The Options and Hardware Texturing rollouts are part of the VRayMtl parameters.
Options
Cutoff Threshold – A threshold below which reflections/refractions are not be traced. V-Ray tries to estimate the contribution of reflections/refractions to the image, and if it is below this threshold, these effects are not computed. Do not set this to 0.0 as it may cause excessively long render times in some cases. This parameter is not available when the renderer is set to GPU.
Hardware Shading
This is the standard Maya hardware texturing rollout. It enables you to choose which texture connected to the VRayMtl will be displayed in the viewport.
The Viewport Shading Quality option corresponds to the global viewport shading settings. They can be set individually for each material.
Viewport Shader Quality – Controls the VRayMtl's quality in the viewport. Note that this option overrides the global viewport shading setting for the material.
Use Global Settings – Uses the global viewport shading settings.
Low – Renders only the direct diffuse and specular (Fresnel, metalness and specular BRDFs) components.
Medium – In addition to the ones rendered with Low setting, it includes environment sampling (reflections and refractions), sheen and coat.
High – In addition to the ones rendered with Medium settings, includes normal/bump mapping, diffuse roughness and GTR gamma other than 2.0.
Previous:
