width60%
The V- Ray Render Stats material can be used to specify additional render settings on a per-material basis. The same settings can be accessed through the Object Properties, but if this material is used, it overrides those from the object properties.
The same properties are also present in every shape of a Maya node. Those override both from this material and from the object properties.
width5%
width35%
Image Removed
width50%
Image Added
width50%
Input Sockets
width50%
This section lists input sockets that are not found in the Properties tab but only as inputs for the node.
Base material – The input socket for the actual surface material.
width5%
width45%
Image Added
Render Stats
width50%
Primary Visibility – When disabled, the object will not be visible. See the Primary Visibility example.
Visible in reflectionsIn Reflections – When disabled, the object will appear perfectly transparent to reflection rays. See the Visible in Reflections/Refractions example.
Visible in refractionsIn Refractions – When disabled, the object will appear perfectly transparent to refraction rays. See the Visible in Reflections/Refractions example.
Casts shadowsShadows – When disabled, the object will not be casting shadows. See the Cast Shadows example.
Receive shadowsReceives Shadows – When disabled, the object will not receive shadows.
Visible to To GI – When disabled, the object will be considered perfectly transparent to GI rays.
width5%
width45%
Image Added
Anchor
primary_cast
primary_cast
Example: Primary Visibility
This example shows the effect of the Primary
Visibility parameter. The V-Ray Render Stats material is applied to the glass owl figurine.
When Primary
Visibility is disabled, the glass owl figurine is not visible to the camera, but it is still visible in reflections and refractions
and continues to cast shadows.
width
10%
width45%
Example: Cast Shadows
This example shows the effect of the Cast shadows parameter. The V-Ray Render Stats material is applied to the metallic owl figurine.
25%
width45%50%
This example shows the effect of the Primary visibility parameter. The V-Ray Render Stats material is applied to the glass owl figurine.
When Primary visibility is disabled, the glass owl figurine is not visible to the camera, but it is still visible in reflections and refractions. It also continues to cast shadows.
Image_comparison_slider
AddButtonsfalse
AttachmentImageBeforeHoudini18_VRay5_VRayRenderStats_Reflections_and_Refractions_off.png
AttachmentImageAfterHoudini18_VRay5_VRayRenderStats_Reflections_and_Refractions_on.png
width25%
Anchor
shadow
shadow
This example shows the effect of the Cast Shadows parameter. The V-Ray Render Stats material is applied to the metallic owl figurine.
width25%10%
width45%50%
AddButtonsfalse
width25%
Anchor
visible
visible
Example: Visible in Reflections/Refractions
This example shows the effect of the Visible in reflectionsIn Reflections and Visible in refractionsIn Refractions parameters. The V-Ray Render Stats material is applied to the metallic owl figurine.
When Visible in reflections In Reflections is off, the metallic owl is transparent to reflection rays, and respectively when the Visible in refraction In Refraction is off, the metallic owl is transparent to refraction rays. When both options are off, the metallic owl is neither visible in the mirror plane nor in the glass owl figurine.
width25%
width50%
Image slider
Panel
borderStylenone
Visible in reflectionsIn Reflections and Visible in refractionsIn Refractions are on
Panel
borderStylenone
Visible in reflectionsIn Reflections is off, Visible in refractionsIn Refractions is on
Panel
borderStylenone
Visible in reflectionsIn Reflections is on, Visible in refractionsIn Refractions is off
Panel
borderStylenone
Visible in reflectionsIn Reflections and Visible in refractionsIn Refractions are off
width25%
