This page provides information about the Bump Material in V-Ray for Blender.
The V-Ray Bump Material gives the ability to add bump map and normal map effects when using any material.
Connect a material into the V-Ray Bump to add additional bump or normal map functionality. Stacking multiple Bump materials together can create a more complex surface material by allowing the use of several bump and/or normal maps together easily.
Node Input Sockets
This section lists input sockets that are not found in the Parameters tab but only as inputs for the node.
Base Material – Allows the user to select the base material to which the bump/normal effect is added.
Bump Tex Color – Specifies the bump/normal texture node that is used.
Map Type – Allows the user to specify whether a bump map or a normal map effect is added to the base material.
Bump Map – Uses a bump map to determine the bump effect of the material.
Normal map in tangent space – Uses a tangent normal map to determine the bump effect on the material.
Normal map in object space – Uses an object space normal map to determine the bump effect on the material.
Normal map in screen space – Uses a screen space normal map to determine the bump effect on the material.
Normal map in world space – Uses a world space normal map to determine the bump effect on the material.
From texture bump output – Uses the texture bump output to determine the bump effect on the material.
Explicit normal
 Sets the normals to adhere to a specific value rather than being dependent on a face. As a result, any changes made to the position of a face do not affect the normals, which remain unchanged.
For more information on each Map Type, see the Bump and Normal Mapping in V-Ray.
Bump Multiplier – A multiplier for the bump/normal effect.
Bump Delta Scale – Scale for sampling the bitmap when using bump mapping. The exact value is calculated automatically by V-Ray, but can be scaled here.
Bump Shadows – When enabled, V-Ray considers the bump maps when rendering shadows produced by objects with the bump material applied to them.
When a texture with color corrections is used as a normal map, V-Ray displays a warning for unexpected results.
