Square Enix © Goodbye Kansas
This page provides information on the Coat Glossiness Render Element.
The Coat Glossiness Render element is analogous to the Reflection Glossiness Render Element. This channel holds a float number with the value set in the Coat Glossiness parameter in the VRayMtl Coat Layer.
Attributes
Enabled When enabled, the render element appears in VFB.
Deep output – Specifies whether to include this render element in deep images.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.SheenGlossiness.vrimg).
