© Taichi Kobayashi
This tutorial walks you through the steps of creating a shadow/matte catcher.
A shadow catcher is a matte object, which is not directly visible in the scene, but shows the received shadows. This approach is ideal for achieving a photorealistic render, compositing a 3d object with a shadow on top of the environment map or just a backdrop.
For the purpose of this tutorial, we use car geometry from our Chaos Cosmos 3D content library. The scene lighting is achieved with a V-Ray Dome light loaded with an HDRI, and another HDRI from Poly Haven used as an environment.
The renders on the right illustrate what a great difference a shadow catcher usage adds to the final image.
Note that the downloadable scene files show only the setup for Houdini.
To download scene files: Download Scene Files
Want to follow along but don’t have a license?: Download Free Trial
none
shadow catcher
Workflow
In this tutorial, a plane becomes a shadow catcher/matte object. There are two ways to do that:
  • by applying Matte/Shadow object properties to the plane
  • by using the V-Ray Wrapper material
Open the scene you will use for this tutorial and let's delve into each method.  Note that the scene shows only the workflows in Houdini.
Using V-Ray Object Properties
Houdini Workflow
Select the object, which will become a shadow catcher. In this particular case, select the plane.
Click the Object Props button from the V-Ray Shelf, or go to V-Ray top menu > Object Properties > Common to assign object properties to the selected plane.
Next, go to the plane parameters and under the V-Ray tab > Matte / Shadow tab set the following settings:
  • Enable Matte /Shadow Options.
  • Enable Matte Surface.
  • Enable Shadows – this option allows the object to receive shadows.
  • Enable Affect Alpha – this option determines whether the received shadows affect the alpha. The Alpha Contribution specifies whether to add to the alpha, when set to 1.0. When the option is set to -1.0, it takes away from the alpha. When set to 0.0, it leaves the alpha unchanged.
  • Set the Alpha Contribution to -1.0. This allows the received shadows to take away from the alpha information for later compositing.
  • For increased realism, set the Matte For Secondary Rays option to With Projection Mapping. This enables the matte object to project the environment back onto other objects in the scene.
The environment can be added in the /out network through a V-Ray Environment ROP that needs to be connected to the V-Ray Renderer ROP's Environment parameter.
All these steps turn the plane into a Matte object. This means that it is not directly visible in the scene; instead the background color is shown in its place.
Solaris Workflow
In /stage, create a Render Geometry Settings LOP and chain it to the rest of the nodes. Drag the geometry you want to turn into a Matte Object and drop it into the Primitives.
Set or Create the following parameters:
  • Matte surface
  • Shadows
  • Affect Alpha
  • Alpha Contribution
Then enable all of them, and set the Alpha Contribution to -1.
The environment can be added through the Dome Light LOP parameters. Go to the V-Ray tab > Environment tab > Secondary Matte, and then set or create the needed parameters.
Now the plane is a Matte object.
Click the image to enlarge it.
Using V-Ray Wrapper Material
Houdini Workflow
Another way to achieve the shadow catcher effect is through the use of V-Ray Wrapper material.
In the mat Network, create a V-Ray Wrapper and assign it to the shadow catcher. In this case – to the plane.
Enable the same options for the V-Ray Wrapper material as the ones outlined in the previous approach:
  • Matte surface
  • Shadows
  • Affect Alpha
Set the Alpha contribution to -1.0.
This turns the plane into a Matte object. This means that it is not directly visible in the scene; instead the background color is shown in its place.
Solaris Workflow
In /stage, create a Material Library LOP or use an existing one if available. Dive inside it and create a new material VOP - VRayWrapper.
Create an Assign Material LOP, and then assign the new shader to the shadow catcher (the plane). For more detailed instructions on how to work with Material Library and Assign Material LOPs, see the Working with Solaris Materials page.
  • Matte surface
  • Shadows
  • Affect Alpha
Set the Alpha contribution to -1.0. Just like in the preceding workflows, set the Matte For Secondary Rays option to With Projection Mapping to increase the realism of the image. This enables the matte object to project the environment back onto other objects in the scene.
Now the plane is a Matte object. This means that it is not directly visible in the scene; instead the background color is shown in its place.
