Version 1 Next »
New Features
Materials
  • Support for rendering V-Ray Blend Material (BRDFLayered).
Render element
UI/UX
Output
Modified
Displacement
  • Improved memory used for displacement by varying tessellation level within a mesh.
Denoiser
  • Updated Intel Open Image Denoise to version 2.2.
Light Cache
  • Improved Light Cache to slightly better preserve low intensity samples.
UI/UX
  • Chaos Cosmos Browser UI responsiveness.
Fixes
Displacement
  • Random displacement when using unsupported secondary UV channel of the geometry object.
Scene states
  • Broken sub-states after dropping Environment texture.
  • Wrong Live Link update for Nodes with unsupported materials.
  • Wrong rendering of Glossy Refraction with rotated texture during Live Link with Rhinoл
Lights
  • Sun azimuth rotation values to match geographical azimuth. Old saved .vantage files will be automatically updated to use new values on Save.
Collision
  • Missing "Height ratio" update when collision "Height tolerance" is changed.
Clouds
  • Wrong cloud shading with sun slightly under the horizon.
Lighting
  • Wrong lighting when rendering using direct light reservoir resampling and the scene contains a normal map.
  • Refraction artifacts when rendering with direct light reservoir resampling.
UI/UX
  • Disappearing toolbar in the Debug Log window after second opening.
  • Hiding of the HQ rendering dialog while "Always on top" is enabled.
Denoiser
  • Streak artifacts with Optix denoiser and multi GPU setup.
  • Broken temporal (“reduce flickering”) denoising in multi GPU mode.
