This page provides information on the Global Illumination settings in the Asset Editor.
Global illumination refers to lighting in a scene/environment that comes from light bouncing around and off objects (or the environment itself). Global Illumination (or GI) refers to the computation of this effect through computer graphics.
V-Ray implements several approaches (called engines) for computing indirect illumination with different trade-offs between quality and speed. Additional rollouts become available depending on the engine(s) specified for Primary and Secondary Rays:
  • Brute Force Settings – The default engine for Primary Rays. It can be used for Secondary Rays as well.
  • [DEPRECATED]Irradiance Map Settings – This option is deprecated. An alternate engine for Primary Rays only.
  • Light Cache Settings – The default engine for Secondary Rays. It can be used for Primary Rays as well.
V-Ray GPU always works with Brute Force as Primary rays engine.
The settings in some of the rollouts are organized in Basic and Advanced mode. You can switch the mode from the toggle button () located next to the rollout title or globally from the Configuration rollout.
UI Path
||V-Ray Asset Editor|| >  Settings > Global Illumination
Global Illumination
Enabled – Turns indirect illumination on and off.
Primary Rays – Specifies the GI method to use for primary diffuse bounces.
Irradiance map (deprecated) – Causes V-Ray to use an irradiance map for primary diffuse bounces. See the Irradiance Map Settings section for more information. This is a legacy option that will be removed in the future.
Brute force – Specifies direct computation for primary diffuse bounces. See the Brute Force Settings section for more information.
Light cache – Specifies the light cache for primary diffuse bounces. See the Light Cache Settings section for more information.
Secondary Rays – Specifies the GI method to use for secondary diffuse bounces.
None – No secondary bounces are computed. Use this option to produce skylit images without indirect color bleeding.
Brute force – Specifies direct computation for secondary diffuse bounces. See the Brute Force Settings section for more information.
Light cache – Specifies the light cache for secondary diffuse bounces. See the Light Cache Settings section for more information.
Light Cache/Brute Force
The second rollout of the Global Illumination settings allows adjustment of the Secondary GI engine - either Brute Force or Light Cache. For more information on each, please refer to their respective page.
Light Cache as Secondary GI engine
Brute Force as Secondary GI engine
Caustics
V-Ray supports the rendering of caustics effects by using one of the following techniques: photon mapping or progressive.
The new Progressive caustics solver uses advanced sampling techniques, and is able to trace as many photons as required without suffering the memory constraints of traditional Photon Mapping techniques.
It is loosely based on two papers: one on Progressive Photon Mapping from Knaus and Zwicker, and another on Metropolis-guided caustics tracing from Šik and Krivánek.
The other method, Photon Mapping, is a two-pass technique.
The first pass consists of shooting light particles (photons) from the light sources in the scene, tracing them as they bounce around the scene, and recording the places where the photons hit the object surfaces.
The second pass is the final rendering, which is when the caustics are calculated by using density estimation techniques on the photon hits stored during the first pass.
When using Interactive rendering, only Progressive Caustics are supported! If Photon Map method is selected, V-Ray silently falls back to Progressive method.
Caustics – Enables or disables rendering of caustics.
Multiplier – Controls the strength of the caustics. It is global and applies to all light sources that generate caustics. Should a different multipliers for each light source be needed, the V-Ray properties of each light should be edited. Note: this multiplier is cumulative with the multipliers in the local light settings.
It should also be noted that changing multipliers, while useful for artistic purposes, will result in physically-inaccurate scenes.
Search Dist (Pixels) – Specifies the initial photon lookup radius in pixels. The Progressive mode works only in Pixels.
Tips when working with progressive caustics:
Required:
  • Affect Shadows should be off in refractive materials if they are to generate caustics
  • The Affect Channels option should be set to Affect all Channels in refractive materials to ensure the Caustics render element contains also the ones fallen behind refraction.
    Not doing so leaves photons fallen behind refractive surfaces inside the Refraction RE, but not inside the Caustics one
  • If present, the VRaySun's photon emit radius should be set to a value large enough to encompass the relevant parts in the scene
Optional:
  • It is strongly recommended to set time limit when rendering with Progressive Caustics, rather than relying on Noise Threshold value only.
  • Lower the Shading Rate.
