This page provides information on using Chaos Scatter with Corona for 3ds Max.
You are viewing a technical documentation of Chaos Scatter for Corona for 3ds Max. To learn more about usage examples, troubleshooting, and using Chaos Scatter with other features of Corona, please see this Help Center article.
Chaos Scatter lets you quickly and efficiently populate surfaces, splines, and volumes with vast numbers of objects. Its major features include:
  • A library of ready-to-use presets available in Chaos Cosmos
  • Ability to edit individual instances
  • Edge trimming (removing any elements of scattered models which stick outside of the defined area)
  • Slope limiting for the scattered instances (no trees growing out of cliffs)
  • Including/excluding scattering areas using splines (closed or open)
  • Surface color map (coloring scattered instances based on pattern textures on rugs, etc.)
  • Limiting scattering only inside camera field of view (camera clipping)
  • Efficient viewport display
  • and more...
We are constantly developing Chaos Scatter! For our future plans, please see Scatter Tentative Road Map - 3ds Max
In case of using Corona 8 or newer and opening a scene made with Corona 7 or olderany legacy Corona Scatters in that scene will be automatically converted to Chaos Scatters. Because of multiple improvements in Chaos Scatter and changes in the way it works, the rendered results may differ between the older and the newer version of the scene.
UI Path: ||Scatter Toolbar|| > Chaos Scatter button
||Command panel|| > Create tab > Geometry > Chaos Scatter > ChaosScatter button
Tutorial: Using Chaos Scatter with Corona for 3ds Max
Objects
Distribute-on target objects – List of scene objects used as the base for distributing the scattered instances.
"+" button - Allows picking scene objects.
"-" button
- Removes the highlighted object from the list.
"[...]" button
– Opens a dialog where you can manually add and remove scene objects to the list.
Factor – Available only in Random Surface and Bounding Box scattering. In either case, if the scattering is defined just by the Count option, it works as a relative weight factor determining how many instances get scattered for the currently selected distribute-on object. Alternatively, in case of scattering instances to reach some density defined by Count and Per square/cube options, it works as a density factor (multiplier) affecting the final density there.
Instanced model objects – List of scene objects which are being scattered on the distribute-on objects.
"-" button - Removes the highlighted object from the list.
"[...]" button – Opens a dialog where you can manually add and remove scene objects to the list.
 Frequency – Available only if there is more than one instanced object. Sets the frequency of the currently selected instanced object relative to others.
Example: Objects
In case of scattering trees on the ground, the tree models are used as Instanced model objects and the ground plane is used as the Distribute-on target object.
Scattering
Enable – Enables the scattering.
Scattering type drop-down:
1D - On splines – Scatters instances along splines. Works with both open and closed splines.
2D - On surfaces – Scatters instances on the surface of the selected objects. Works with closed splines too, treating the spline area as the surface to scatter on.
3D - In bounding box – Scatters instances inside the bounding boxes of the selected objects.
Max. limit – Limits the maximum number of scattered instances. Note that there is always another mode-dependent parameter (spacing, density, or count) which determines how many instances to scatter. This parameter is intended as a constant value "safety measure" to prevent crashes/freezes from scattering too many instances, e.g. when setting the density too high.
Random seed – Determines the particular random distribution used. Changing the value makes random permutations of the scattered objects.
Temporal consistency – When enabled, instances get scattered in the selected Rest-pose frame and stick to the surface even if it deforms in other frames. When disabled, instances get scattered in each frame from scratch, which may lead to instances popping in and out. If it is combined with the Avoid collisions option, non-colliding instances in the Rest-pose frame are still allowed to collide in other frames.
Rest-pose frame – Specifies the frame with which the scattering is consistent at all other frames.
Avoid collisions – When enabled, the instances which collide with other ones are discarded, resulting in no overlaps between instances. Note that when using this feature, the real number of created instances may be lower than the number specified in the settings.
