©BBB3viz
This page provides information on the Image Filter rollout under the V-Ray tab.
While the Image Sampler determines the overall approach to pixel sampling to produce the color for each pixel, the image filter sharpens or blurs the transitions between adjacent pixel colors.
Image filtering is particularly important when textures in the rendering include very fine detail. For a still image rendering, the image filter can sharpen these details to make them more visible and prominent, or blur the pixels to reduce Moiré patterns and other unwanted artifacts. For an animated sequence, the choice of image filter can blur pixels to reduce "buzzing" and flickering of detailed textures during playback.
UI Path: ||Render Setup window|| > V-Ray tab > Image filter rollout (Renderer set to V-Ray)
Image filter – Enables sub-pixel filtering of materials. When this option is disabled, an internal 1x1 pixel box filter is used. All image samplers support all 3ds Max's standard anti-aliasing filters except the Plate Match filter. Using filters increases rendering time.
Filter type – Specifies the filter type. For more information, see the Anti-aliasing Filters and Anti-aliasing Filters and Moire Effects examples below.
Avoid using filters with negative components (sharpening filters) like Catmull-Rom or Mitchell-Netravali when using the Progressive sampler. Doing so might dramatically increase render time as the sampler needs to take additional image samples to resolve the filter.
Size – Specifies the size of the image filter.
? button – Opens Chaos documentation on image filtering.
Example: Anti-aliasing Filters
Here is an example briefly demonstrating the effect of different anti-aliasing filters on the final result.
Note that rendering with a particular filter is not the same as rendering without a filter and then blurring the image in a post-processing program like Adobe Photoshop. Filters are applied on a sub-pixel level, over the individual sub-pixel samples. Therefore, applying the filter at render time produces a much more accurate and subtle result than applying it as a post effect. V-Ray can use all standard 3ds Max filters (with the exception of the Plate match filter) and produces similar results to the scanline renderer.
The Bucket image sampler was used for the images below.
FilterImageZoomed-in imageComments
Filtering is off
FilterOff
Filter_Off_Zoom-In
Applies an internal 1x1 pixel box filter.
Area filter, size 1.5 (default setting)
areafilter1.5
areafilter1.5_zoom
Slightly blurs the image, visually more pleasing than the box filter.
Area filter, size 4.0
area4
Area 4_Zoom-In
More blurring.
Blackman
blackman
blackman_zoom
Blend filter
blend_filter
blendfilter_zoom
Combination of a sharp and a soft filter, kind of dreamy effect.
Catmull-Rom
catmull_rom
catmullrom_zoom
Edge-enhancing filter, often used for architectural visualizations. Note that edge enhancing can produce "moire" effects on detailed geometry.
Cook Variable
cookvariable
cookvariable_zoom
Cook Variable is a general purpose filter. Values of 1 to 2.5 make the image sharp, and higher values make it blurred.
Cubic
cubic_filter
cubicfilter_zoom
This is a 25-pixel blurring cubic filter.
Mitchell-Netravali
Mitchell-Netravali
Mitchell-Netravali_zoom
Allows control between edge-enhancement and blurring.
MItchell-Netravali, ringing=1.5
Strong edge-enhancement.
Mitchell-Netravali, ringing=2.0
Even more edge enhancement; kind of cartoon-style effect.
Quadratic
quadratic
quadratic_zoom
This is a 9-pixel quadratic blurring filter.
Sharp Quadratic
Sharp Quadratic
Sharp Quadratic Zoom
This is a 9-pixel reconstruction filter, based on the work of Nelson Max.
Soften
Soften
Soften_zoom
Gaussian blur.
Video Filter
Video Filter
Video Filter_zoom
This is a 25-pixel blurring filter, optimized for NTSC & PAL video applications.
VRayLanczosFilter
VRayLanczosFilter
VRayLanczosFilter_zoom
This is V-Ray's implementation of the Lanczos image filter.
VRayBoxFilter
VRayBoxFilter
VRayBoxFilter_zoom
This is V-Ray's implementation of the Box image filter.
VRayTriangleFilter
This is V-Ray's implementation of the triangle image filter.
VRayMitNetFilter
VRayMitNetFilter
VRayMitNetFilter_zoom
V-Ray's implementation of the Mitchell-Netravali filter.
VRayMitNetFilter, ringing = 1.5
VRayMitNetFilter, ringing = 2
Example: Anti-aliasing Filters and Moire Effects
This example demonstrates the effect anti-aliasing filters have on moire effects in your images. Sharpening filters (Mitchell-Netralavli, Catmull-Rom) may enhance moire effects, even if your image sampling rate is very high. Blurring filters (Area, Quadratic, Cubic) reduce moire effects.
Note that moire effects are not necessarily a result of poor image sampling. In general, moire effects appear simply because the image is discretized into square pixels. As such, moire effects are inherent to digital images. The effect can be reduced through the usage of different anti-aliasing filters, but is not completely avoidable.
The scene is very simple: a sphere with a very fine checker map applied. The images were rendered with a very high sampling rate (15 subdivs, or 225 rays/pixel). This is enough to produce quite an accurate approximation to the pixel values. Note that the image looks quite different depending on the filter:
Image Filter off
Image Filter off
Area, size = 1.5
Area, size = 4.0
Blackman
Blackman
Blend
Blend
Catmull-Rom
Catmull-Rom
Cook Variable
Cook Variable
Quadratic
Quadratic
Sharp Quadratic
Sharp Quadratic
Cubic
Cubic
Video
Video
Soften
Soften
Mitchell-Netravali, default
Mitchell-Netravali, ringing = 1.5
Mitchell-Netravali, ringing = 2
VRayLanczosFilter
VRayLanczosFilter
VRayBoxFilter
VRayBoxFilter
VRayTriangleFilter
VRayTriangleFilter
VRayMitNetFilter, default