    Photons are cast for each camera ray, not for the secondary ones. The more camera rays are cast, the more photon passes are achieved.
    A value of 3 is fine if rendering with the rest of the scene, but a value of 1 could be used if rendering specific caustic passes (for example, a caustics pass scene prepared with the purpose of maximizing caustics' calculation speeds).
Managing Expectations:
  • The progressive caustic solver is fire and forget
    This means that it can be turned on in any scene, and expected to trace photons on any specular or refractive surface.
    It doesn't, however, mean that doing so will result in an image converged to perfection within a short time.
    The approach, novel as it is, is still photon-map based, and judgement should be used to ensure quick, noise and frustration-free results.
  • It renders with the beauty
    The solver does indeed render happily alongside a beauty pass, storing caustics in the appropriate Render Element (see requirements tips above!), but that may not be the best solution as far as performance is concerned.
    It's suggested to consider preparing a dedicated caustic rendering pass if the photon tracing is particularly extensive, and/or if sequences are to be rendered.
    That way, it will be possible to optimize the caustics calculation separately from the requirements of the beauty pass.
Photon Map Caustics
Multiplier – Controls the strength of the caustics. This parameter is global and applies to all light sources that generate caustics.
Search Distance Units – Determines in what units the Search distance parameter is specified - World units or Pixels.
Search Dist (World)/(Pixels) – When V-Ray renders the caustics effect at a given surface point, it searches for a number of photons on that surface in the area surrounding the shaded point (search area). The search area in fact is a circle with center the original photon and its radius is equal to the Search distance value. Smaller values produce sharper, but perhaps more noisy caustics; larger values produce smoother, but blurrier caustics.
Max Photons – Specifies the maximum number of photons that is considered when rendering the caustics effect on a surface. Smaller values cause fewer photons to be used and the caustics are sharper, but noisier. Larger values produce smoother, but blurrier caustics. The special value of 0 means that V-Ray uses all the photons that it can find inside the search area.
Max Density – Limits the resolution (and thus the memory) of the caustics photon map. Whenever V-Ray needs to store a new photon in the caustics photon map, it first checks if there are any other photons within a distance specified by Max density. If there is already a suitable photon in the map, V-Ray just adds the energy of the new photon to the one in the map. Otherwise, V-Ray stores the new photon in the photon map. Using this options allows you to shoot many photons (and thus get smoother results) while keeping the size of the caustics photon map manageable. This option is not supported by V-Ray GPU.
Calculation Mode/Disk Caching
Mode – Controls the mode of the irradiance map:
New map – When enabled, a new photon map will be generated. It will overwrite any previous photon map left over from previous rendering.
From file – When enabled, V-Ray will not compute the photon map but will load it from a file. Press the Browse button on the right to specify the file name.
Progressive – Uses advanced sampling techniques and is able to trace as many photons as required without suffering the memory constraints of traditional Photon Mapping techniques.
Keep File – When enabled V-Ray keeps the photon map in memory after the scene rendering has finished. When disabled, the map is deleted and the memory it took is freed. Enabling this option can be especially useful if you want to compute the photon map for a particular scene only once and then re-use it for further rendering.
Auto-Save File – When enabled, V-Ray automatically saves the caustics photon map to the provided file when rendering is completed. Specifies the file location where the caustics photon map will be saved after rendering.
Caustics are not supported in VR Camera and Stereo Camera modes.
The Calculation Mode/Disk Caching options are not supported by V-Ray GPU.
GI Caustics
GI Caustics rollout is available only in Advanced mode.
Reflective Caustics – Allows indirect light to be reflected from specular objects like mirrors, etc. Note that this is not the same as Photon Mapped Caustics, which represent direct light being reflected by reflective surfaces.
Refractive Caustics – Allows indirect lighting to pass through a transparent objects like glass, etc. Note that this is not the same as Photon Mapped Caustics, which represent direct light going through transparent objects. You need refractive GI caustics to get skylight through windows, for example.
Ambient Occlusion
These controls allow an ambient occlusion term to be added the global illumination solution. Ambient Occlusion rollout is available only in Advanced mode.
Enabled – Turns ambient occlusion on or off.
Radius – Determines the amount of area (in Scene units) where the ambient occlusion effect is produced.
