This page provides a library of cloud assets that are created using Chaos Phoenix.
Here we share a collection of volumetric caches for clouds, simulated using Chaos Phoenix. Each file in *.aur or *.vdb format contains a single frame that can be quickly loaded into your scene through a Phoenix Simulator or a VRayVolumeGrid. Furthermore, with the aid of Chaos Scatter, you can effortlessly craft a cloudscape for your project.
This table provides an overview of three different types of clouds, to help you better understand their appearance and characteristics.
Cumulus
Anvil
Stratus
Morphology
They have flat bases and are often described as "puffy" in appearance
A cumulonimbus cloud that has reached a level of stratospheric stability and has formed a characteristic flat, anvil-top shape.
Characterized by horizontal layering with a uniform base, as opposed to cumuliform clouds
Library
The downloadable cache files contain only volumetric data without any shading setup. To achieve the result from the screenshots below you can download the Cloud Render Preset from here.  To learn how to set up shading and assemble the volumetric data into a complete cloudscape scenery, you can follow the Cloudscape with Chaos Scatter tutorial.
Please note that the cloud assets provided are static. If you are searching for animated clouds, we recommend checking out the Animated Clouds tutorial.
Depending on your scene requirements you can pick the volumetric cache according to its grid resolution. For instance, if the cloud is positioned far away from the camera, lower grid resolution is recommended, while close up shots will require higher grid resolution.
Rendered imageNameCloud type
Grid resolution
Download link
1
Cumulus_ACumulus 138 623 940 voxels
Download .aur (325.5MB)
Download .vdb (1.58GB)
 2
Cumulus_BCumulus 78 044 280 voxels
Download .aur (181.3MB)
Download .vdb (911MB)
 3
Cumulus_CCumulus152 964 330 voxels
Download .aur (347.3MB)
Download .vdb (1.73GB)
4
Cloud_for_scatter_farCumulus6 885 348 voxels
Download .aur (18.3MB)
Download .vdb (83.4MB)
5
Cloud_for_scatter_nearCumulus63 977 643 voxels
Download .aur (442MB)
Download .vdb (1.56GB)
6
Anvil_CloudAnvil19 699 200 voxels
Download .aur (70.9MB)
Download .vdb (237.2MB)
7
Stratus_topStratus36 241 821 voxels
Download .aur (22.5MB)
Download .vdb (145.4MB)
8
Startus_bottomStratus36 241 821 voxels
Download .aur (43.6MB)
Download .vdb (215.8MB)