Spacing – This value is a multiplier for enlarging/shrinking the bounding boxes used to detect and remove collisions of the scattered objects. Use lower values to achieve a higher density of the scattered objects at the cost of some minor collisions. Use higher values to keep scattered objects farther apart from each other.
Edit Instances – Switches to Instances sub-object mode, allowing you to override individual instances in the viewport. You can move, rotate, scale, or delete them. It is not effective in great scale, but may serve well for final touches of small amount of instances.
Convert to Max geometry – Replicates this scatter using 3ds Max instances. This is usable only for a small number of objects.
Scatter Lister – Shows a lister allowing to inspect and control all scatter objects in the scene.
Example: Scattering
Scattering mode: 1D - On splines
Scattering mode: 2D - On surfaces
Scattering mode: 3D - In bounding box
Camera Clipping
Enable – When enabled, scattering is limited only to the camera view and instances which are not visible are clipped away. It is an optimization - it may improve scene parsing performance and lower memory requirements, however it can cause missing reflections/shadows. To compensate for this you can use the Extend view parameter.
Active render camera – Clips the instances based on the camera view used for rendering. The clipping is not visible in the viewport, unless changing clipping parameters or running IR. This is because otherwise the clipping would be too intrusive during regular scene work.
"None" object picker – Uses a selected camera for the clipping. In this case, the clipping is always visible.
Extend view – Specifies a uniform extension to the camera view in all directions (as distance), adding an extra zone beyond the camera view (behind the camera too) where the instances are not clipped. This is useful for ensuring correct shadows or reflections from instances that would otherwise be clipped.
Near and Far overrides – Specifies the near and far threshold distances from the camera. Instances close than the "near" value and farther than the "far" value are clipped away.
Example: Camera Clipping
Camera clipping disabled
Camera clipping enabled
Camera clipping enabled and "Extend view" set to 5 meters
With camera clipping disabled, the ground plane is fully covered with the scattered instances. When camera clipping is enabled, it limits the instances to the visible area only. The Extend view option can be used to expand the area where the instances are visible. This is useful, for example, to make sure that trees growing close to the camera are not removed.
In this example, the colors of the trees change between different renders, because when using the Corona Multimap, the distribution of colors depends on the current number of instances. Since we are changing the number of instances by removing some of them, the Multimap produces different "patterns".
Surface Scattering
Random distribution – Scatters randomly on all mesh and closed spline distribution objects.
Count – Defines an exact number of instances to scatter - either overall, or per area in the case of scattering defined by density (Per square option). The number is always limited by the Max. limit option.
Per square – When enabled, the number of instances to scatter is defined by density (Count per square having the given edge length). The number of instances is always limited by the Max. limit option. The specified value is the edge length of a square defining an area for computing the scatter density. The length is measured in world units.
Map – Specifies a texture map used for instance distribution. White areas of the texture are treated as maximum density and black areas are treated as areas with no instances.
UV map – Uses the distribution objects' UVW mapping to scatter the instances in regular patterns.
Pattern – Choose which pattern to use for scattering:
Grid Rectangular grid.
Running grid – Rectangular grid with every other row offset by half of the grid spacing.
Hex grid – Hexagonal point arrangement.
UV Channel – Specifies which of the UV channels of the distribution objects to consider.
Override by planar mapping – When enabled, simple planar UVW mapping is applied to the distribution object and used instead of its existing UVW channel.
Lock V – Locks the V coordinate for Spacing, Jitter, and Offset to the same value as the U coordinate.
Spacing – Scales the pattern in UV space - 100% spacing makes the pattern occupy the whole 0-1 UV space; with 50% spacing the pattern gets repeated 2 times in both U and V, etc.
Jitter – Randomly jitters each instance in the the U or V axis, with 0% being entirely deterministic placement (no jitter) and 100% being entirely random placement.
Offset – Offsets the pattern in the UV space. Each 100% added or subtracted moves the pattern by one entire repetition - which means that e.g. 0% and 100% offsets yield the same result.
