Square Enix © Goodbye Kansas
This page gives information about the Unclamped Color Render Element.
The Unclamped Color Render Element is a color image that shows the original colors that were clamped or adjusted with Color Mapping. This render element is useful in the compositing process for enhancing extreme colors (very bright or very dark) or for shading the final image with the unclamped colors.
When Color Mapping is used, the values that are clamped depend on whether the Clamp output option has been enabled, as well as the rest of the Color Mapping parameters.
UI Path: ||Display Render Settings button|| > Render Elements tab > Unclamped Color
Attributes
Enabled – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.unclampedColor.vrimg).
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Examples
Beauty Composite Render
Composite using Unclamped Color,
made warmer
