© Taichi Kobayashi
This page provides information about the Chaos Cloud node in V-Ray for Houdini.
The Chaos Cloud node allows you to submit a render job from V-Ray for Houdini to Chaos Cloud for rendering.
To learn how to use Chaos Cloud, refer to the Rendering in Chaos Cloud page.
Upload to Chaos Cloud – Submits the currently open scene for rendering in Chaos Cloud.
Valid Frame Range – Specifies how to obtain the frame range.
From ROP – Takes the settings for the render job from the connected V-Ray Renderer node.
Current Frame – Renders the current frame only.
Frame Range – Renders a specified range of frames.
Start/End/Inc – Specifies a Start frameEnd frame and Increment frame manually when the Valid Frame Range is set to Frame Range
Override Camera Resolution – When enabled, overrides the camera resolution.
Resolution – Specifies a camera resolution for the render job when Override Camera Resolution option is enabled.
Main
Project – Defines in which project to save the render job.
Job – Sets the name of the render job.
Client Update – Updates the Chaos Cloud Client app.
Export
Export Directory – Specifies a temporary directory to export data from job uploaded to Chaos Cloud.