Slope Limitation – Uses the slope (angle) of the distribution object's surface to limit the scattering.
Angle – Defines the range of angles, measured in degrees between either the Local or the World up vector and the surface normal, to which scattering is limited. Instances scattered outside of this range get filtered out.
Local – The up vector of each individual distribute-on object is used to define the slope limitation.
World – The world Z-axis up vector is used for all distribute-on objects to define the slope limitation.
ExampleSurface Scattering
Random distribution
UV map distribution
UV map distribution with Slope limitation from 0 to 20 degrees
Transformations
Translation
From - To – Specifies the translation range for X, Y, and Z axes, in world units.
Map – Specifies the texture map to use for translation.
Mode – Decides how the Map is interpreted to control the translation. RGB maps can be used to control translation in specific axes. Grayscale maps control translation proportionally in all axes.
Map fixed – Black areas of the map represent the From values. White areas represent the To values. Map areas with shades between black and white represent the values between From and To. No randomization occurs.
Random amount – No randomization occurs in black areas of the map. Full randomization occurs in white areas of the map. From and To values specify the lowest and highest translation allowed for the randomization.
Stepping distance – When nonzero, switches the random translation from a continuous to a discrete one, with steps specified by this parameter value. The From and To are still used as bounds. This effect is used only for the selected axes.
Rotation
From - ToSpecifies the rotation range for X, Y, and Z axes, in degrees.
MapSpecifies the texture map to use for rotation.
ModeDecides how the Map is interpreted to control the rotation. RGB maps can be used to control rotation in specific axes. Grayscale maps control rotation proportionally in all axes.
Stepping angleWhen nonzero, switches the random rotation from a continuous to a discrete one, with steps specified by this parameter value. The From and To are still used as bounds. This effect is used only for the selected axes.
Preserve model rotation – When enabled, instances preserve the original rotation of their models (instanced objects). Otherwise, the original rotation is ignored.
Scale
From - ToSpecifies the scale range for X, Y, and Z axes, in percent.
MapSpecifies the texture map to use for scaling.
Mode – Decides how the Map is interpreted to control the scale. RGB maps can be used to control scale in specific axes. Grayscale maps control scale proportionally in all axes.
LegacyFrom and To values decide about the overall randomization and are then multiplied by the values of the Map. This means that black areas of the map are always interpreted as zero scale.
Stepping percentageWhen nonzero, switches the random scaling from a continuous to a discrete one, with steps specified by this parameter value. The From and To are still used as bounds. This effect is used only for the selected axes.
Uniform scale – When enabled, instances get scaled in all axes using the values for the X axis. When disabled, each axis uses independent values.
Preserve model scale – When enabled, instances preserve the original scale of their models (instanced objects). Otherwise, the original scale is ignored.
ExampleTransformations
No randomization
Randomized translation
Randomized rotation
Randomized scale
Areas
Spline includes – A list of splines where the instances are allowed to be scattered.
Spline excludes – A list of splines where the instances are not allowed to be scattered.
Spline include/exclude options
Near - Far – Falloff distance from the selected spline projected to the selected axis plane up to which all instances get included or excluded, depending on the type of the spline. Scale and density of instances between the near and far falloffs change linearly - from 1.0 to 0.0 in case of inclusion, and contrariwise in case of exclusion.
Scale – Scale factor further affecting instances between the near and far falloffs.
Density – Density factor further affecting instances between the near and far falloffs.
Projection – Based on which axis to project the spline include/exclude areas.
Example: Areas
Spline include
Spline exclude
Spline exclude - Near: 5m, Far: 10m, Scale: 0.5
Viewport Display
Instances
Previz type – Selects how to display scattered instances in the viewport. Affects viewport performance.
None – Instances are not displayed at all.
Dot – Each instance is displayed as a single dot.
Box – Each instance is displayed as a solid box.
Wire box – Each instance is displayed as a wire box.
Full – Each instance is displayed as the full mesh.
Point cloud – Displays each instance as a point cloud.