Occlusion Amount – Multiplies the amount of ambient occlusion. A value of 0.0 produces no ambient occlusion.
Example: Ambient Occlusion
Note: the scene in this example is from Evermotion. ( http://www.evermotion.org/)
This example demonstrates the effect of the global ambient occlusion options.
The first image to the right is rendered with the Light cache for both primary and secondary bounces, Fixed Filter type for the light cache, and Store direct light off. The second image in the center is rendered with the same light cache settings, but with global ambient occlusion enabled. The third image to the right is rendered without ambient occlusion, with Brute force GI engine for primary bounces, and the Light cache as a secondary engine with Nearest  Filter type. The render times include the time for calculating the light cache. Note how ambient occlusion can produce a feeling of a more detailed image, even though the result is not entirely correct.
Ambient occlusion is off - lighting is good, but there is a lack of detail
Ambient occlusion is on - details are much more defined
Brute force GI, no ambient occlusion - details are fine, but render times is longer.
Progressive and Photon Map Caustics Examples
The example illustrates the Caustics parameters of the Progressive and Photon map caustics methods. The lights used in the scene are two V-Ray Spot Lights with different intensities and temperature. The scene is in millimeters.
Example: Progressive Caustics - Caustic Subdivs
(Caustic Subdivs parameter of the Lights' Caustic Photon option)
Multiplier = 20; Search Distance = 100
Example: Progressive Caustics - Multiplier
Caustic Subdivs of the Lights = 6000; Search Distance = 100
Caustic Subdivs = 3000
Caustic Subdivs = 4000
Caustic Subdivs = 10000
3000
10000
Multiplier = 10
Multiplier = 20
Multiplier = 30
10
30
Example: Progressive Caustics - Search Distance
Caustic Subdivs of the Lights = 4000; Multiplier = 20
Example: Photon Map Caustics - Caustic Subdivs
Multiplier = 20; Search Distance Units = World; Search Distance = 0.5; Max Photons = 5000; Max Density = 0
Search Distance = 4
Search Distance = 20
4
20
Caustic Subdivs = 6000
4000
10000
Example: Photon Map Caustics - Max Photons
Multiplier = 20; Search Distance Units = World; Search Distance = 0.5; Max Density = 0; Caustic Subdivs of both lights = 4000
Example: Photon Map Caustics - Search Distance
Multiplier = 20; Search Distance Units = World; Max Photons = 5000; Max Density = 0; Caustic Subdivs of both lights = 4000
Max Photons = 500
Max Photons = 2000
Max Photons = 5000
500
5000
Search Distance = 0.2
Search Distance = 1
0.2
1
Example: Caustic Photons of V-Ray Sun - Caustic Subdivs
Mode = Progressive; Multiplier = default value; Search Distance = default value; Emit Radius = 1000
The scene is in centimeters.
Example: Caustic Photons of V-Ray Sun - Emit Radius
Mode = Progressive; Multiplier = default value; Search Distance = default value; Caustic Subdivs = 16000
Caustic Subdivs = 5000
1000
16000
Emit Radius = 350
Emit Radius = 500
Emit Radius = 1500
Emit Radius = 4000
350
4000
  • Since V-Ray Next Update 1.1 some of the render elements are rendered differently than before. The Lighting render element now contains all direct diffuse illumination and the GI element contains all indirect diffuse illumination. Similarly, all direct reflections of lights now go to the Specular element and all indirect reflections go to the Reflection element.
Progressive Caustics Advantages
  • they require nearly no setup;
  • each cast photon is more useful than those in traditional Photon Mapping;
  • the number of photons castable is only limited by time, not memory;
  • they can resolve tiny caustic details, compared to the scene size;
  • they can resolve caustic details also when a camera is very zoomed in on them;
  • statistics about the photon tracing can be found in the VFB2 stats panel;
Progressive Caustics Limitations
  • they require the progressive image sampler;
  • the image sampler often requires Min. subdivs values much higher than 1;
  • it's non-deterministic, meaning that there could be somewhat unpredictable render times, and also tiny differences in the visual results when rendering the same frame twice;
  • currently doesn't work with distributed rendering;
  • currently not supported by the GPU engine;
  • Depending on the scene, the performance might not scale linearly with the number of threads/cores, resulting in inefficient CPU utilization.
