This page provides information on the Lens Effects layer found in the New V-Ray Frame Buffer.
Floatingpagetoc |
Section | ||||||||||||||||||||||||||
Anchor | ||||
Lens FX controls
Anchor | ||||
Example: Size
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Bloom / Glare
Anchor | ||||
Example: Intensity
Anchor | ||||
Example: Cold/Warm & Saturation
Aperture Shape
Anchor | ||||
Example: Streak blur
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Lens Scratches
Lens Dust
Obstacle Image
Anchor | ||||
Example: Obstacle Images
Size (constant) = 50
Bloom (constant) = 0.5
Filter Image
Aperture Preview
File Names of Saved Channels
As expected, channels will keep their names as displayed in the VFB when saving them to a single .vrimg or .exr file (using the V-Ray raw image file option from the Frame buffer rollout or the Save all image channels to single file VFB button). The same channel names will be appended to the files when you use the VFB button Save all image channels to separate files.
However, using the Save separate render channels option from the Frame buffer rollout to save all layers as separate files will save the effectsResult channel to a file with the text RGB_color appended to its name, and the RGB channel as origRGB instead.
