This page provides information on the Virtual tour feature in Chaos Cloud Collaboration.
In Virtual Tour mode, you have the ability to add and edit interactive hotspots and highlights that guide you to specific points of interest within the tour. You can also leave comments to enhance the experience or provide context for others exploring the virtual space. Additionally, you have the option to initiate the virtual tour in Virtual Reality mode, allowing for a fully immersive experience where you can navigate through seamless panoramic transitions and feel as though you're truly present in the environment. This feature is designed to enhance engagement and provide a richer understanding of the space being explored.
Functionalities
Opens the Add new dropdown menu. From here, you can add Comments, Hotspots, Highlights, or new file Versions.
Opens the Comments menu.
Opens the Edit menu. From here, you can edit and create Hotspots and Highlights, and edit the Current file Settings
Opens the Virtual tour dropdown menu. This menu provides access to the file settings, file information, download, and sharing options.
Enters the Full-screen view mode.
Exits the Full-screen view mode.
Hides the Virtual tour Markers.
Shows the Virtual tour Markers.
Opens the Highlights menu.
Enables the Virtual Reality mode.
Displays the Floor plan minimap in the bottom right corner of the screen.
Opens the Floor plan image.
Virtual Tour
After creating a Virtual tour, it appears in the current project. Click on the Virtual tour to open it and add files.
Opens the Information menu.
Opens the Virtual tour comments menu.
Opens the Share project popup window.
Opens the Virtual tour Edit menu.
Starts the Virtual tour in full-screen.
Opens the Add files popup window. Select from already uploaded files in other projects or folders to add to the currently opened Virtual tour.
Uploads files from your computer. You can upload up to 10 files, 100 MB at a time. Supports: PNG, JPEG, WEBP, GIF, TIFF, AVIF and EXR files.
Sorts projects by Name, date Created on, or Modified on, or Custom order.
Inverts the order of items.
Equirectangular/spherical panoramas, cube and stereo panoramas (left-right & top-down types) are supported.
Files in Virtual Tours
Shows the file version.
Shows the number of comments for this file.
Opens the file options menu.
Rename – Edits the file name.
Move to – Moves this file to another location within the My projects space.
Copy file – Copies this file to another location within the My projects space.
Set as floor plan – Sets the image as the floor plan for this Virtual tour. Only a flat image can be set as the floor plan.
Upload new version – Uploads a new file version.
Download file (version) – Downloads a specific file version.
Delete file version – Deletes a specific file version.
Remove – Sends the file to the Trash.
Drag and drop files to change their order within a Virtual tour to create a custom arrangement.
