Square Enix © Goodbye Kansas
This page gives some basic details about the Reflection Glossiness render element and how it is used in compositing.
The Reflection Glossiness Render Element stores the image's reflection glossiness as a grayscale image that represents the degree of Reflection Glossiness set for materials in the scene. White areas have the most reflection glossiness, while dark areas have little.
The amount of reflection glossiness for a material is set by its Reflection Glossiness parameter. For example, V-Ray Material (VRayMtl) has a Reflection Glossiness parameter, and and VRayFastSSS2 has a Specular glossiness parameter that goes in the Reflection Glossiness render element.
Attributes
Enabled – When checked, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.reflGloss.vrimg).
This render element is not supported with V-Ray GPU rendering.
Note
  • Since V-Ray Next, the Reflection Hilight Glossiness option has been removed from the UI as it can no longer be controlled separately from the Reflection Glossiness in VRayMtl. As there will be no difference between the Reflection Hilight Glossiness Render Element and the Reflection Glossiness one, the Reflection Hilight Glossiness Render Element is no longer available.
