | getTabName () const |
| TierType | getTier () const |
| UnitsType | getUnits () const |
| std::string | getValueOfOverriddenBy () const |
| std::string | getValueOfOverride (const int index) const |
| bool | hasAttribute (const AttributesType attributeType) const |
| bool | hasEnabledCondition () const |
| bool | hasHiddenCondition () const |
| bool | hasOverriddenBy () const |
| bool | hasOverride () const |
| bool | hasType (const GuideType type) const |
| bool | isEnum () const |
| bool | isStringEnum () const |
| UIGuides & | operator= (const UIGuides &uiGuides) |
Protected Member Functions | |
| RuntimeUIGuides (const void *pParamDef, const Internal::VRayRendererNative *renderer, InstanceId id) | |
Protected Member Functions inherited from VRay::UIGuides | |
| UIGuides (const void *pParamDef) | |
| const void * | getParamDef () const |
Friends | |
| class | PropertyRuntimeMeta |
Additional Inherited Members | |
Public Types inherited from VRay::UIGuides | |
| enum | AttributesType { None = 0 , ObjectSet = 1 , TextureSlot = 2 , LightSet = 4 , PartOf3dsMaxTriple = 8 , BitSet = 16 , Boolean = 32 } |
| Used to specify some additional attributes for the parameter. More... | |
| enum | FileAssetOpType { Load , Save , LoadAndSave } |
| enum | GuideType { Enum , Enable , DisplayName , MinValue , MaxValue , SpinStep , Units , FileAsset , Attributes , StringEnum , FileAssetNames , FileAssetOp , StartRollout , StartTab , SoftMinValue , SoftMaxValue , QuantityType , OverridenBy , Overrides , GPUSupport , Tier , Hide , DefaultValue , MaxGuides } |
| UIGuides supported property types. More... | |
| enum | QuantityTypeEnum { Unknown , Distance , Angle , LocalSubdivs } |
| Defines the quantity type that the parameter represents. More... | |
| enum | TierType { Basic = 0 , DefaultTier = 1 , Advanced = 2 } |
| enum | UnitsType { DefaultUnits , Radians , Degrees , Millimeters , Centimeters , Meters } |
| bool VRay::RuntimeUIGuides::isEnabled | ( | ) | const |
Evaluates whether the enabled condition holds with the current values of the parameters of the plugin.
| bool VRay::RuntimeUIGuides::isHidden | ( | ) | const |
Evaluates whether the hidden condition holds with the current values of the parameters of the plugin.
