Official release
Date - Nov 19, 2020
Release Notes: V-Ray 5
VISUALIZE IN REAL-TIME
Supercharge your Rhino and Grasshopper design workflow
V-Ray Vision lets you visualize your designs in
real-time while you work in Rhino and Grasshopper. Build your model, apply materials, set up lights and cameras—all with a live real-time view of your scene. And anytime you’re ready for photo quality renders, V-Ray is always there, ready to go.
V-Ray Vision helps you:
Explore your model
Collaborate on design decisions
Easily save images and 360 panoramas
Export real-time animations
LIGHTING MADE SIMPLE
Now with Light Mix, after your scene is rendered, you can instantly adjust the brightness and color of lights without having to render again. This lets you look at dozens of lighting scenarios from just a single render.
ADD YOUR FINISHING TOUCH
With the new V-Ray Frame Buffer, you can do more in V-Ray than ever before. Make color corrections, combine render elements, adjust lighting, and add the final touches to your renders without needing a separate image editing app.
Find more at the V-Ray Frame Buffer page.
SEAMLESS GRASSHOPPER INTEGRATION
Parametric design visualization
New live link between V-Ray Vision and Grasshopper lets you visualize your parametric designs in
real-time. V-Ray Clipper support makes it easy to render sections and cutaways. And Stereo Camera support now lets you render stereoscopic 3D images.
LIGHTING THAT’S AUTOMATIC
With the new Light Gen tool, lighting your Rhino scene is automatic. In minutes, Light Gen calculates multiple lighting options and shows them as thumbnails. Simply choose the look you want and render.
HIGH-RESOLUTION MATERIAL LIBRARY
Get a headstart on your next design project. V-Ray 5 for Rhino comes with access to over 500 render-ready materials with high-resolution 4K textures.
MORE ACCURATE SUN AND SKY
The new Improved Sun and Sky model is more accurate and looks great even at sunrise or sunset when the sun is at the horizon. You can also override the position of the sun and sky with new Custom Orientation controls.
Find out more at the SunLight page.
ADD RANDOMNESS FOR REALISM
New randomization tools make it easy to create subtle variations in textures and materials for added realism. Plus the new Stochastic tiling controls are a fast fix for repeating patterns.
IMPROVED LINE RENDERING
To give your renders an illustrative look, now you can easily add linework with global contour controls and material overrides.
Find more at the Outlines page.
DIRT AND WEATHERING
The improved V-Ray Dirt texture can help give your Rhino model a weathered look. Easy controls let you vary the amount of dirt and streaks in corners or across entire surfaces.
