Loading
Once installed, you can start Chaos Vantage from the Start menu > Chaos Vantage > Start Chaos Vantage or search it directly in the Start menu.
You can also start it from its installation directory. The default directory is C:\Program Files\Chaos\Vantage where you can find and execute the vantage.exe file.
Note that for Vantage versions prior to 2.5, the default directory is C:\Program Files\Chaos Group\Vantage
If a silent installation is used without accepting the End User License Agreement and the Global Consumer Privacy Policy, you are prompted to accept them when loading in order to use Vantage.
Please enable the I accept checkboxes in order to proceed using the software.
