Scene provided by Evermotion
Official Release
Date - December 7, 2023
New Features
Geometry
  • Support for V-Ray Fur, Ornatrix, Hairfarm, and XGen hair.
  • Support for V-Ray Displacement.
  • Support for new V-Ray 6.2  Forest pack and Rail clone instancing.
Materials
  • Support for V-Ray Hair Next material.
Hardware
  • Support for Intel Meteor Lake iGPU.
Batch rendering
  • Render Setup options and render queue items are now stored in the .vantage file.
UI/UX
  • Implemented a warning and error count indicator in the status bar.
Rendering
Modified
Geometry
  • Improved GPU peak memory usage when loading the geometry for a scene.
  • Improved check for failed geometry allocations.
DLSS
  • Improved DLSS - added 2.25x and 3x upscale modes (available when Secondary (when static) denoiser is set to Same as Primary).
  • Reduced memory usage.
Denoiser
Scene States
  • Properly update the Scene States helper message on undo/redo.
  • Update scene state button now creates necessary sub-states if ORIGINAL SCENE or SAVED SCENE is currently chosen.
  • Detected changes for scene states when modifying a New file.
Navigation
  • Improved Orthographic camera navigation. Now Navigate around cursor ray hit and Navigate around selection work properly.
UX/UI
  • Improved Viewport Fill - now filter is disabled when sharpness is set to 0.
  • Improved DPI scaling on 150% and similar ratios.
Fixes
Geometry
  • Crash when loading invalid Instancer2 with missing node reference.
UI/UX
  • Bug with wrong UI slider ranges.
  • Wrong trimming of the scene animation track.
  • Auto-exposure and noise mask overlay while using Intel GPUs for rendering.
  • Wrong reloading of a saved .vantage file, with imported .vrscene.
  • Animated cameras from imported vrscenes are not loaded with animation after reload of .vantage file.
  • Wrong camera grouping on import.
Textures
  • Missing texture UVs if their UVW generator is missing.
Output
  • Wrong baking of Exposure bias in EXR when exposure correction is disabled.
  • Camera white balance not getting saved in EXR.
