Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.5
ThumbnailBGImageHeight100px
ThumbnailOverlayOpacity0
ThumbnailSubTextSize13px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleHeight80%
ThumbnailOverlayRectangleBottomPadding10px
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1width1540px
Columns2width1290px
HideElements
cssselector#ehp-navigation-content, #easy-heading-free-end, #ehp-navigation-wrapper, #ehp-navigation, #ehp-nav-content-wrapper, #ehp-navigation-content, #ehp-navigation-switcher, .ehp-drag-bar, .ehp-navigation-title, .ehp-navigation-list, .ehp-navigation-bottom, #nav-header-wrap
CSS Stylesheet#ehp-navigation-wrapper{ width: 0px !important; top: 0px !important; left: 0px !important; } #ehp-navigation{ width: 0px !important; } #ehp-navigation-content{ width: 0px !important; }
#tocVertical, #tocHorizontal
This page provides information about the Tool menu and its sub-menus in Chaos Vantage.
Menu Options
width60%
High Quality Render – Opens the Render setup dialog where you can specify render parameters for still, sequence, or batch rendering. (Shortcut: Ctrl+R )
Record Camera Movement – Creates a new camera slot in the Camera tab and records its movement. (Shortcut: Ctrl+Shift+R )
Quick Record Viewport – Starts capturing the viewport to an .mp4 file in the .vrscene file location. (Shortcut: Ctrl+Backspace)
Record Viewport to Video File – Opens the Viewport Video Capture dialog where you can specify the quality preset and frame rate.
width5%
width35%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardTooltipClick to open the Render Setup page
CardPageLinkRender Setup
High Quality Render
Detailed information about the Render Setup window, accessible through the Tools menu.
Textboxcard
CardTooltipClick to open the Render Elements page.
CardPageLinkRender Elements
Render Elements
Detailed information about the Render Elements dialog, accessible through the Render Setup window.
Textboxcard
CardTooltipClick to open the Record Viewport to Video File page.
CardPageLinkRecord Viewport to Video File
Detailed information about the Viewport Video Capture dialog, accessible through the Tools menu.
