| enum | Error { NO_ERR = 0
, BAD_LIBRARY_FILE = 1
, SDK_BROKEN = 3
| ScannedMaterialInfo (const char *pluginLibPath=nullptr) |
| ScannedMaterialInfo (const std::string &pluginLibPath) |
| Error | getError () const |
| bool | getInfo (const char *filename, std::string &info) const |
bool | getInfo (const std::string &filename, std::string &info) const |
| | This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
| bool | getPreset (const char *filename, ScannedMaterialPreset &result) const |
bool | getPreset (const std::string &filename, ScannedMaterialPreset &result) const |
| | operator bool () const |
| bool | operator! () const |
◆ getError()
| Error VRay::ScannedMaterialInfo::getError |
const |
If exeptions are disabled, check if the ScannedMaterialInfo constructor has been able to load the vray_BRDFScanned dynamic library.
- Returns
- Error
◆ getInfo()
| bool VRay::ScannedMaterialInfo::getInfo |
const char * |
filename, |
std::string & |
info |
| const |
Get information string about the file content.
- Parameters
| filename | The name of the file containing the scanned material data. |
| info | [out] Info string. |
- Returns
- true - success, false - failure.
◆ getPreset()
| bool VRay::ScannedMaterialInfo::getPreset |
const char * |
filename, |
ScannedMaterialPreset & |
result |
| const |
Get preset values of the scanned material.
- Parameters
| result | [out] Structure filled in with preset data. |
- Returns
◆ operator bool()
| VRay::ScannedMaterialInfo::operator bool |
const |
- Returns
- true - ok, false - error.
◆ operator!()
| bool VRay::ScannedMaterialInfo::operator! |
const |
If exeptions are disabled, check if the ScannedMaterialInfo constructor hasn't been able to load the vray_BRDFScanned dynamic library.
The documentation for this class was generated from the following file:
- /home/jenkins/ci/cgrepo/appsdk/VRay_SDK_CPP/include/vraysdk.hpp
