Comment: imgs and descriptions
width50%
The V-Ray Rock texture generates a procedural rock pattern using two colors or texture maps.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Textures V-Ray Rock
width5%15%
width45%35%
 Image Modified
Node Input Sockets
width50%
Uvwgen – Mapping – This slot allows you to connect a Mapping node (UVW Mapping, UWV Randomizer) to adjust the UWVs of the texture.
Color 1 – (input socket) – Input for the first color texture.
Color 2 – (input socket) – Input for the second color texture.
width5%
width45%
Image Added
Common
width50%
Compatibility With – Allows you to match the result of the texture in Blender to that in either 3ds Max or Maya.
Max – The resulting alpha of the texture is the intensity of the texture.
Maya –
The resulting alpha of the texture is the color luminescence.
InvertWhen enabled, inverts the colors in the final result.
Invert Alpha –  Inverts the alpha channel if Invert is also enabled.
Color
Multi
Mult  Corrects the color of the texture by multiplying the color values in the texture with the color values specified here.
Color Offset  Corrects the texture's color by adding the color values specified here to the color values of the texture.
Alpha Mult – A multiplier for the Alpha value.
Alpha Offset – Controls the offset of the Alpha value.
No UVs Color  Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square.
Color Offset –
Alpha Mult –
Alpha Offset –
No UVs Color –
width5%
width45%
Image Added
Mapped
width50%
UV noise phaseNoise Phase – Specifies the UV noise phase.
Color 1 – Specifies a color to be used when no node is connected to the Color 1 socket.
Color 2 – Specifies a color to be used when no node is connected to the Color 2 socket.
Grain Size – Controls the size of the fine grain features.
Diffusion – Lower values make the resulting texture sharper, while higher values blur the texture details more.
Mix Ratio – Controls the mix between Color 1 and Color 2.
width5%
width45%
Image Added