Max instances – Maximum number of scattered instances being displayed in the viewport. When this limit gets exceeded, some instances are randomly hidden. If increasing this number would display more instances, the label is colored.
Max polygons – Maximum number of polygons (forming scattered instances) being displayed in the viewport. When this limit gets exceeded, some instances are randomly hidden. If increasing this number would display more instances, the label is colored.
Points – Percentage of points to display when Point cloud representation is selected in the Previz type selection.
Original wire colors – Selects whether to use wire colors of original instances objects when displaying their instances as dots, point clouds, or wire boxes in the viewport.
Icon size – Sets the display size of the selected Scatter object's gizmo.
Update automatically – Forces re-computation of the scattering.
ExampleViewport Displays
Previz Type
None
Dot
Box
Wire box
Full
Point cloud
Spline Scattering
This rollout is only available when "1D - On splines" mode is selected in the Scattering rollout.
Spacing – Sets spacing between scattered instances measured in world units.
Jitter – Randomly jitters every instance along the spline. The value means how much of the Spacing (half on each side) can be used to jitter around original position of each instance, e.g. 200% means that every instance jitters by up to the entire Spacing on the left and the entire Spacing on the right.
Offset – Moves all scattered instances along the spline. The value means by how much of the Spacing the instances shall move, e.g. 100% moves the first instance by entire Spacing so that it appears instead of the second one, the second one instead of the third one, etc.
Follow spline – Controls how scattered instances get oriented along the spline. With default 100% instances follow the spline and are oriented along local tangent direction. For 0%, instance orientations are unchanged.
Bounding Box Scattering
This rollout is only available when "3D - In bounding box" mode is selected in the Scattering rollout.
Count – Defines an exact number of instances to scatter - either overall, or per a volume in the case of scattering defined by density (Per cube). The number is always limited by the Max. limit.
Per cube – When enabled, the number of instances to scatter is defined by density (Count per cube having the given edge length). The number of instances is always limited by the Max. limit. The value specifies the edge length of the cube defining a volume for computing scattering density (Count, Per cube). The length is measured in world units.
Info
Stats
Instances – The total number of instances generated by the currently selected Scatter.
Polygons – The total number of polygons generated by the currently selected Scatter.
About Chaos Scatter – Shows the exact version of the currently installed Chaos Scatter plugin.
Chaos Scatter Maps
Edge Trimming Map
Default map – If a material is using some opacity texture in addition to the Edge Trimming map, this texture can be defined here.
The Edge Trimming Map can be used to trim the scattered objects so that they stay within the boundaries of the distribute-on objects or the include/exclude splines.
To learn more, see: How to use Chaos Scatter with Corona for 3ds Max
UI Path: ||Material Editor|| > Material/Map Browser > Maps > Chaos Scatter > ChaosScatterEdgeTrimming
Example: Edge Trimming Map
Edge Trimming Disabled
Edge Trimming Enabled
Surface Color Map
Source
Custom map – Uses a custom map as the surface color. You can then randomize this map's hue and gamma using the built-in controls.
Surface diffuse/base map
– Automatically uses the distribute-on object's diffuse/base map.
Hue random – Controls randomization of the resulting color hue. The value specifies maximal distance from the original hue (in range of 0-100%) where 0% disables hue randomization and 100% applies maximal hue randomization.
Gamma random – Adds additional randomization of mid-tones (gamma) to the result (in a range of 0-100%), where 0% disables randomization and 100% applies maximal reasonable gamma randomization.
The Surface Color Map automatically takes the diffuse color of the Chaos Scatter distribute-on object and passes it to the instances which are scattered on it. The map itself takes only the distribute-on diffuse color, but it can be applied to any material property of the scattered instance (e.g. roughness, opacity, self-illumination, or any other).
UI Path: ||Material Editor|| > Material/Map Browser > Maps > Chaos Scatter > ChaosScatterSurfaceColor
Example: Surface Color Map
Scattering disabled
Scattering enabled
